Usually if something is shutting down as the volume is turned up, it is caused by a bad speaker. Try disconnecting one speaker at a time, and see if you can turn up the remaining speakers until you find the one that is causing the problem.
The only thing i know to be named "Program Files" is a default folder created upon installing the OS. It wouldnt be a program, its a folder where the programs you install are stored by default. if you did delete this folder, you may no longer have a working OS, and might need to reinstall your OS.
Don't know if this will help go to the apple menu and then down to system preferences then choose Language and Text then go to input sources and select Devanagari and/or Devanagari-QWERTY and click on the show input menu in the menu bar which will allow to change easily. Hope it will help.
Since I don't know the operating system you're using, you will need to select your version of Windows in the "Choose your OS" drop-down list. Once you do this, the list of drivers for your motherboard with be shown.
http://www.gigabyte.com/products/product-page.aspx?pid=2669#dl
I hope this was helpful and thanks for using Fixya!
** If this was helpful, please leave a rating so others may be helped by this. **
Replace your Samsung with a borrowed monitor temporarily. This problem could also be caused by a failed video card or on-board chipset.
With your system shut down, unplug your monitor, plug in the replacement, then start your system.
If your OS is operating properly, it will find and incorporate the borrowed monitor but it may choose a default resolution so don't be surprised by larger or smaller icons but check for the vertical lines causing the problem.
If they are also present on the substitute monitor, then your monitor is OK and the video source has failed.
what are facing is a problem caused by a virus that either destroys files that support .exe applications to run or it replaces which makes your machine unstable. my first solution to you is to repair your operating system using the operating system cd. secondly, if that doesn't work please try installing a second os on your system and then you do a dual booting. u then delete the folder of the previous os. if that does not work u backup ur files and then you format ur system with a new os
When working with Mac OS, you're required to use an administrator password to install just about anything. If you forget your password, or if you're using a hand-me-down computer and you don't know the previous owner's password, there is no workaround to bypass the admin password. Your only solution is to reset the password with the discs the computer came with. This project has two phases. Changing the admin password is the first step, but you must also follow through and change the keychain login as well. Instructions Things You'll NeedMac OS X install CDResetting the Administrator Password in OS X
1 Locate the Mac OS X install disc your computer came with. If you don't have it, you may be able to get another one from Apple by calling (800) SOS-APPL. (You will most likely have to buy another one.) Insert the disc into the optical drive. 2 Restart the computer while holding down the "C" key. A "Utilities" or "Installer" menu will appear, depending on which version of OS X you are running. Select "Reset Password." 3 Select "Macintosh HD" from the available volumes. On the drop-down menu, select the name of the original administrator account. Do not select "System Administrator." 4 Choose a new password and enter it in the two fields. Click "Save."
Resetting the Keychain Password in OS X
1 Go to the "Go" menu from the Finder. Select "Utilities" and scroll down to locate "Keychain Access." Double-click it. 2 Select "Keychain List" from the "Edit" menu. 3 Highlight the "login" keychain and delete it. The next time you log in to the account you can save your new password. Don't forget to backup your files before you change anything. Your files shouldn't be affected, but it's better to be safe than sorry. Thank you and Goodluck
