Is anyone else having issues with their Compaq Presario V2220US? We had issues with the ac adapter connection a little over a year ago, since it was covered under the warranty at the time we sent it back for repair. Now the warranty is expired we are having the same problems again.
  • 62 Answers
Sounds like a dry solder joint on the dc socket
Posted on Jul 26, 2008
V2222won't go to seal automaticly i have to do it manual.
go to power settings in the control panel - there should be something there
Oct 17, 2014 | Compaq Presario V2220US Laptop Universal...
Compaq presario cq61 will not stay turned on.
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:
http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
Replacement Compaq Presario CQ61 AC Adapter 65Watt 18.5V 3.5A
Replacement Compaq Presario CQ61 AC Adapter 90Watt 19V 4.74A
Nov 21, 2012 | HP Compaq Presario F730US Notebook
Cq61 laptop battery issue
According to the sympton you have described, the most likely issue is your laptop charger failure. Considering replacing a new one:
Oct 25, 2012 | Computers & Internet
Compaq presario c552us will not charge battery
THE COMPUTER DOESN'T EXACTLY CHARGE THE BATTERY. MAYBE THE ADAPTER FOR THE C502US ISN'T COMPATIBLE WITH UR COMPUTER, OR THE ADAPTER CONNECTION AT THE COMPUTER/ MOTHERBOARD IS FAULTY.
Jan 09, 2010 | Compaq Presario C552US Notebook PC
Wireless adapter not functioning-
Do the following :
  1. Turn Laptop off, then disconnect adapter and remove battery. Re assemble and restart.
  2. Try clicking the button activating the wireless card.
  3. Reinstall wireless card drivers, select drivers from Compaq Presario V6205NR Notebook PC
  4. If all that did not work, then the internal adapter is faulty. Buy an external wlan adapter:WLAN Adapter WL-167G-£12.90 new
Sep 26, 2009 | Compaq Presario Notebook
Presario 700 power problems
No the battery does not have to be in for the notebook to work. No the battery does not have to be charge for the notebook to work. It sounds like you have a AC jack issue. Check to see if the AC is loose. You need to get this repaired by a local notebook repair shop.
I hope this helps. Please rate.
Feb 18, 2009 | Compaq Presario 700 470024-192 Notebook
AC Adapter Problem
why not buy the correct power pack
matching the power needs of you puter.
each puter needs a watts level, do that or more never less.
only hp.com spec tells you what you need,
its in the service guide for you PC.
take out the battery
now run OFF LINE pack
run now? good, does it drop dead if you gently
wiggle the plug at PC port> not moving pack and its cable.
yes, then the PC has a bad power port end cause.
if it is the PC power jack bad
you will never fix it. its real deep and takes totally disassembly to reach.,(done many and do no teach LT guts to anyone)
amazing HP.com has your books, and is always there.
read them it specs it out.
yes, power packs go bad, 3 ways, dead, weak, or intermittent.
all do in time, (max life is about 20years,less if overloaded, as i bet you did)
if the PC needs, 50w, do not put in a 30w. use 50 or 75 or 100w
see? or it overheats .the pack,
here is your page (OP)
seems very very old, HP, is fighting me...
needs 19v at 90watts,
$8 to learn what is bad, is this too much>?
old XP LT built in the 1990 its very very old and slow.
256mb ram wow. Celeron ouch.
https://www.amazon.com/Adapter-Supply-Charger-Compaq-Presario/dp/B002V1CWZM/ref=sr_1_1/153-8354350-8800969?s=electronics&ie=UTF8&qid=1489601394&sr=1-1&keywords=compaq+presario+2596us
Mar 15, 2017 | HP Compaq Presario 2500 HP Pavilion ZE...
Compaq Presario 1200 won't charge battery
dear N9YK
you can follow this
If you have a loose connection where you plug in the power on your laptop, or it works intermittently, you could have a bad dc jack. Symptoms
  • Move the power plug and the laptop loses connection
  • Broken or cracked dc jack
  • Laptop won't charge but worked on battery
  • Power LED and battery LED flicker when the adapter tip is moved
  • Battery won't charge
  • Sparks come out the back of the laptop
Why does this happen?
  • Flaw in manufacturer designs
  • Use of universal or non-original ac adapter
  • Lots of plugging and unplugging of the ac adapter
  • Tripping on or pulling the ac adapter cord
or you can check your dc amper in your adaptor
oke
thx
cropp
Mar 16, 2008 | Compaq Presario 1200 Notebook
Computer start-up
ok...try this without battery, only with ac power pack plugged in.
got backup?
Feb 11, 2008 | HP Compaq Presario V2000 Notebook
Compaq presario does not turn on
Your battery is dead. You need to get a new power adapter. The battery isn't charging. The AC adapter went south. If the laptop is under warranty, you can get one from Compaq. Or, what I would do is shop on the internet and order one. Whats the numbers on the ac adapter? I'll help you find one.
Jun 30, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
