Question about Alesis Multimix 12 USB 12-Channel Mixer Spdif System
Scratchy noise So for some reason from one usage to another, my "main mix out" make a funny scratcy noise kinda like interference...and it's very annoying, so I had to resort to using "control RMout" as my main output which switches my "volume" control to the control RM knob, and i've been using "main mix out" for my bass, but I've been forced to keep the volume low so that people won't hear it... any suggestions?
What's a potentiometer?
Posted on Aug 01, 2008
  • 417 Answers
you can go to radioshack and get TV TUNER CLEANER, spray it into that troublesome potentiometer amd cycle it while off several times and then try it again. If not the potentiometer may have to be replaced but I believe radioshack may have one thats a near perfect replacement. hope that helps
J
Posted on Jul 26, 2008
One of my speakers is making a scratching noise when both the positive and negative leads are plugged in. both the cabinet and amplifier are parallel. I've cleaned the whole thing in and out and it's still...
having only one speaker that sounds scracthy tells me that one or more of your drivers are blown, the tweeter, midrange or full range drivers (speakers). have you swapped the leads @ the amplifier to see if the scratchy sound moves to the other speaker? if it does, your problem starts before in the pre-amp stage. if it is the same speaker you can isolate the problem by swapping indiviual drivers with the good speaker, or you can cover individual drivers to determine where the scratcy sound is coming from. it could be the surround ( the rubber or butyl material that attaches the cone to the frame) is rotted from age. which can be replaced
Apr 20, 2011 | Audio Players & Recorders
Distorted, scratchy sound with Toshiba Satellite
OK, I would restore or recover the computer to manufacturer's original specifications and automatic update to the latest sp3.
Then, I would reinstall your virus protection and see if it's better.
Jul 28, 2010 | Toshiba Satellite A105-S361 Notebook
Scratchy radio volume dial
Use an electronic contact cleaner. You need to shoot it inside the pot through the openings. Then rotate many times. This will remove oxidation on the contacts inside. If you don't use a contact cleaner, turn of f the radio and rotate many times the potentiomer left-right-left-right ...When you turn it on again, you will see the scratcy sound will be reduced but it will come back eventually. The more often you rotate, the less noise it will make. This is a very common problem, nothing to worry about.
Oct 19, 2009 | Audio Players & Recorders
Every time i turn the volume nobs i get a funny noise.
is it a scratchy noise??? if soo it means there is dust build up in the potentiometer and by turning off the amp and opening it up and spraying the pot's with contact cleaner will stop this.....if it is some other noise can you please describe it and i can let you know what to do to fix it
hope this helps thanks,ben
Aug 11, 2009 | Crown CE4000 2-Channel Amplifier
Kitchenaid dishwasher making funny noises while running
HI. this sounds like a busted impeller in the pump housing. there are two impellers. one for the wash and one for the drain. the drive shaft will strip the impeller center nut, causing this noise. I would inspect the pump housing for lose impeller action. replace the faulty impeller if found to be damaged.
Jun 11, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
1999 Chev. Monte Carlo steering wheel make's a scratchy slidding,
Either part you mentioned can cause this type of noise.
Apr 19, 2017 | 1999 Chevrolet Monte Carlo
STANDARD TV
thier is a loose conecttion located in tuner section.try to check your arial terminal, maybe its loose. or change your matching transformer. if you have any back ground in electronic repair,try to resolder components near tuner section specially AGC sections.
May 29, 2008 | Televison & Video
Over heating on corsica91
what kinda noise squilching pinging bubbling or what
Feb 07, 2008 | Lakewood Oil-Filled Electric Radiator...
No longer spinning/loud noise
Did all the standing water pump out?? If sou you may have broken a drive coupling
Jan 22, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
FLASH WON'T WORK, LENS MAKES FUNNY NOISE
search canon web site or repair shop in los angeles area.
Jan 14, 2008 | Canon PowerShot Pro1 Digital Camera
Alesis Multimix 12 USB 12-Channel Mixer Spdif System Logo
156 people viewed this question
Top Alesis Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Gil Shultz
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
