Question about Bosch Dishwashers
Dischwasher will not drain - Bosch Dishwashers
    Scholar:
  • 93 Answers
Does your dishwasher run during wash cycle? then,
Check drain hose by try this, loose the clip that hold your drain hose firmly from your dishwasher side, check carefully if no debris blocked the hose connector, water suppose to come out from that connector if it does, your drain hose was blocked with debris or mold and particles like coffee seeds etc.removed them connect the hose back run the dishwasher.
If that does not solve your problem check under your dishwasher, there's a timer activated drain solenoid that opens a drain valve to drain the wash water through a hose.
Replace it.
Posted on Jul 26, 2008
Jet tech f14 dischwasher water not fill in
you go the water turned on at pipe
Feb 03, 2017 | Jet Dishwashers
E21 code on Bosch Dischwasher...what does it mean
E21 Circulating pump blockage
This would be caused by a blockage or a poor water flow from the main motor of the dishwasher. This can be caused by a capacitor failure or for other reasons.
Dec 08, 2013 | Kenmore HE2 Plus Front Load Washer
What size allen wrench to open panel of the bosch dischwasher
It is not an allen wrench you need but a torx wrench (looks like a 6-point star). DO not try af open with an allen wrench or you will strip the screws.
Jan 17, 2011 | Bosch SHU9915UC Dishwasher
I am putting in new Granite Counter Top but I do not have my DIshwasher yet. Do I need to have them drill a hole for the dishwasher airgap? If so, how large? Thanks
I have had several dischwashers over the years and none have required any ventilation holes in the worktop.
I am an odd job man and have never seen any such holes in any of the houses that I have visited, so I think that you can safely forget about it.
Sep 19, 2010 | LG LDS4821ST Stainless Steel 24 in....
What is error code 3 on the Miele dischwasher?
I dont think that the error code is 3 it must be 13.
If it is 13 then, this error is a flow meter error. You will need to pull the dishwasher out and it on the side there is no way to reset it it will need to be replaced fairly common issue.
Remedy is to open the stop clock fully - clean the water inlet filter - th e water pressure at intake is lower than 30kPa (0.3 bar)
Aug 29, 2010 | Miele 24 in. Touchtronic G694SC Built-In...
Sink was pluged plunged and now the dischwasher will not fill it's keeping draining the water out all the time
Bosch has a safety float switch under the dishwasher basin. If water leaks into this area, the float rises and turns on the drain pump to clear out the water in the dishwasher. Hope I explained that ok :)
Anyways, usually a leak somewhere causes this and unless the leak is fixed and water is removed or evaporates, the dishwasher will remain in the drain cycle.
Feb 24, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
My Bosch dischwasher is not draining completely. I've taken out the mesh filter and the square plastic drain cover. Should I unbolt the white cover which I presume covers the drain? thanks!
I had the same problem, twice. Both times, the technician simply removed the drain hose and cleared it of a small food particle. Save yourself the service charge by unhooking the hose yourself, clearing it and rinsing your dishes THOROUGHLY before washing.
Feb 23, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Fault with my dischwasher
F2 indicates the motor is not rotating.The motor may be jammed or defective. Also , the motor rotation sensor may be defective
Jun 03, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
169 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
