Question about Garmin GPS
I only get acquiring satellites on the screen all the time
  • rtfisher1234 Sep 28, 2008
    I think this is a bug with some i3's. I updated to firmware version V 3.40 but no difference. My mates one works ok though. let me know if you get a fix.
    Brigadier General:
  • 4,090 Answers
45 minutes is not a reasonable time to aquire. If these times are being experienced then the battery is in a low state.MAX time 5-6 mins But average 1-2 minutes
1) ALWAYS ensure the battery is fully charged USE AC charger
2) clear view of the sky
3) check BAUD RATE and port arecorrect ( some FPS brands are fixed)
4) Burned out sirf chip ( Always remove DC plug before starting engine)
5( Be aware that some windscreen are thermo screens and can interfere with GPS signal Determined by black dots at centre top screen behind the mirror (Toyota Prius as an example)
Posted on Aug 21, 2009
After you re set your nuvi, and the "acquiring satellites" is showing on screen: place the unit while on, flat, outside - I placed mine on the outside deck with open skies above! leave the unit in this position for no less than 45 minutes. This is the time the unit needs in order to "acquire" the satellites.
After this, my unit worked perfectly well.
Hope this helps.
JA
Posted on May 06, 2009
4 Suggested Answers
  • 6 Answers
SOURCE: Trouble Acquiring Satellites
Thank you all for the help. I had already downloaded updates and it told me there weren't any more updates that the unit was current. The bugger just fought me all the way.
I tried the reset address over and over to no avail. Finally after it was completely charged, I set it by a window and left in turned on with the finding satellite or whatever it said on it, and went to bed. By the next morning it knew where I was!
Posted on Dec 25, 2007
SOURCE: acquiring satellite
I had the same problem with my brand new nuvi 200w. I called Garmin support and they were able to help me. I live on Long Island and evidently when I first turned on the unit I had selected the "Atlantic" time zone rather than "Eastern." The support tech had me reboot the unit by turning it off, holding my thumb onto the lower right hand corner of the screen and turning the unit back on. It does prompt you that you will lose your previous settings. When I reset it and selected the proper time zone its worked like a charm.
Posted on Dec 31, 2007
  • 35 Answers
SOURCE: Garmin Nuvi takes a long time to Acquire satellite
No. 98% of the time it took 45-56 seonds for your NUVI 660. Thats the compagny set up time acquisition and it did very well.
Be sur you had your flip antenna parallel to earth surface.
660 has THE BEST SIRF Chipset for acquiring satellite.
I had 2 NUVI 660 since 2 years. It work much better than those new 7xx series who it really took 2-3 minutes to acquire satellite.
Be sure you update your version to the last one.
----> https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00540-00&cID=134&pID=400
Best regards
Posted on Jan 21, 2008
It soes not a acquire a satlelite.
I have this unit and have not had a problem acquiring satellites except under dense canapy cover. In open view you should always be able to acquire enough satellites. You should be able to see the available satellites on the start up screen and watch them being acquired. According to the manual if a satellite fix is not established a list of solutions is suppose to appear. Hope this helps.
Feb 02, 2011 | Garmin eTrex Vista Cx GPS Receiver
I have a garmin 260 and lately when I turn it on it takes a very long time to acquire satelites.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
  • If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes.
  • If your unit has not been used for an extended period of time (more then a month), it may take 3-5 minutes to acquire satellites.
  • If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased.
  • If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites.
    • If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*.
If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software by using our WebUpdater program. Once your unit is updated please allow the unit to acquire satellites outdoors in a stationary position with a clear view of the sky.
*Note: Some units may not be compatible with an external antenna. Please check the Products tab on the external antenna's page to see if your unit is listed.
Jan 16, 2010 | Garmin nuvi 260W GPS Receiver
While driving Garmin Nuvi 250 constantly loses satellite signal. The screen says that it is aquiring a signal. It is also constantly refiguring the route.
Nov 12, 2009 | Garmin nuvi 250 GPS Receiver
Nuvi350 doesn't locate any satillites. What can I do?
Jul 11, 2009 | Garmin nuvi 260W GPS Receiver
Brought my NUVI from NY to San Francisco and it doesn't locate any satillites. What can I do?
Good Luck
Jul 07, 2009 | Garmin nuvi 260W GPS Receiver
Garmin 260w won't acquire satellites
Jan 30, 2009 | Garmin nuvi 260W GPS Receiver
Hello i have the garmin 250 i had brought it on the water a few weeks ago and as soon as i got of the water it has a question mark and says aquiring satatiles but never picks up a signal and doesnt work...
Question: Why won't my unit acquire satellites?
--> Answer: There are a several different factors that can cause a GPS unit to not acquire satellites:
  • If your unit is trying to acquire satellites for the first time, it is normal for it to take a while to establish its initial position.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take longer than normal to acquire.
  • If your unit has traveled a long distance while turned off or not tracking your travel, it may take a longer period of time to acquire.
  • If your unit has not been used for an extended period of time, it may take a longer period of time to acquire.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, you may need an external antenna.
If your unit is not acquiring satellites, it is recommended that you place the unit in a stationary position where it has a clear view of the sky. In some cases it may be necessary to take the unit outside of your vehicle as certain vehicles inhibit the unit from acquiring satellites. As the unit receives signal from the satellites, it will begin to lock on to them individually until it has acquired enough information to establish your position.
If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software. You can do this using our WebUpdater program which can be found at the following link:
http://www.garmin.com/products/webupdater/howtoinstall.jsp
Sep 25, 2008 | GPS
Abnormal Powerdown Error Code
Your battery is dead, which is causing the problem with "slow to receive satellites". Normally when you turn off the unit it will remember the last location and time, then the next time you start the unit it already has the time and current location to acquire satellites, but with a dead battery it has to start from scratch. Check the screen and see if it says "Locating Satellites" or "Acquiring Satellites". Locating satellites will take longer. Replace the battery and your problems should go away.
Jul 22, 2008 | Garmin StreetPilot C330 GPS Receiver
Best regards
Jan 12, 2008 | Garmin Nuvi 660 GPS Receiver
Acquiring satellite
Dec 31, 2007 | Garmin StreetPilot c340 GPS Receiver
GPS Logo
385 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
