Question about Maytag Kitchen Ranges
I have maytag range model mer6770acw it give me codes f1-1 and f3-1 after 10 to 15 minths of using the oven what is that codes means and what i should do before calling the service tech. thanks
  • yamanayeemi Jul 30, 2008
    thanks for your assistance would you mind to give the pars # for runawat cook upper oven and temperature sensor maytag mer6770acw appreciated
  • yamanayeemi Jul 31, 2008
    thanks prince p for the help i ordered the part for my stove i also have problem with my whirlpool side by side fridge model #ED2FH6KQ00 SERIAL # SM1841062
    the ice maker deos not get water so there is no ice i checked the water supply there is water coming to the fridge i can get water from the water compartment but the pipe which attached in the back of the fridge which supply water to the ice maker there is no water in that pipe. what do u think could be wrong. thanks for ur help.
    Scholar:
  • 93 Answers
F1-1 : this indicate runaway cook upper oven.
Solution is to check oven temperature sensor,replace if necessary.
F3-1:It indicate oven temperature sensor, upper oven. You need to replace your temperature sensor.
If you need the part # let me know.
Posted on Jul 26, 2008
  • Femi Omojogberun Jul 30, 2008
    check this site:www.repairclinic.com, at the left hand side type your model number.
    search for sensor @ part type. click sensor. you will see part # 1364 the price is $36.70
How to clear or reset SA6 code on digital display? none of the button function works.
SAB (which is probably the display message) means that the range is in Sabbath mode. The unit believes that you want the range to maintain whatever the previous settings were for the next 24-36 hours. (This is useful for those who do no work on the Sabbath but wish to keep a dish hot in a low oven for the period.)
Providing the model number would be more helpful than the serial number. The manual for the range will explain how to toggle on and off the Sabbath mode. Since you don't give your range's manufacturer and model number, I can't be sure how to disable the mode. However, on some models, press and hold the Timed oven "Cook Time" and "Delay start" buttons. For some Maytag ovens, just press and hold the Clock key.
I hope this helps.
Oct 20, 2015 | Kitchen Ranges
Getting a F1-4 error code on my Maytag Gemini model # 6772. Came home to the upper oven at full heat with the control panel beeping. Extremely dangerous situation where the oven would not shut off at the...
Hi greg_shanoia,
The F1:-4 error code means "Runaway Clean Lower oven". You need to check the oven temperature sensor, replace if necessary.
Hope it helps.
Thank you for using FixYa.
Sep 21, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Maytag gas oven has an F1 code. Model # CGR3740ADW.
The F1 code on a Maytag electric stove means the electronic range control, clock or touch pad is defective. You or a technician can do a test to determine which item is broken, but you must replace the electronic clock range in models where the touch pad and range control are one part.
Feb 01, 2011 | Maytag 24" Built-In Single Gas Wall Oven -...
Error message and alarm
These are the fault codes for your unit
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Hope this helps, Please take the time to give this solution a fix ya rating
clarkco
Feb 27, 2009 | Maytag MGR5870 Gas Kitchen Range
Bake element doesnt work everything else does
hi there,
the bake element can melt for various reasons, however, i think that you problem lies somewhere else.
here is the service manual. have a look through it and let me know if i can be of more help.
http://www.servicematters.com/maytag_library/docs/16010107.pdf
Sep 09, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag double oven model # mer6770acw code f1-1 and f3-1 appears on the panel when using the ovens ofcourse when it gets warm or hot the ovens stop working.thanks for help
still i have the with oven heats up and stops working the codes coming on the panel are f 1-1 and f 1-3 range model # is maytag double oven mer6770acw
Sep 09, 2008 | Maytag Kitchen Ranges
Maytag Gemini Electric Kitchen Range
Codes are correct .The back needs to be removed and your sensor is a 2 wire part ,The easiest way to make sure you change the right one is by turning oven to on and run a voltage test at each end of the thermostat.Rule follows : If oven is on you should have 115 -120 volts present and make sure you have the same at the other end of thermostat ,if you have the volts at one side and not the other than that is the bad thermostat. Please rate this !
Aug 15, 2008 | Maytag MER6772 Gemini Electric Kitchen...
CODE F1-1 STOVE MAYTAG GIMENI/ WHIRLPOOL S/S NO ICE TO ICE BUCKET
Sorry i still have this problem with code f1-1 appears on the screen panel especially when it get warm or hot and still need help. thanks
Aug 08, 2008 | Kitchen Ranges
Error code F-4
Oven temerature sensor fault. Check the sensor. Probably needs to be replaced.
Jan 18, 2008 | Kitchen Ranges
Kitchen Ranges Logo
317 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
