Question about E-Machines eMachines Desktop PC
Computer bios seting
How can i get bios seting & trubleshuting
  • hirenck Jul 28, 2008
    beep beep gape beep post gating only what problem
  • 163 Answers
Depending on the BIOS it may be "F1". When your computer boots, watch the bottom of the screen for "Press [xx] To Enter Setup." Depending on your OS there is not much you should change in BIOS and very little (if any) troubleshooting. MM85
Posted on Jul 26, 2008
    Novelist:
    Scholar:
  • 141 Answers
Try restarting the computer. As soon as it shuts down start tapping the "Del" key continuously. It has to be before the beep if you get a beep, and before any boot up screen appears.
If this doesn't work try in the same manner tapping F2,F8 or F12.
Try going on the web to Emachine site and do a search for that question.
Good-Luck
My computer wont turn on lights up but wont turn on
What did you do in bios ?
You might have to go back into bios and set fail safe or optimized defaults.
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart. Hope this helps.
Dec 22, 2012 | Abit AS8 Motherboard
When i boot my computer it says a problem with the hard ddrive has been detected.
problem with the hard ddrive has been detected.thn
check bios seting boot frm hdd ,check hdd connection
Feb 12, 2011 | Gateway GM5626 PC Desktop
When i start PC; BIOS seting opens and says clear
  1. pls read the user manual first to identify which pinds of password jumper to normal position
  2. Reinstall the jumper in a different position. For example, if you removed the jumper from pins 2 and 3, reinstall the jumper over pins 1 and 2.
  3. Replace the computer cover and reconnect the power cable and monitor.
You can now assign a new system and/or setup password. For more password information, refer to the Passwords section of your computer'sservice manual.
Aug 23, 2017 | Intel D102GGC2 Motherboard
I am not able to install windows xp operating system ?
WHEN YOU SAY YOU CANT INSTALL WHEN YOU START YOUR COMPUTER UP AND IT STARTS TO BOOT RPESS THE DELETE KEY THIS WILL GET YOU INTO THE BIOS SETINGS GO TO THE BOOT SETTINGS AND DEVICE PRIORITY SELECT YOUR DVD/CD DRIVE WITH THE WINDOWS DISC IN THEN F10 TO SVE THE SETTINGS AND EXIT WHEN YOU R COMP RESTARTS IT WILL BOOT TO THE DISC DRIVE AND WINDOWS SHOULD START UP.. IF IT DOESNT GO THROUGH THE PROCEEDURE AGAIN AND JUST MAKE SURE THE BOOT SETINGS ARE SET TO THE DISC DRIVE FIRST SETTING.. GOOD LUCK
Jun 24, 2009 | ASUS K8V-MX Motherboard
COMPUATER REBOOTS AFTER SHUTDOWN
on booting pres del and on bios try to put on factory setings it helped on my mobo
Jun 15, 2009 | Computers & Internet
Install Vista on cq40-144tu
Take out the hard disk put it on the externaslcase hard disk and format the disk wipe all data from it , and chek the bios seting, put the bios on default seting than you will be able to instal wich OS you want. chek if you have enogh ram for vista , if no put XP not vista. wen you will have more than 1GB  put vista.
Jan 20, 2009 | Compaq Presario Notebook
My Motherboard running but no beep no display of bios how can I solve the problem
refix your ram after clean it.also reset your bios setings .put your cmos cell for 15 minutes away from other bord.
also u can reset your bios setings with jumper setings.it is nearly cmos cell or corner of the motherbord put in 1-2 position then power up the cpu then refix again to its original position.
Dec 29, 2008 | Intel D946GZIS Motherboard
How to enter setings bios in Compaq Model:Armanda 1592 dt
Erini,
While the "Compaq" logo is onscreen at boot up, press the <Delete> key three times quickly. This will get you into the Bios for your computer.
Thanks
Dave
Dec 11, 2008 | IBM NetVista A40 PC Desktop
Bios Can't Memorise Seting.
when you enter your bios and make changes you must save those changes before you exit normally this by pressing f10 wich will save the bios and then exit, and reboot the computer.......
i hope this is what your looking for.......if not please clarify the question for me.
Oct 11, 2008 | Intel DG31PR Motherboard
On the on/off switch you must always hold it down a couple of seconds to turn computer off
There is an option at the BIOS setings of your pc that would allow you to turn off the computer at once or after holding the power button for about 4 seconds. Although this is only effective if you havent loaded any OS like winXP in your computer
Apr 30, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
163 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
