Question about Jenn-Air 24 in. JDB8910 Built-in Dishwasher
Jennair dishwasher jdb8910aww
Dish washer not drying dishes bad smell after load is finished
    Problem Solver:
  • 14 Answers
Start by puting timer in heat dry for about 4 seconds and see if element got warm. If so check you rinse aid and make sure it is full. I like the turbo dry made by jet dry. If it is empty, this is your problem. about the smell, you would use a cleaner such as diswasher magic made by GE. If element did not get warm, put unit on heat dry and and test voltage at the element. 120 volts present replace element. if not check voltage at thermal fuse for 120 volts. If no voltage there replace timer.
Posted on Jul 26, 2008
Why does my dishwasher smell bad?
Clean it well after each use. Chlorinate it.
Aug 17, 2014 | Dishwashers
What causes grit to dry onto dishes after dishwasher has finished?
Check water hose leading to the dishwasher for deterioration..
May 11, 2014 | LG LDF6920ST Stainless Steel 24 in....
When we open dishwasher theres standing water in the drain area and it smells bad this is after washing aload dishs look clean but inside stinks
After you run a load of dishes put 1cup of CLR or vinegar (white) and run a quick wash.no dishes,after running dishes clean out spray arm and clean strainer,use a rinse agent like finish, and spray off dishes before loading.About 35yrs. ago I use to be a dishwasher as one of my first job's and if you did'nt spray the dishes and scrap them off before loading,the dishes would not come out clean,And after each shift the dish washer would be cleaned out.
Aug 04, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishes are not drying
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Jul 12, 2010 | Electrolux 23 in. ESL6114 Built-in...
Drying problems
Check the front control panel for a AIR DRY / HEAT DRY switch. Perhaps the switch is in the AIR DRY position. If so and you really want to HEAT DRY your dishes, set the switch for HEAT DRY.
Second, it is not a bad thing to let your dishes AIR DRY. It saves money! Just open the Dish Washer door after the last rinse cycle has finished and let the dishes AIR DRY manually. In a hour or so they can usually be put away.
You can also check for the heating element.Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element. Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thank you!
May 14, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
My dishes still come out wet..how do i set the washer to dry the dishes
there should be a setting or a button to turn the heat dry on and off, if it is on and dishes are not drying then the next time you do a load of dishes pay attention to the cycles, after the rinse cycle is complete the heat should come on. if not you could have either a bad heating coil or a bad relay.
Aug 20, 2009 | Kenmore Dishwashers
Bad smell
Try running washer empty with soap or tablet in the regular cup and baking soda in the secondary cup. After cycle is complete and somewhat dry inside leave slightly open to allow air circulation overnight. This should help.
Sep 15, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishes are not coming out fully clean
first if the pump is running and you can hear it washing it should clean now hot water cleans dishes not the washer the hotter the better at least 130-135 degrees modern dish washers use less water than older models so if you don't get the water as hot as you can stand it at the sink before you turn the washer on you can fill it with cold water second its important that you use jet dry and if your dishes aren't dry at the end of the cycle then on most washers you can turn the disp up for more hope that helps let me know
Dec 01, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwasher
get valves on both cold and hot water coming into the dishwasher, I would first turn the cold all the off and the hot midway ....now try it. ps: it might only have a hot coming in. if still problems keep turning that hot down perhaps too much hot water is all i can think of. good luck
Aug 31, 2007 | Kenmore 18 in. 14432 / 14439 Built-in...
My Dishwasher does'nt dry my dishes.
How old is the dishwasher? Check the front control panel for a AIR DRY / HEAT DRY switch. Perhaps the switch is in the AIR DRY position. If so and you really want to HEAT DRY your dishes, set the switch for HEAT DRY. Otherwise: Second, it is not a bad thing to let your dishes AIR DRY. It saves money! Just open the Dish Washer door after the last rinse cycle has finished and let the dishes AIR DRY manually. In a hour or so they can usually be put away. Works for me :)
Nov 30, 2006 | Frigidaire 24 in. FDB510LC Free-standing...
Jenn-Air 24 in. JDB8910 Built-in Dishwasher Logo
391 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
