Question about GE 27851FC1 2.4 GHz Cordless Phone
2003 Phone- no dial tone GE CORDLESS 900MHz
No dial tone.  I bought this phone approx 2003-2004, never charged it completely, never used it, and now I want to but can't find the users manual.  I tried charging it for 24 hrs and it just doesn't work.  It's been sitting around for a long time buy I am able to set the outgoing message and time.  Also, the screen on the phone is blank.  no dial tone
  • justawinch Jul 26, 2008
    i have no dial tone....help!!!
3 Suggested Answers
SOURCE: 2003 Phone- no dial tone GE CORDLESS 900MHz
http://www.geappliances.com/service_and_support/literature/
Posted on Dec 08, 2007
I have a GE 25952 cordless phone that has not worked at all in the year I've had it. No dial tone. No ringer. The instruction manual that came with the phone is all in Spanish. What is the solution?!
Posted on Jul 19, 2008
How do i put the ring tone back in the handset
    Does the Phone Power Up?
  1. When you pick up your GE cordless phone and press a button, the phone should beep as a confirmation that a button has been pressed. If the telephone handset does not beep, or if it does not respond to any buttons, the battery may be in need of a recharge. Verify that the cordless phone base unit is plugged in to an electrical source, then place the handset into the charging cradle. If no lights illuminate on the phone, or if charging fails to correct the issue, clean the metal charging contacts on the cordless handset and place the phone back on the charger. If it still fails to respond or to charge, the unit may need to be serviced or replaced.
  2. Does the Battery Hold a Charge?
  3. If the cordless phone charges up and appears to be ready for use but dies after only short periods of use, the internal rechargeable batteries may need to be replaced. Replacement batteries are widely available at electronics and discount retail stores. Note your phone's exact model number, as this number will be necessary when purchasing a replacement battery.
  4. Listen for a Dial Tone
  5. If the GE cordless phone powers on, and beeps when you press keys, but no dial tone is heard, one of three problems is the likely culprit. The phone's batteries may have an insufficient charge to fully power the phone, a condition that can be corrected by simply placing the phone back in the charger. If the batteries are charged, but no dial tone is heard, it is also possible that another telephone in your home or office is "off hook" or in use; verify that all telephones, fax machines and modems are securely on the hook. If there is still no dial tone, your telephone service may have been disconnected or require service by your local telephone company.
  6. Listen for Static
  7. On some GE cordless phone models, particularly older models, static may be heard if the radio signal between the handset and base unit experiences interference. Common sources of interference include unshielded electronics, appliances, and radio transmitters, as well as high-tension power lines. If your phone offers an option to change channels, try several different channels to see if the static is eliminated. If static continues to exist, or if static can be heard on wired phones sharing the same line, your telephone line may require service.
  8. Verify Your Handset is Registered
  9. Some models of GE cordless phones may display a message on the display screen that the handset needs to be registered. If this message appears, move the handset close to the base unit and press the "Prog/Mute" button near the bottom of the handset. Next, press the "Pager" button on the base unit (your handset may instruct you to perform this step). Finally, press the "Prog/Mute" button on the handset one more time to complete the registration process. Your GE cordless phone should now work correctly.The GE Cordless Phone brand is designed to deliver the conveniences of cordless home service with quality sound and features. There are many models of the GE Cordless Phone. The most current models, including the DECT 6.0, have standard features such as call waiting, caller ID, visual ring indicator, phone number memory and digital answering systems .
  10. Before you use your GE Cordless Phone, ensure that you have all the parts. Your cordless phone package should include the phone base, a handset battery pack, a battery compartment cover, the cordless handset, a wall mount bracket, and a telephone line cord and AC power adaptor. Once you have confirmed that you have all of your parts, insert the handset battery pack into the handset and replace the battery compartment cover. Insert your telephone line cord and the AC power adapter into the phone base. The phone base identifies the telephone line as TEL LINE and the adapter as AC. Plug the phone base into the electrical socket. Place the cordless handset into the base. Allow the phone to charge for at least 16 hours before its first use. Failure to fully charge the battery before its first use will result in poor battery performance.
  11. Once you have fully charged your phone, you can proceed with setting up your phone's features. If your cordless phone includes an answering system, complete this setup process first. Turn on the answering system by pressing the on/off button. The message indicator light will display. The cordless phones are defaulted to English as the selected language. To change your language preference, press the "Skip" button for two seconds. The language will change to Spanish. Next, you will set up your voice time and day stamp. While the answering system is on, press the "Answer" button on your handset for two seconds. The phone will enter the answerer mode. Press the "8" key. This will take you to the time/day setup menu. Use the number keys to set the hour and minutes. Use the volume up and down arrows to set the AM/PM. Press "#" to save. The cordless handset will also require that you give it a name. Press the "Mute" button for two seconds until the handset reads "ENTER NAME." Enter the name of the handset by using the touchtone keypad. Press the "Mute" button to save. Enter the default area code by pressing "Mute" until the phone displays "AREA CODE." Enter your three-digit area code and press the "Mute" button to save.
  12. GE Cordless Phones are designed to be simple and convenient to use. To place or answer a call, press the TALK button. You can pre-dial a number by dialing the number before pressing the TALK button. When you are ready to make the call, press TALK and the phone will dial automatically. To answer a call that is waiting on the other line, press the FLASH button. If you experience call interference or bad reception while on a call, press the CHANNEL button until your line clears
Nov 17, 2009 | Uniden Cordless Phone
Swicth from tone to pulse
1) When the phone is in standby mode, press and hold the caller id/menu key.
2) Press the vol/ / key three times to select Dial.
3) Press the select key to toggle between Tone and Pulse.
4) Press the end key or return the handset to the base unit to complete the setting. The handset returns to standby mode.
This phone also has a feature that allows you to use Pulse dialing to make calls, but allows you to switch to tone dialing for automated systems (like “Please Press 1 for English) here are the steps for that:
Initially make your call with the pulse dialing mode. Once your call connects, press
the */tone key. Enter the desired number. These digits will be sent as tone dialing.
Once the call ends, the tone mode is canceled and pulse dialing mode resumes.
Apr 06, 2009 | Uniden Cordless Phone
GE 2.4 ghz card less phone
AC/DC Power not connecting, hence not charging at all. Dial tone is also so low it cannot hear from very near.Hence the cordless handset is useless since last 3-4 month. No support available for me. My Product code is ES 27923GE2-B (GE 2.4 GHz)
Dec 16, 2007 | Uniden Cordless Phone
Handset has No link to base
I was having the same problem with the same model phone, and fixed the problem by rebooting the phone – unplugging the AC and phone cord from the base station and plugging both back it, then removing and replacing the handset to regenerate the security code.
Nov 17, 2007 | Xact Communication XG2200 Cordless Phone
I am having the same problem with general electric model 27939ge3-a . I am very displeased with the GE website(s) as it is difficult to manuveur around to find any user manuals.
Next time I purchase a phone, I will check the manufacturer's help support first.
As to a solution. I may try purchasing a new battery. Perhaps it is a power issue
Oct 30, 2007 | Uniden Cordless Phone
No dial tone at all!
I assume you put the battery in and charged it for 12 hrs. If everything is plugged in correctly then it's time to return the phone as it is defective. GE does not have a very good rep with phones.
Oct 29, 2007 | GE 25865 Cordless Phone
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
Handset No Link To Base error and no dial tone
I have the problem. I think it is because the battery i have in it was a Ni-MH and it should be a Ni-Cd. I am now looking for the right baterry Good luck Frank wolfgang24@verizon.net
Jan 27, 2007 | GE 900 MHz Phone
Handset ?No Link To Base? error and no dial tone
2/29 Have you registered or re-registered the handset?
"No link" can mean handset is not accepting radio wave of base unit. At Mfgr website pull-down operator's manual and look for registration instructions. Some sequence of buttons will create a radio signal from base (have handset off base) then another sequence of buttons on handset will accept radio signal. If handset has "menu" button, try "menu", then "00" (zero zero) then select an accept or "OK" button. Good luck.
Jan 14, 2007 | Xact Communication XG2200 Cordless Phone
GE 27851FC1 2.4 GHz Cordless Phone Logo
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
