Question about Pioneer PRO-520HD 53" Rear Projection Television
BRIGHTNESS ON A Pioneer Pro-520HD REAR PROJECTION TV
I have one of these TV's, but the picture is too dark. How can I get it to display lighter?
  • 3 more comments
  • dwain603 Jul 26, 2008
    There is no "Brightness" setting on the menu of this TV
  • dwain603 Jul 27, 2008
    yes, I have tried all the menue menu video settings, but brightness is not one of them. The closest I come to actually lightening faces, is to increase the back level, believe it or not., but they are still often too harsh/dark.
    I think it may have been this way since I got it. It got worse until I adjusted it, but still shows darker faces (with more contrast) other TV's
    Yes, I bought it new not long after this model was released. Don't remember how long that was (4 or 5 years?)
    I'll give Pioneer a try
I would like to by a new tv pioneer 520 hd because my wall unite custom made and i need to have same screen
Posted on Nov 29, 2008
  • 4,472 Answers
Have you attempted to adjust the brightness setting?
Thanks,
Lee
Posted on Jul 26, 2008
  • 4 more comments
  • Lee A.
    Lee A. Jul 26, 2008
    Have you tried adjusting any of the video settings?
    Thanks,
    Lee
  • Lee A.
    Lee A. Jul 26, 2008
    should be located in the menu.
  • Lee A.
    Lee A. Jul 27, 2008
    has it always been like this? How long have you owned the unit? How long has it been doing this?
    Thanks,
    lee
  • Lee A.
    Lee A. Jul 27, 2008
    How long ago did you get it? Did you buy it new?
    Thanks,
    Lee
  • Lee A.
    Lee A. Jul 27, 2008
    and has the picture been like this since you purchased the tv? What are the lighting conditions in the room? My first suggestion would be the bulb itself. I would contact pioneer for the nearest authorized service center.
    (800) 421-1404
    Mon. - Fri. 9:00 a.m. - 7:30 p.m. Eastern (all product inquiries).
    Sat. - Sun. 11:00 a.m. - 7:30 p.m. Eastern
    you can contact them directly, Depending on what they say you can also contact a local repair person. You can find those by entering your zip code in the repair service box located on www.fixya.com
    Hope this helps,
    Lee
  • Lee A.
    Lee A. Jul 28, 2008
    Feel free to keep me updated as to how it is going, or if you need any further assistance. Also if you have a moment to accept and rate the solution I hope you at least found my information helpful.
    Thanks,
    Lee
Red light on back of pioneer pro-520hd
The most common issue on this model is the power board develops all kinds of bad solder connections--have to remove and in most cases hand solder the entire board.
Dec 16, 2012 | Pioneer PRO-520HD 53" Rear Projection...
Dim/dark Picture
The model indicated here is rear projection that uses three picture tubes.
If rear cover is removed--can be done by removing entire front screen but there are hazards like damaging the screen---with rear cover removed clean the lens in the three round cyclinders which point up and are hard to miss===
They are the light source for the picture---there is if you look up inside and to the rear a mirror but unless grimy it rarely needs cleaning.
clean the lens with a lens cloth or even a paper towel with glass cleaner sprayed on the towel.
Jun 12, 2012 | Pioneer PRO-520HD 53" Rear Projection...
Can this be connected to Apple TV?
through HDMI it should be able to im not sure but you can go to
www.google.com
search-the name of your (tv-Pioneer PRO-520HD-specs) the specs should let you know if you can or can't but most likely you should be able to
Jan 08, 2011 | Pioneer PRO-520HD 53" Rear Projection...
Picture has a red hue to it. I have checked the convergence and the lines up and stays put. The TV was working great when I turned it off and when I turned it back on this condition was present.
The problem could be a few things, check your color balance and contrast or try adjusting the guns. If its a fuzzy red haze, kind of like a halo around things, it may just be that the crt coolant fluid needs changed. I, myself, have had a problem with the tinted halo in my rear projection Toshiba tv, I replaced the crt coolant fluid and the picture returned to good as new.
May 15, 2010 | Pioneer PRO-520HD 53" Rear Projection...
Pioneer Elite Pro 620 HD TV on several occasions the screen has gone black but sound continues and the power green libht remains on. After shutting down for 10-15 minutes picture comes back.
Pioneer Elite Pro rear projection 620HD - Picture is still there but brightness and "white" have faded over years allowing for mediocre viewing when room is dark only. During the daylight picture is visible if viewed straight on and within 15 feet from set. Any suggestions?
Oct 16, 2009 | Televison & Video
Colors are skewed on Pioneer Pro-520HD
you can replace your the convergence chips on the convergence board. The board is to identify because it has a large heat sink. The convergence chips normally starts with STK... After you find the chip, you can buy online (ebay has a lot of listing) and costs around $10. If you know how to solder, it is very easy to do. I just replace the convergence chips on myPRO-610HD and it works perfectly.
Feb 20, 2009 | Pioneer PRO-520HD 53" Rear Projection...
Is the RGB computer-like jack at the rear of the Pioneer PRO-520HD projection TV a digital input like a DVI input? I'm trying to use the TV for BluRay discs. Chris Fox
The RGB input is like a computer monitor input, and may handle HD. I would recommend using component video instead for ease of use, but also most TVs will only handle a couple resolutions, but your component jack should handle 480i, 480p, 720p, and 1080i giving you flexabilty and a comprable picture.
Dec 06, 2008 | Pioneer PRO-520HD 53" Rear Projection...
Pioneer tv
you may have problem with convergence IC is shorted and goes in protec mode
Oct 02, 2008 | Pioneer PRO-520HD 53" Rear Projection...
TV not working
need mor info the tv when turn on after 15 or 30 minuts works fine ?
Mar 21, 2008 | Pioneer PRO-520HD 53" Rear Projection...
PRO-520HD Tv will not stay on
you may have short in convergence circuit but this is a job for experienced tech after replacing ic's need to get in to settings and and is kind of complicated
Mar 18, 2008 | Pioneer PRO-520HD 53" Rear Projection...
Pioneer PRO-520HD 53" Rear Projection Television Logo
323 people viewed this question
Top Pioneer Televison & Video Experts
Electro Med Services...
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
