Question about Whirlpool Refrigerators
Whirlpool Model # ED5JHEXTB SOME TIME IT GIVE GOOD COOLING AND SOME TIME IT DOES'NT.
Reset whirlpool refrigerator model#wrv986fdem
Page 20 of the manual
Exit Showroom mode by pressing and holding LIGHT and LOCK at the same time for 3 seconds.
Manual
https://www.whirlpool.com/digitalassets/WRV986FDEM/Use%20and%20Care_EN.pdf
Sep 06, 2016 | Whirlpool Refrigerators
How do I determine and fix what is wrong with 2008 model whirlpool frig that the freezer I noticed first all food unfrozen then a couple days later refrigerator not cooling can hear running but contin
I ned more information to answer your question. What model do you have? This is very important to give you the correct information you seek. Thanks
Sep 16, 2014 | Whirlpool Refrigerators
My whirlpool fridge isn't cooling but freezer is
check if it has iced up around the air vents between the two halves as that will block airflow and warm up fridge. if it is is give it a good defrost to melt the ice and stop it from reicing
Feb 08, 2012 | Whirlpool Refrigerators
Cook top light will not go out even with all burners off on my whirlpool WFE361LVS. any ideas?
Light usualy stays on till the stove or stove top Cools off give the oven time to cool off If this dos`nt do it turn the Breaker off for a while to rest it and see if no help check owners manual for a user`s GUIDE
Aug 29, 2011 | Whirlpool WFE361LVS Stainless Steel...
My dryer takes to long to dry, the element is not burned out but it does'nt come on often enough is it my thermostat?
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Jul 30, 2011 | Whirlpool LER5636P Electric Dryer
Stopped cooling. fan still runs. after several hours started cooling good again.next morning stopped cooling again
Your defroster timer switch may be at faught. The defrost timer turns on a heating coil to defrost your frige. This is only a guess since I don't have the model and year. Do this: feel the walls if they are hard and they have no give to them, then your fridge is frozen up solid and no air can circulate. Unplug you fridge for 24 to 36 hours. Put towels on the floor to catch the water. If the defrost timer is bad it will defrost naturally with room temp. Plug back in after 24 to 36 hrs and see if bottom is now getting cold. If it is the defrost timer, the solution is not cheap. It's up to you to repair or invest in new. Good luck Google burdfrenzy
Nov 26, 2010 | Whirlpool Refrigerators
Have a whirlpool refrig. both sides freezing up even when set on lowest level model # ed5phaxtsoo cleaned coils fan runs allthe time.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 09, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
How to bleed the coolant?I cant get it right.HELP...
if you haven't any experience with that bleeding out air in cooling system maybe it is time to invest in a service repair booklet for that model??
Dec 15, 2008 | 2000 Pontiac Grand Prix
Refrigerators Logo
210 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
