Question about Sony Computers & Internet
I put my laptop in hibernation mode and I can't get it to come back on. What do I need to do?
    Scholar:
  • 81 Answers
Hi sbrinke594,
Power down your laptop by pressing down the power button for about 5-10 seconds. Wait about 20 seconds before powering it on. Once you power it on, right click on an empty space on the desktop and choose properties, next click on "Screen Saver" tab, click on "Power" button, then click on t he "Hibernate" tab and uncheck the box for "Enable Hibernation".
This should help and good luck.
Posted on Jul 26, 2008
When i hibernate, my computer turns back on in 30 seconds/
check that it is not set to 'wake on wifi', if so, turn this setting off
Oct 19, 2012 | Dell Inspiron 1200 Notebook
My laptop keeps saying hibernating and i cannot get to menu screen.
Definition: Hibernate is another option for powering down your laptop. When you use Hibernate all data will be saved to the hard drive in a compressed form. Once you start up from Hibernate mode you will be able to work with the applications and documents you left open before putting the laptop into Hibernate.
Hibernate is best used to conserve laptop battery power when you will be away from the laptop for more than a few minutes. You can put your laptop into Hibernate overnight or when you will be away from it for a few hours. Examples: Rather than shutting down my laptop each night, I use Hibernate to help conserve battery power and enable me to access my open files quicker in the morning.
If you are not going to use your computer for a few hours, it is a good idea to put it to sleep (also known as mode) to save power. If you are not going to use the computer for more than a day, it is usually best to turn it off.
hope it helps.... please rate if you like my post...thanks
Jun 06, 2011 | Computers & Internet
I ussually put mi laptotp to a hibernating mode but now I cant get it started the message it shows says: "hibernating" and its been like this for more than 3 hours How can I solve this?
Power off the laptop, remove the ac adapter, and remove the main laptop battery. Push the power button in for approx 15 seconds. This will bleed all power from the capacitors. Now, replace the battery and attach the ac adapter. Power the computer up. When it boots, go to the control panel > Power Options > On the top of the window you will see the hibernate tab, click on it and un-check the hibernate box. Hibernation will and can destroy parts of the registry. Sleep mode is fine for most laptops....hibernation is not.
Jun 30, 2010 | Dell Inspiron 1545 Notebook
My Acer Aspire One went into hibernate mode by itself and am unable to turn it back on unless I remove the battery and use it solely on electricity mode. Please help.
keep press power button for 1 mins and your laptop will turn off. when you turn on your laptop. disable hibernate mode.
to return to your desktop from hibernate mode press power button quickly. windows will resume
May 04, 2010 | Acer Aspire One PC Notebook
Question
Hibernation is a power management feature. When you hibernate a laptop, you're essentially turning it off. So, unlike Stand By (Sleep) mode, a hibernated laptop isn't using any battery power at all - that laptop is off!
The secret behind hibernation is that before you turn off the laptop, everything you're doing with the computer is saved. (The contents of memory are saved to the hard disk.) When the computer is turned on again, it recovers from hibernating by reloading all the saved information and restoring your laptop to exactly the same condition it was in before it was hibernated.
Briefly, hibernation works like this:
1. You activate the hibernation feature.
Hibernation is activated differently depending on how it's set up.
2. The laptop hums as everything in memory is saved to disk.
3. The laptop turns itself off.
It's really and truly off: The battery isn't being used, and it's safe to store the laptop or put it away until you need to use it again.
To recover from Hibernation mode, just turn the laptop on. In some cases, the laptop may recover from hibernation when you press a key or touch the mouse pad. hibernated state for as long as you want.
Hibernation mode requires hard drive space. So you should be aware that when hard drive space runs low, it's possible that Hibernation mode won't work.
In Windows XP, you have to activate Hibernation mode before you can use it. Follow these steps to activate Hibernation:
1. Click the Start button.
2. From the Start menu, choose Control Panel.
3. Open the Power Options icon in the Control Panel.
4. In the Power Options Properties dialog box, look for and click on the Hibernation tab.
If you don't see a Hibernation tab, there's your answer: The laptop isn't capable of hibernating. Oh, well.
You might want to check the laptop's Setup program to see whether you can activate Hibernation there.
5. Select the Enable Hibernation option by clicking the check box to place a check mark in the box.
6. Review other options, if they're available.
7. Click OK to confirm the changes and close the Power Options Properties dialog box.
Optionally, close the Control Panel window, as well.
Some laptops may require you to restart Windows for this change to take effect.
Sep 09, 2009 | Computers & Internet
Gerneral advice please
On hibernation, the state of the computer is saved to the disk, to turn it on again press the power button, the computer will read the hibernation image from the disc and restore its state.
You can press stand by, from that mode the computer should come back with the press of a button, the computer might also go into stand by if the cover is closed and come out of it when opened.
let me know if you have further questions.
May 21, 2009 | Acer Aspire AS5002WLMI Notebook
Hibernate
When Windows opens then -
Open Control Panel - then click on Power Options - Click on Hibernate tab and uncheck Enable Hibernate - Click OK
Feb 13, 2009 | IBM ThinkPad T23 2647 Notebook
My cooling fan is not working
It really is like the sleep mode / Hibernate mode when it is it really his job, also for when people are sleeping out which job as sleep, the computer does so well the reason is also removing his job when sleeping in, would have understood and helped them. good luck
Jan 11, 2009 | Dell Inspiron 1525 Laptop Jet Black
Computer does not stay in hibernation or standby mode
That happen because on the stand by or hibernate setting the time was setting in 5 minutes.
Go to Control Panel >> Display >> Screen Saver >> Power
And set the time right there as your preferences.
Oct 01, 2008 | Toshiba Satellite A135-S2276 Notebook
Desk top won't display-hibernation mode
Based on your post of failure to boot due to hibernation, you can try removing the battery and AC adapter connection for an hour or so. Thereafter, insert battery back and charge but don't power up. Allow the laptop to charge for a couple of hours. Try powering up/booting. Press F8 to start in Safe Mode. Once in Safe Mode disable Hibernation.
If the laptop still fails to power up, then it may be entirely another problem.
Post back results. Good luck and kind regards.
Nov 04, 2007 | HP Pavilion dv4000 Notebook
Computers & Internet Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
