Question about Denon AVR-2500 Receiver
Denon avr-2500 left main speakers very quiet.
Just bought this gorgeous receiver at a yard sale - they said it worked perfectly - it does everything great EXCEPT the left main speakers, front and rear are almost silent. The volume control works but it's 1/100th the volume it should be. All other speaker outputs work fine. I've got no documentation, but I do have tools, a dvm, and a soldering iron, so if somebody knows why this channel seems to be only preamped, or how to further t-shoot it, I might be able to fix it. Thanks in advance for your help!
  • Anonymous Jan 04, 2009
    i piked mine up at good will . all 4 speakers seem to be preamp
  • 3 Answers
The Denon 2500 was one of the best ProLogic receivers built, it was a work horse and very little ever went wrong with them.
To make sure you're only supposed to hear right & left speakers, press the Stereo button on the remote. Also recheck your speaker connections - this is the single most overlooked connection problem folks have.
Check the balance control to make sure it's in the center position
Make sure the Tape Monitor is not engaged.
Then, check to make sure that the Pre-Out, Main-In jumpers are connected properly on the rear panel.
If that is not the problem, try pressing the Tone Direct button on the remote (aka Tone Defeat on the front panel).
Posted on Oct 22, 2009
Front speakers 5.1
Turn up the volume on the left or right speakers or turn down the center channel volume to meet your preferences. There should be a setting for that in most receivers.
Jan 17, 2014 | Pioneer VSX-454 Receiver
I have a Yamaha RX-V2092 with a 7 speaker set up. Purchased new. Everything has worked great until recently. Now the center channel speaker, left front effect speaker & left main speaker short off...
It seems that the main sound processor comes into an error and so seems a fault on the board. Since checking for a component level solution is very tricky as the access is not friendly, what could be done initially is to remove and reset the boards, check for faulty connectors that seems to vibrate and bring in these faults. Check the solde joints of the connector pins on the board. Check and solder the processor IC and the allied circuits. If the fault seems to disappear when the set heats up then you must check using a magnifier.Check the solder on the audio driver outputs of the center, main , front and rear are clean.
If not refer and proceed with consensus as a false move can cripple the set.
Oct 28, 2011 | Yamaha RX-V2092
Front-Right Speaker Not Working
I would have a look inside, it might be a bad soldering joint that got disturbed in the move. When you get inside follow the wires from the Front-Right terminal.
Apr 05, 2010 | Sherwood RVD-8090R Receiver
I bought a used Denon AVR-1400 without the remote. I am able to control everything from the face except switching to front b speakers. How do I switch to b? I have tried every button on the face and have...
There is no capability to switch to front "B" speakers, the second "front" speaker output allows for bi-wiring a single pair, or running two speakers with identical outputs.
Sep 04, 2009 | Denon AVR-1400 Receiver
Only Left Speakers Work
CHECK THE MENU,,SETTUP ,,NO RECIEVER NEEDEED,,IF NOT CHECK THE RAC JACKS
May 14, 2009 | Pioneer VSX-D511 Receiver
Left channels not working
Check out the left channel amp stages - your issue is there.
Apr 30, 2017 | Yamaha RX-V395 Receiver
No sound out of right main when watching DVR/TV or VHS
When watching TV or VHS the sound should be stereo and therefor come out of the the 2 front speakers. I suspect you now have sound out of the left front and the center speaker which indicates you connected the center speaker to the right front speakerterminal and the right front to the center terminal.
Just check if all speakers are connected to the correspondent speakerterminal.
If this is correct and the problem persists, try to connect another speaker to the right front terminal to see of the terminal or speaker is not working properly. If another speaker does work on the same connection, your right speaker might be damaged which might not be heard when listening to 5.1 because of the surround sound.
Mar 15, 2009 | Yamaha RX-V663 Receiver
No sound from all speakers except front left and front right
Check the cables from the DVD to the Amp and make certain your in Dolby Digital mode on player.
Jan 24, 2009 | JVC TH-G30 Theater System
Onkyo Tx-SR55
did you swap the left from speaker with the left front?
if still crackels after that them you have bad left output.
Jan 09, 2008 | Onkyo TX-SR500 Receiver
Sony CDX-M8800
hi i had that problem and changed the ribbon and my front was dead
Sep 24, 2007 | Sony CDX-M8800 CD Player
555 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
