Biostar A880G+ AMD 880G Socket AM3 mATX Motherboard w/HDMI, DVI, Video, Audio, GbLAN & RAID (A88PCM3SR01) Logo
Anonymous Posted on Feb 19, 2011
This is my first build and fired it up but no display on monitor. Neither hdmi or VGA. what could i be missing?
Anonymous
Level 3:
  • Master 731 Answers
  • Posted on Feb 19, 2011
Anonymous
Master
Level 3:
Answers
731
Questions
0
Helped
321103
Points
2181
Check to see if the red jumper for the Bios is jumper to the normal two pins 2-3 and the board like this ram 1Gb OCZ Platinum DDR3-1333 make sure they are plugged in tight. Make sure the video is plugged in tight if you are using external video.
  • Anonymous Mar 05, 2011
    I have a system i just got in for repair and the CPU over heated and is cooked and there is no hard drive light or video but the hard drive is ok and everything else is ok. if your board doesn't beep on start up check the CPU.
Can you connect monitor AOC HDMI DCR 20000:1 old with desktop Medion Akoya P5138D new?
GEE YES, ANY PC CAN HAVE NEW MONITOR ANY CAN,
IS THIS A PRE SALES QUESTION OR WHAT?
IF BOTH PC/MON ARE IN FACT HDMI ?
WE DO NOT KNOW HOW YOU USE A PC EVER. AND MATTERS TOO.
1: EMAIL, CRUISE WEB ONLY?
2; WATCH STREAMING 4K VIDEOS AT NETFLIX.?
3: OR PLAY AAA NEW $70 GAMES, ON STEAM.?
what stops you>? from trying? it will not catch fire tired,
no monitor told at all , vast models 1979 to now.
VAST SOLD AND VAST HMDI AND VAST PERFORMANCE DIFFERENCES AND MAXIMUM RESOLUTION LIMITS.
ALSO A TV CONNECTS TO ANY HDMI PC. BUT IS SLOW THE SCREEN IS FOR PC WORK AS SOME COMPLAIN.
I am not sure how to connect my gifted LG 295 LM Monator to my PC
so it has power ?
is p.c ?vga display output ?
https://en.wikipedia.org/wiki/VGA_connector
is monitor vga input ?
or is p.c only hdmi output ?
https://en.wikipedia.org/wiki/HDMI
if vga on both you need a vga cable
if hdmi on both you need a hdmi cable
if pc is VGA and the monitor is hdmi then an adapter is needed
if p.c is hmdi and monitor is vga then an adapter is needed
suggest figure out video cable standards and then decide on what you need
as shop will need to know what standards are used VGA or HDMI ?
How do i fix when i hook up hdmi cord and the screen wont display and when i hook up vga it does but i want hdmi for my ps3?
You must have to make setting in your ps3 and Display device. Set the display device at auto option for input source. It may be set at VGA. that why you get output of VGA but it does not display output from ps3
Monitor vga connection hdmi
You can check these:
1. Connection: Make sure that both ends are connected properly,
2. Monitor: Most newer monitor has 3 options: VGA or DVI or Automatic. Test the "Automatic" and "VGA" options.
3. Cycle your display option using your laptop keyboard (Alt + F4). Please tap the F4 several times (to change the option to Mirror, Laptop Display only, External Monitor only)
Unlock password
How about looking at a screen?
Use an external monitor
Briefly;
Your laptop has an external display device port. (Connector)
I do not know what it is, because you didn't state the laptop manufacturer name, and model number; Elizabeth
It may be a VGA port, or HDMI port, or Mini-HDMI port; or DVI port
http://en.wikipedia.org/wiki/VGA_Connector
(Scroll down for VGA Cable example)
http://en.wikipedia.org/wiki/HDMI
(You can click on any photo, and it will enlarge)
http://en.wikipedia.org/wiki/File:HDMI_Connector.jpg
http://en.wikipedia.org/wiki/Digital_Visual_Interface
Laptop OFF, monitor OFF, connect the external display device to the laptop.
(VGA = Monitor. DVI = Monitor. HDMI, and Mini-HDMI usually = HDTV. They all compromise an external display device)
Turn the monitor/HDTV on.
Turn the laptop on.
By factory default settings, the display should show on the external display device.
IF not;
There are at least 3 display options. For this example I'm going to use a VGA monitor.
(For a VGA monitor you can use a CRT type of monitor. Looks like a small TV. Or you can use a flat LCD screen monitor, if it has a VGA Cable attached)
The basic 3 display options using a VGA monitor are;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Hold the Fn key down, and at the SAME time tap once on the Display Toggle-Over key.
Which key is that? Dunno. Laptop manufacturer name, and ......................
It will be one of the F keys at the top. F1 through F12.
The Function key will have a monitor icon on it, and usually an arrow on one side........Or perhaps two monitor icons sitting side by side.
(Empty rectangle is a monitor icon)
Still no display on external display device?
Hold the Fn key down again, and tap once more on the Display Toggle-Over key
[If memory serves for Display Toggle-Over key;
HP = F4
Acer = F5
Toshiba = F5
IBM/Lenovo = F8
Don't write that in stone, however.......]
Once you post the manufacturer name, and model number; then I can guide you step by step.
Post back in a Comment.
Regards,
joecoolvette
1helpful
2answers
How do I hook a an external monitor up to a hp dv6 1355 with a cracked screen?
http://h10025.www1.hp.com/ewfrf/wc/product?product=4043282&lc=en&cc=us&dlc=en&lang=en&cc=us
Product information > Product specifications > Product specifications;
External Ports:
1 VGA (15-pin)
Manuals > Notebook Tour - Windows 7;
Left-side Components - External Monitor Port
Left/Rear side of laptop,
http://en.wikipedia.org/wiki/VGA_connector
You can use a CRT type of monitor (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
(You can also use an HDTV if it has an HDMI port, and you have an HDMI cable. The HDMI port is on the Left side of the laptop, too.
{Don't buy an HDMI cable that is expensive. Just a waste of money.
Those gold plated parts are just a little bit better, than an HDMI cable that doesn't have it. $20 for an HDMI cable is PLENTY. (12 Feet) I use one's that cost less )
A) Laptop OFF, monitor (External display device) OFF.
Connect the VGA monitor to the VGA port, on the laptop.
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
There ARE at least 3 display options available;
1) Internal monitor ONLY
2) Internal monitor AND external display device (VGA monitor in this example)
3) External display device ONLY
Press, and hold the Fn key down, tap once on the F4 key.
(The F4 key is the Display Toggle-Over key)
Wait a few seconds.
Still no?
Hold the Fn key down again, and tap once more on the F4 key.
For additional questions please post in a Comment.
Regards,
joecoolvette
I have a 24" aoc 2436Vh display and a new 15"
I purchased the AOC 2436Vh display yesterday. To get my MacBook Pro to work with it I purchased Apple's Mini DisplayPort to VGA Adapter. Since the monitor comes with the VGA cable, all you need is the adapter to plug it into your MacBook Pro. It works beautifully and set up is easy if you know your way around the Mac. Although the HDMI works perfectly with my PS3, I strongly recommend the Apple Mini DisplayPort to VGA adapter. I hope this helps.
2helpful
4answers
Can i connect a dvid cable from the monitor to my flat screen tv hdmi to watch videos from my computer? Thank you Martin
the Flat Screen TV if has, a HDMI input, also has VGA Input.
You must choose :HDMI or VGA, if HDMI The VGA board must Have HDMI Connector, and you connect a HDMI cable to the TV.
The HDMI is a digital signal input/output, VGA is Analog Signal. You must have Signal Converter if you Use the 2 signals
ATI Radeon HD 4350 will not display red.
It could be a problem with the monitor cable.
Try unplugging and re-plugging the PC to monitor cable (VGA cable)
If possible, Use a different monitor to ensure that your video card is working fine.
Hannspree 22" wide monitor won't recognize hdmi to dvi cable connection
First, fire up monitor in VGA. You can then use the monitor menu to select the hdmi instead of vga. Restart andf it should work Ok.
Top Biostar Computers & Internet Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
