Question about AOC CT720G 17" CRT Monitor
AOC 17" Flat CRT Monitor
Gentlemen,
Display menu keeps on popping out on my screen and my monitor keeps turning on and off.
Hope you can help me.
Best regards,
Diorel Gavino
  • donptal Oct 06, 2008
    menu keep on popping and adjusting by itself.
Try cleaning it
Posted on Nov 06, 2008
    Champion:
  • 220 Answers
Could be problem of key switches!
Try replacing or check for leakage,high resistance across switches using ohmmeter.
Samir
Posted on Jul 26, 2008
Crt monitor turned orange and the monitor menu keeps popping up
probably its old or try to check the color status in display property in desktop properties
Apr 21, 2010 | SAMTRON 55V 15" CRT Monitor
I have aoc monitor the problem is out of range
Describe your AOC S7M51, 17 in. CRT Monitor Problem. with external TV Tuner card connected, Message shows "Warning, Not Support, Out of range" and with CPU connected, the same message shows from the booting... ??? are AOC monitors trusted for the efficiency ?
Dec 04, 2009 | AOC CT720G 17" CRT Monitor
My monitor changes colors (e.g. normal then turns
Color changes on the display mostly occurs because of a faulty VGA cable or a loose connection of the cable to the VGA port at the back of your PC or Monitor. But if the cable is fixed securely at the back and the problem still persists, slightly move the cable's wire segment while observing its reaction on your monitor. Does it change colors while u do so? If it does even when the cable is securely plugged in to both the PC and the monitor, then u need to change the cable.
As for the visible display area size (technically called the Resolution) right click on an icon free area on the desktop and click Properties. At the top of the form click on the Settings tab. At the bottom of this form find Screen Resolution and adjust it to it your requirements and click Apply. On the confirmation dialogue that pops up click Yes if the displayed resolution suits u otherwise click No and try another resolution size. Hope this helps.
Nov 28, 2009 | AOC CT720G 17" CRT Monitor
Screen got yellowish color
Sounds like overstressed video cable, at least that wire for BLUE signal, 'cause when image is yellow - the BLUE color is missing.
Open the monitor and ring coaxial wire in blue insulation.
Sep 11, 2009 | AOC CT720G 17" CRT Monitor
No display on AOC 17" CRT Monitor
My AOC 17" flat monitor (model number P7S80) is not displaying properly. Only 80% of monitor is displaying and the edges at the bottom are tapered of. If somebody is having a solution please post it.
Sep 07, 2009 | AOC CT720G 17" CRT Monitor
Help me fix to the set up of my monitir AOC 7f 17''
Good morning! kindly try the following:
-mouse pointer on the screen, right click the mouse, then click the Properties, then click Settings tab, then click Troubleshoot or Advance which will guide you in setting your screen display. best regards.
May 04, 2009 | MPC Computers AOC 7F 17" CRT Monitor
Hi...my AOC 17" CRT monitor display on the screen says NOT SUPPORTED OUT OF RANGE... i try to change the screen resolution by using other monitor but still nothings happen..
Change to the lowest settings you can on the other monitor, then connect the 17" CRT. If you can see anything, go to display settings and slowly bring the settings up. If you lose the display, press "n" (there is a dialog box asking if you want to keep the settings, y or n). Most likely it is a refresh rate that is set to high. Try setting this to 60 Hz for starters.
Hope this helps.
Dec 12, 2008 | AOC CT720G 17" CRT Monitor
"Not support Out of range"
You have to boot your PC in safe mode using press F8 key.
after that you decrease the resolution in the display setting section.
It will help you.
Nov 29, 2008 | AOC CT720G 17" CRT Monitor
The menu is always pop up
so what is the best solution guys?
Oct 30, 2008 | AOC CT720G 17" CRT Monitor
AOC 7 F 17" the OSD keeps on flashing
DIAGRAMA DE CABLE VGA DE MONITOR AOC MODELO F1770 DE FABRICACION O MONTAGE EN CHINA
Aug 03, 2008 | AOC 7F 17" CRT Monitor
AOC CT720G 17" CRT Monitor Logo
331 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
