Question about Toshiba Satellite A205-S4617 Notebook
Toshiba satellite A205-S5847 booting problem
Hello there
My Toshiba satellite A205-S5847 when loading windows Vista Freezes with a Black Screen just when the Vista Logo is about to show, I cant find the Toshiba Disk that came with the Laptop, what do you suggest i do?
  • 2 more comments
  • jayera Jul 26, 2008
    is there a way i can download boot drivers online?
    no i havent..ok i'll try that.. Thanks
    Wheres the Graphic card how can i check it?
  • brucehathcoc Jan 09, 2009
    i need a driver for web cam for dummies sakar 4952
  • 4 Answers
Check your GraphicCard. Have you tried downgrading to XP and can you tell if you facing same problem?
Posted on Jul 26, 2008
Toshiba a205-s4707 will not boot windows from any location.
You didn't mention the DVD/CD rom? Shut down, unplug, remove battery, plug in reboot and try this procedure: http://www.ehow.com/how_5766144_restore-satellite-laptop-factory-disc.html
Dec 16, 2012 | Toshiba Satellite A205-S4707 Notebook
My Toshiba Satellite a205-s5814 turns on fine, but will not boot, I can get it to the boot screen where it shows the windows vista load bar, and then it passes that screen and stays on a black screen with...
it looks like windows is corrupt or your hard drive is faulty. if you have a recovery disc try using it to repair wondows. if that doesn't work you might need to do a clean install which means you'll lose your documents. if that still doesn't work it's likely to be your hard drive. even if you run a check disc on your hard drive and it passes that doesn't mean there isn't a fault with it
Jan 10, 2011 | Toshiba Satellite A205-S4777 Notebook
I have a toshiba satellite a205-4707 when i got it it would freeze at startup i had a ancient copy of xp pro sp1 i could only install with power cord unplugged.even after install if i plugged in power cord...
http://www.4shared.com/file/oE15gXll/killdisk_and_boot-cd-iso.html
get this from my shared drive(read instructions in there)
and wipe your disk clean (Warning...this process will make you lose all data on disk so be careful, if posible backup all critical data that you need)
once done install WinXP SP3(get a Windows XP cd from a friend or download a pirated copy from net) look for "WinXP SP3 piratebay" in google
when installing WinXP make more than 2 partitions (C, D, E)
Install WinXP in C
once done, let Windows boot and show Desktop
install WinVista or Win7 in D
use E for saving your critical data
Nov 29, 2010 | Toshiba Satellite A205-S4617 Notebook
Windows Vista Will not load correctly
sounds like you have some corrupted files in the boot sector. 2 options.
1. using a vista dvd: let it boot from dvd and when it is loaded select the repair my computer option. once you get up and running use malwarebytes and superantispyware to remove any nasty bugs that you may have caught.
2. using your recovery partition do a system recovery this option restores your pc back to when you bought it.
Aug 29, 2009 | Toshiba SATELLITE Notebook A205-S5813
Toshiba satellite a205-S5847 cuts off while working
You could have an overheating problem, The CPU shuts down when it overheats and the laptop won't bootup until the CPU has cooled down.
The overheating problems are caused by a faulty fan or the heatsink/fan assembly is clogged with dust which prevents proper cooling.
Check the fan to see it it spins freely, if not (it has a bearing problem) then replace the fan. Also remove and vacuum the dust off the fan and heatsink.
Aug 18, 2009 | Toshiba Satellite A205-S4617 Notebook
Recovery disk wont work because of preinst4.swm
you probably need a functioning Windows Operating system to copy the disk.
If you havent had it for too long, you could try sending it back to have the O/S and other original software reinstalled.
Jun 13, 2009 | Computers & Internet
Finger print sensor not working with vista in toshiba M200
here is the link :
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2211892&rpn=PSMC4U&modelFilter=M205-SP3018&selCategory=3&selFamily=1073768667&selModel=2211892|PSMC4U
Satellite A200-ST2041, A200-ST2043, A200-ST2042, A205-S4617, A205-S4618, A205-S4639, A205-S4638, A205-S4537, A205-S4557, A205-S5816, A205-S5814, A205-S5813, A205-S5812, A205-S5811, A205-S5810, A205-S5809, A205-S5806, A205-S5805, A205-S5851, A205-S5847, A205-S5843, A205-S5841, A205-S5835, A205-S5831, A205-S5825, A205-S6810, A205-S5823, A205-S5804, A205-S5803, A205-S5801, A205-S5800, A205-S7468, A205-S7466, A205-S7464, A205-S7459, A205-S7458, A205-S7456, A205-S7443, A205-S7442, A205-S4797, A205-S4787, A205-S4777, A205-S4707, A205-S5863, A205-S5859, A205-S5855, A205-S5853, A205-S5852, A205-S6812, A205-S6808, A205-S5821, A205-S5819, A205-SP5822, A205-SP5821, A205-SP5820, A205-SP5818, A205-SP5817, A205-SP5816, A205-S5000, A205-S5866, A205-S5879, A205-S5878, A205-S5872, A205-S5871, A205-S5867, A205-S5880, A205-S5861, A205-S5833, A205-S5864, A205-S4629, A205-S4607, A205-S4597, A205-S4578, A205-S4587, A205-S4577, A205-S4567, A215-S4697, A215-SP5811, A215-SP5810, A215-S48171, A215-S4817, A215-S4807, A215-S4767, A215-S4757, A215-S4747, A215-S4717, A215-S4737, A215-S5839, A215-S5848, A215-S5837, A215-S5829, A215-S5828, A215-S5827, A215-S6820, A215-S6816, A215-S7472, M110-ST1161, M115-S3094, M115-S3104, M115-S3154, M115-S3144, M200-ST2001, M200-ST2002, M205-S3207, M205-S4804, M205-S4805, M205-S4806, M205-S7453, M205-S3217,
Apr 02, 2009 | Toshiba Satellite Pro L300 Notebook
Problem with booting my A205-S4577 with the powercord on
Have you tried a new power AC/DC convertor ? make sure you have the correct spec...see manual for power adaptor needed. Cost less if you can get a loan of one. other than this i would be looking into checking the power jack. hope this helps
Feb 15, 2009 | Toshiba Satellite A205-S4617 Notebook
Toshiba Satellite A205-S4617 Notebook Logo
449 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
