Question about Friedrich Heating & Cooling
Hi i have a friedrich model rm18j30-3 ac. the problem i am having is the fan does not turn on when i switch to hi/med/or low ac the compressor kicks on and the front of the ac get cold but no air blows out. and when i put it on fan only nothing happens.....is this a cheap fix? and can i fix it my self?
    Sergeant:
    Champion:
  • 330 Answers
The switch is out of order. if yopu know, go to the junk yard get a used one put in, the part which you get must be same as yours.
Posted on Jul 26, 2008
How to trouble shoot heat/ a/c fan switch.
Will your blower fan kick on in the medium position by chance? Med/ med high..if it is a 4 position switch, does it operate in the number 3 position? If so it is probably your blower motor resistor. If not, I would test the blower motor itself. Since the compressor kicks on when you turn the fan on, I would think the switch is working.
Jun 11, 2015 | 1991 Toyota Camry
Friedrich xq08m10 - f2 and f3 fan speeds reversed
Unplu cord and remove front panel. Then remove electrical box, you should be able to find the blower motor leads.
Black is usually- hi speed motor
Blue or Yellow is- Medium Speed
Red is- low speed
Just exchange the wires to match the dial
Jun 14, 2010 | Heating & Cooling
Air conditioning stopped working , no compressor kicking in
try the fuse,then the relay,then the wire going to the clutch on the compressor
Apr 06, 2010 | 2006 Jeep Liberty
Rear AC fan will not run in lo med or hi, switch or is there resistors on the fan that need checked?
When a blower motor does not turn on in low or med. and only turns on high its usally a resistor block. If nothing works it is most likely the bolwer motor itself or a fuse.
Feb 28, 2010 | 2001 Chevrolet Suburban
Ac compressor wont click on my friend said that there is a sensor next to the starter he said to pull the wires off of it and jump it if it clicks on the sensor is no good if it doesnt the compressor is...
When you jump the switch all you are doing is forcing the compressor to kick in and work. It could be low on freon which will also keep it from kicking on which in that case you need to have it charged so does not mean your "sensor" (switch) is bad or that your compressor is bad.
Oct 21, 2009 | 1998 Chevrolet Lumina
1995 Chevy 1500 ac problems
replace the fan 'resistors" near the fan under the hood they are under a cover and, are marked Hi,Low.Med(ium)
Aug 28, 2009 | 1995 Chevrolet K1500
Ac fan will not work on low or med only on
It may well be the fan switch is defective
Jul 27, 2009 | Heating & Cooling
2004 Chevolet Silverado blows hot air and snowflake button blinks when pressed
Blinking or chattering of the compressor clutch usually indicates low "freon" charge.
Jul 09, 2009 | 2004 Chevrolet Silverado 2500HD
2003 dodge grand caravan ac recharge
you should be adding the 134a to the system the low pressure switch is doing its job by not allowing the compressor to kick on, it wont kick on until there is enough 134a in the system to be above the preset pressure for the low pressure switch.
Jun 27, 2009 | 2003 Dodge Grand Caravan AWD
Heating & Cooling Logo
253 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
