Question about HP LaserJet 1320n Printer
Pcl xl error , subsystem:kernel, Error: Illegal tag
Hai
im using hp Laserjet 1320
it is connected in lan, in some of the sys when i give print
the error is printing in the page
PCL XL error
subsystem: kernel
error: illegal tag
operator : 0x1b
position : 6
plz give me solution to this problem
  • 5 more comments
  • shams2391 Jul 28, 2008
    I ha ve the same problem and we two person are using this printer and in both the places we receive the same message. We tried all our way and means but could not success. Please give your solution for this error to start the printer to work. I have changed the cable also but no way to recover.
    Shamsul Arifin
  • SOUTH CITY Sep 20, 2008
    i have also the same problem
  • Anonymous Nov 27, 2008
    PCL XL error
    subsystem: STATE
    Error: ILLegalAttributeValue
    Operator: SetCLipReplace
    Position: 432
  • sira786 Dec 12, 2008
    subsystem:kernel,
    Error: Illegal tag
    operator:0x1b
    position:6
  • ilyasraj Dec 16, 2008
    yes i've same problem
  • Anonymous Jan 18, 2009
    PCL XL error
    subsystem: kernel
    error: illegal tag
    operator : 0x1b
    position : 6
    softex@eim.ae
  • mamiumras May 05, 2009
    Please describe the specifics of your problem below. We'll add your post as a comment to aazeez's "pcl xl error , subsystem:kernel, Error: Illegal tag" problem, and notify you when a new solution is offered
    muhamed abdulla
Change paper to plain instead of UNSPECIFIED in the printing properties. The printer hates the UNSPECIFIED setting.
Posted on Apr 01, 2010
Pcl xl error
subsystem : kernel
error : illegal tag
Operator : 0x1b
position : 6
Please help me in this problem
E-mail: benfaleh@hotmail.com
Posted on Nov 13, 2008
    Scholar:
  • 59 Answers
Try this resolutions....
When you try to print a document or report using an HP Laserjetprinter, an error message similar to the one given below may print out:
PCL XL Error
* Subsystem: KERNEL
* Error: IllegalOperatorSequence
* Operator: SetColorSpace
* Position: 52
Cause of the Error
This error occurs due to a problem with the HP LaserJet PCL XL Driver.
Resolution Method
The following are some of the methods that you can use to workaroundthe problem and resolve the issue. After implementing each workaround,try to print your document again to see if the issue has been resolved.
Method 1: Directly Connect the Printer
Most commonly, LaserJet printers are accessed over a network. Toworkaround the issue, you may try to connect your PC directly to theprinter using an IEEE-1284 compliant cable.
Method 2: Disable High Speed and Advanced Features
Use the Control Panel that exists on your LaserJet Printer to disable the High Speed and Advanced Functions. To do this, you need to perform the following tasks:
  1. Display the I/O MENU by pressing the MENU key in the printer display.
  2. Now, press the ITEM key until you see Parallel High Speed = Yes.
  3. Now, press the VALUE key to change the value of Parallel High Speed to No. (Parallel High Speed = No)
  4. Press the SELECT key and ensure that an asterisk is displayed next to the Parallel High Speed = No item. (Parallel High Speed = No*).
  5. Next, press the ITEM key again until you see Advanced Functions = On in the printer display.
  6. Now, press the VALUE key until the value changes to Advanced Functions = Off.
  7. Press the SELECT key and ensure that an asterisk is displayed next to the Advanced Functions = Off item. (Advanced Functions = Off*).
Method 3: Update your Printer Driver
The PCL XL error may occur if one or more of the required driverfiles are missing from your computer or are outdated. In this case, youmay visit the HP Website for the latest driver updates, download them,and update the existing driver files.
Method 4: Use another Printer driver
If the problems with the PCL 6 driver continue to occur, remove itfrom your system. After removing, install the PCL5 printer driver thatis shipped with your HP LaserJet Family Printer. If this driver is notavailable, use the latest preinstalled driver that is available on yourWindows computer.
Note: You may use a good registry cleaner, such as RegGenie to clean your registry and ensure that the uninstalled driver does not leave behind any orphaned registry entries.
Method 5: Remove additional memory chips
If you have added any memory chips on your LaserJet printer, try toremove these additional chips to see if that solves the problem.
I had the same problem with pcl 6 driver I tried using other driver such as PCLe i managed to print but with no table lines so how using a different driver such as PCL not PCLe or maybe try to find some update or maybe reinstaling the driver again.
Posted on Jul 30, 2008
PCL XL error while printing through LAN in HP 1320n printer
Posted on Oct 25, 2008
2 Suggested Answers
Nikhil Gedam
  • 87 Answers
SOURCE: PCL XL error
Please uninstall the current PCL driver and upgrade the same with UPD PCL5 (dont install PCL6) from http://www.hp.com/go/upd
Regards,
Nikhil
Posted on Sep 17, 2009
Since I installed another printer, my hp 1320 starts printing these lines: PCL XL error Subsystem: KERNEL Error Illegal Tag Operator: 0x1b Position: 6
Okay, a hex (0x1B), that's a hexadecimal number is defined by the 0xYY signature.
What you are looking at is a Hex IB, That is the escape code for earlier editions of the HP Command set.
More that likely, all you need to do is to change the driver properties to Pcl5e to fix your problem.
Right now, the printer is expecting a PCXL command set and it is receiving a PCL5e command set.
Don
Dec 11, 2009 | HP LaserJet 1320 Printer
Pcl xl error subsystem: kernel error: illegal tag operator: ox1b position: 6
If you are using Windows 2003 Server and/or Windows XP Client machine and if you hace installed PCL 6 Driver than printer will print pcl xl error while printing.
To fix this problem user need to install PCL 5 Printer driver or Universal printer Drivers from the Link mentioned.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1845552&prodTypeId=18972&prodSeriesId=1845551&swLang=8&taskId=135&swEnvOID=228
Jun 29, 2009 | HP LaserJet P2015 Printer
Pcl xl error kernel illegal tag 0xlb 6 HP 3050
Re install the driver for the printer or the best thing is format the system
Jun 19, 2009 | HP LaserJet 3030 All-In-One Printer
Printng error
Please change the driver to UPD (http://www.hp.com/go/upd) to PCL5
This will solve the issue
Rgds,
Nikhil
Jun 14, 2009 | HP LaserJet 1320n Printer
PCL XL error
Regards,
Nikhil
Dec 16, 2008 | HP LaserJet 1320n Printer
Printing problem with HP laserjet 1320
Hope this helps you troubleshoot it.
Link
Regards.
Nov 18, 2008 | HP LaserJet 1320n Printer
Printing problem "PCL XL error"
Dear Sir
My printer is laserjet 1320
PCL XL error
Subsystem: KERNEL
Error: Illegal Tag
Operator: 0x1b
Position: 6
Pls. This problem solution give me.
May 29, 2008 | HP LaserJet 1320n Printer
Printer error
Hi there guys reinstall the driver using PCL 5e as the program you are using may not understand the PCL 6 newer driver. Try this
Hope it helps
Thanks J
Nov 14, 2007 | HP Color LaserJet 3500 Printer
HP LaserJet 1320n Printer Logo
30,626 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
