FixYa.com
Tags:
Toshiba Libretto 100CT  Motherboard
Toshiba libretto 100CT
By Lizzy - usenet poster
I have a broken Toshiba libretto 100CT notebook computer. The problem is
that this computer resets after a random amount of time. Sometimes it keeps
on working for more then an hour, sometimes it runs only for a minute or so
before it restarts.
I have brought the unit to a repair shop, and they could repair the unit,
but at a cost of more then 1000 euro.  I think this is too much for such a
computer so I would like to try to repair it myself. Since I do not have any
documentation, I would like to ask if anybody has some experience with these
machines and give me some help. I do have some experience with SMD
soldering, so if I can find what's wrong with it, I think I can fix it.
Regards,
Kees.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Oct 18, 2007
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Hello
Yes, that seems like a overheat problem. take out the power (battery and Power supply) take away the little plastic frame in front of the keyboard and move the keyboard. (do not disconnect any cables from the keyboard!) Use compressed air and blow away the dust from the cpu.
Hope you understand my bad English.
I got a Libretto 110CT an that works perfect.
Libretto-fan
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 11, 2005
Not Rated (0)
paulrmc
paulrmc - usenet poster
Rating: 0%, 0 votes
Every disadvantage has its advantage :) Opening this computer is difficult
enough, so when the unit was still under warrenty, I would not try to repair
it myself.
Although I could not believe the reset switch could be the problem, I now
think that this is indeed the case. The switch is directly soldered onto the
mainboard, so it is not so easy to remove it, but when I press the switch
continuously, the reset problems are gone. (I use a small screwdriver
between reset-hole in computer and the wall.) So thanks very much for your
idea. I now will try to remove the switch, and try to find a replacement for
it.
Regards
Kees.
Solution #3
Not Rated (0)
maartenw
maartenw - usenet poster
Rating: 0%, 0 votes
Sounds like either an overheating or a reset problem .
Might be as simple as an intermittent reset switch .
The other thing you could try is to wire up an external drive, and use
a copy of PC-Check to test for hardware problems . Might help with
diagnosis .
BTW, you won't believe this, but Windows (any version) has a bug
whereby if there is a corrupted sound file played by Windows after an
event (e.g. "New Mail" then it can cause a soft reset .
The solution to that is to disable all sounds . Worth a try I suppose.
(Windoes help file) .
Does this happen from a boot disk ?  If so then the computer is
definetely bad .
Solution #4
Not Rated (0)
Luisa_K
Luisa_K - usenet poster
Rating: 0%, 0 votes
If you're really stuck - give me a bell..  I repair notebooks - smt rework
is quite easy - aslthough getting some of the parts can be hard..
1000euro's  -- Should be a LOT less than that..
Matt.
Solution #5
Not Rated (0)
lawyer
lawyer - usenet poster
Rating: 0%, 0 votes
It does also happen when i restart the computer in dos mode, so I think that
it must be a hardware problem.
Kees
Solution #6
Not Rated (0)
Beresford
Beresford - usenet poster
Rating: 0%, 0 votes
Is it under warranty ?
The other thing worth trying is to remove all the expansion cards (if
fitted) , and see if this makes any difference .
If it was my laptop. I'd try monitoring the voltage lines to see what
was happening when it reset itself - was it slowly dropping, and then
resetting when the power dropped below a critical level ?
(Tip: the +5V output is available on the PS-2 port, so no disassembly
required) .
Also try disconnecting the reset switch (if on a separate lead) . I
remember reading about a problem on some earlier machines where the
reset switch was normally closed, so any problem would result in a
reset (even just a noisy switch) .
Just my $0.02 worth ..
Solution #7
Not Rated (0)
Brad
Brad - usenet poster
Rating: 0%, 0 votes
OTOH this does mean that you don't have to worry about voiding the
warranty by trying to fix it yourself . :)
Especially the machines at the uni I was at , some were so bad that
just tapping the desk would cause a reset . Bit of a pain if you're
doing an assignment at 2 am and the ^%^^$^% thing resets as you get up
to go and get a cup of coffee ... :-( :-(
Solution #8
Not Rated (0)
Bomber
Bomber - usenet poster
Rating: 0%, 0 votes
No, it is not :(
The only expansion card that is installed is 32Mb of extra memory. I did try
to remove that, but that did not change the situation.
Ok, I'll do that. I will post the results.
Thanks for the reply
Solution #9
Not Rated (0)
Mini Me
Mini Me - usenet poster
Rating: 0%, 0 votes
This can be a failed component on the mother board.  They would not
even attempt to troubleshoot this unit.  They will most likely be
changing the mother board.  This is the reason for the cost!
It is not praticle to service these boards, because of the labor and
cost of the instrumentation to do this type of work.
Jerry Greenberg        GLG Technologies GLG===========================­===================
WebPage          http://www.zoom-one.com
Electronics        http://www.zoom-one.com/electr on.htm
Instruments       http://www.zoom-one.com/glgtec h.htm
problem is
it keeps
minute or so
before it restarts.
unit,
such a
have any
with these
it.
Can you Help with these Motherboards problems?
Motherboards
mother board jumpers setting
sis mother board jumper setting... Answer This...
Motherboards
disque cod?
Bonjour,j'ai un probl?me avec... Answer This...
Motherboards
soundcard aspire m1620
i have an acer pc and degrade... Answer This...
Motherboards
motherboard drivers fo intel...
I cant find any motherboard... Answer This...
Repair Service
Find Motherboard Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
