Question about Miele Novotronic Premier 500 Front Load Washer
Miele novotronic w820
Electrical element for heating water in machine is not working ! machine is 12 years old . Can anyone take me through process of changing above ? this is the 2nd element in wash-machine .
  • osama_anshas Jul 26, 2008
    cheers , mate . thanks ,i will try to get a replacement element and follow your steps ..........
  • Emma Duers Feb 25, 2012
    can you please letme know how to take off the facia of the novotronic W820 please
  • 70 Answers
I havent changed one on this model but there useally much the same and qiute easy to do first take the back off the machine
at the lower half of the rear of the drum there is two prongs sticking out with wires on spade connectors a third earth wire in the centre remove these 3 wires they should just pull off but sometimes held on by nuts you will have to check yours then with the machine emty of water unbolt this is the element assembly is the reverse
Posted on Jul 26, 2008
Miele Novotronic 500, 10 years old, noisy filling, no error light, inlet filters clean. Any suggestions please?
Hi dear,
As I know it's a indication on inlet valves going to fail. I hope that helps. Thanks.
Jan 21, 2016 | Miele Washing Machines
Why is my miele t220 novotronic have a burning smell when working
If lint material has collected around the heating element this will happen. Locate the element and clean out all debris, lint, etc.
Sep 01, 2015 | Miele Novotronic T220 Electric Dryer
Miele w820 novotronic
A What-ty? Miele! Well Whatever it is called. You got a bad drain pump and it needs to be replaced!
Jan 16, 2014 | Washing Machines
My Miele dryer Miele Novotronic 494C does not dry clothes
Check breaker, then wiring. This can be a thorough job. Your element is probably burned out. If it is older than10-12 years,this is normally it. One other thing to look at is the relay switch which is located under the top. It will shut down if there is an electrical problem.
Mar 15, 2013 | Miele Dryers
W820 washing machine
Some markets do have an internal fuse, if it has one it will be right where the power cord runs into the machine, if not then the issue will be with the main control panel.
Mar 10, 2012 | Miele Novotronic Premier 500 Front Load...
My miele dishwaher is not heating the water thus not wahsing the dishes properly
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Apr 26, 2011 | Miele 24 in. Novotronic G641 Plus Built-In...
Hi, I have a W526 Novotronic Miele
rinse light flashing is an indication the is a problem within the motor circuit. Brushes,motor or electronic.
Dec 24, 2010 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic W 833 won't drain
hi,
if your washing machine drains into a spigot in the u bend under your sink you will probably find a blockage here. you need to remove the drain hose and have a look in the hole.
if not when you remove the fluff filter have a look in the hole and make sure the drain pump turns freely. you can also run a drain spin cycle with the fluff filter removed and make sure the drain pump is working.
Jun 14, 2010 | Miele Novotronic Premier 500 Front Load...
Tripps electric when heating miele w989i
you may have a faulty heating element or the wire going to the element has broken off and is touching the casing of the unit. if you are confident and able to remove the front panel you will see the heating element under the drum.
Sep 27, 2009 | Miele Novotronic Premier 500 Front Load...
Miele Washer problem Novotronic Premier
Main wash light flashing is a heating fault. You either have a faulty temp sensor (NTC) or the pressure chamber has blocked and the heater element has popped.
Oct 22, 2006 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic Premier 500 Front Load Washer Logo
1,267 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
