Home | RCA | F31317 31" TV | RCA ctc203ca6 model f32...
RCA F31317 31" TV
Problem for RCA F31317 31" TV
RCA ctc203ca6 model f32649
By electronictv on Jul 26, 2008
Turning on it self, also when the tv is on, and you touch any botton of the remot control, the tv turning off
Comments:
Jul 29, 2008
- I've found the problem, in the siwcht sistms, somes of the channel, up, and down, button in the Tv was broken
Jul 29, 2008
- I' ve found the problemn, and I fixed, in the switch sistems, channel, up, channel down, volumen up, volumen down, in the tv, I remove the button, change some of those, and the Tv was fixed
Solution #1
posted on Oct 08, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
the front panel assembly is rca part # 237420
I assume your chassis is a CTC203
Un plug the fpa and see if problem still acts up
you may not be able to find one
then try replacing the sticking buttons on it
Popular Solutions for RCA F31317 31" TV
Questions and Unsolved Problems for RCA F31317 31" TV
Do you recommend RCA F31317 31" TV?
Answer
Answer
My RCA Model F31317 has intermittent picture display. The sound works but the picture will cut out... (More)
Answer
my sat went out and during the reset process I lost picture. just snowy static screen. still plays... (More)
Answer
my tv will not recinize when a cable box is hooked up to it. it keeps asking for a G-link for the... (More)
Answer
picture on my rca f31317 seems darker than normal, have adjusted to the brightest setting. any... (More)
Answer
changes channel down on it own nonstop
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For RCA F31317 31" TV:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
