Question about Car Audio & Video
My sub in my car only runs when the car is parked
YOU MIGHT HAVE THE AMP REMOTE WIRE SOMEHOW HOOKED UP TO YOUR PARKING LIGHT DO YOU HAVE ANY LIGHT THAT COMES ON WHEN YOUR IN PARK?
Posted on Jul 26, 2008
2 dvcoil 4ohm.subs, need 2 ohm load total for monoblok.amp. how do I wire.it
If you run one sub with the DVCs in parallel, you would get 2 ohms. If you run both subs with all DVCs in parallel, you would get 1 ohm.
If you run both subs with DVCs in parallel and subs in series, you would get 4 ohms.
If you run both subs with DVCs in series and subs in parallel, you would get 4 ohms.
If you run one sub DVCs in series and the other sub DVCs in parallel and both subs in parallel, you would get 1.6 ohms but the subs would not be balanced.
If you run both subs on only one coil and the subs in parallel, you would get 2 ohms (but only if the individual coils are rated for the full power)
Oct 15, 2015 | Ohm Car Audio & Video
Won,t come out of park
Not sure what coming out of park has to do with custom sub boxes? May be you can give us a clear ask?
Dec 14, 2014 | JVC Mtx Thunderform Custom Box For Ford...
Tail lights and dash lights is no working
did you check them in the dark to see if , not just dim?
what sub model, EX, or LX? the LX is very different.
the car has 2 fuse boxes. did you know that, most cars do.
the fuse is called fuse #10 (fuse 10 runs hazards too, are haz dead?)
box one in cab, and 2 in engine bay.
the HAZ fuse is marked, HAZ
park/dash dim all dead, this is the largest path in car, over 20 lamps on most cars. (lots of places to mess up)
all are dead, all parks, front , rear, side and cab (dim) dead??????
even the license plate lamp>>>> details?,,,,, help, im blind..
here ill login to alldata.com for you, so can you at anytime.
ok this car can have a tail light relay. the LX dont have one.
the combo switch (1st click ) turns on park(tails)
and the relay energizes and runs all the park lamps.
but not on the LX, the LX is switch direct drive to all parks.
so?????
found this with google. NON LX !!!
Fuse #10 (15A) Audio unit, pocket light, clock, climate control, cruise switch light, gauge assembly, hazard switch light, heater control panel, interior lights switch light, driver's multiplex control unit, power sliding doors switch light, rear A/C switch light, taillight relay TCS swtich light.
Dec 30, 2013 | 1999 Honda Odyssey
Known issues for repeated fuel pump failure
If you buy a new GM fuel pump or brand
name new pump- then NO-- to the repeat problems
I won't
Mar 04, 2013 | 1997 Buick Park Avenue
2006 galant vibrates badly at idle
how many miles on it? how long have you had it? it sounds like the ICS sensor . that is idle control actuator it is on the thottle body
Oct 30, 2012 | 2006 Mitsubishi Galant
Will a SONY XPLOD XM1652Z 2 CH 1000 watts hold two 12in subs?
should do easily though you may need to employ the use of a cross over just incase something goes pop and burns you're car out when you park it after you've been hammering the subs.
May 13, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Amp staying on but cutting out?
Hello Willb2396,
Actually you answered your own question in your paragraph. I draw your attention to your statement of:
"It will work for as long as I'm driving I will park my car, and when I turn it back on every thing will be working just fine and, then a couple minutes later, amp cuts out and won't hit for a couple hours or a couple days.... I have checked the sub multiple times and I don't see it being the sub or the amp"
You are correct it is neither the Sub nor the Amp. The problem is either your voltage regulator or your alternator. one and or the other is going bad.
Here is some advice check your ground wires, the buy a dual alternator kit, it contains the parts you will need to add an additional alternator to your car. This will provide the power you need.
I hope this helps,
Thank you,
Shuttle83
Nov 10, 2008 | Alpine MRP-M650 Car Audio Amplifier
Subs just quit
It's probably not a battery problem; sounds more like a sub or amp problem. Check the sub's cone and see if it siezed up or if you smell something burned, also check the amp to see if you can smell the "burnt" smell. It's unlikely that it's your battery, because if it were nothing would be working properly. Take you subs and amp(s) to a good shop and ask them to bench test each item.
Jun 13, 2008 | Car Audio & Video
How to instal my pioneer avh-p57000dvd
you have to run a toggle switch to do it connect the part where it runs from the dvd player to the main connector on the toggle then find a ground and connect that to the ground on the toggle and flip the switch put a dvd in and should work
Dec 26, 2007 | Pioneer AVH-P5700DVD Car DVD Player
Car Audio & Video Logo
51 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
