Try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines. don
dust causes static which causes lots of problems with a computer and its parts
or if this does not fix the problem
click start control panel keyboard you can change your settings there
or you might have uninstall the keyboard restart your computer then reinstall it and its drivers
click start control panel administrive tools computer management device manager scroll to keyboard you might see a yellow question mark ? right click update driver
if your computer came with a motherboard disc the drivers could be on it
hope this helps
I would recommend making sure the keyboard is connected to the proper connection on the pc. If it is, check to make sure you have no POST error when the pc reboots. (Most times your pc will halt if no keyboard is detected.) If you get no error after the reboot and your connections are correct, you will need to get a new keyboard.
PS - Make sure you 9 pins in the connector of the keyboard connection. (Look at the end that plugs into the pc you can see the pins form a semi-circle.
Good Luck
C2Solutions
