Question about Nvidia GeForce FX 5200 Video Card Graphic
Slower machine, Unstable screen, blinking screen, finally blue screen with error message
I have a Dell Dimension 5400 (4 yrs old) and the machine has slowly gotten slower over the last few months until it finally shut down Windows XP with the dreaded blue screen. At the same time, the screen got increasingly unstable, blinking off and on more and more. The error message on the blue screen indicated a problem with either the driver file nv4_disp.dll or the device itself. I downloaded/installed the latest driver from the Dell site for the display card, but this did not help at all. Same problem persists.
My fear is that the Display card has gone bad, but how do I diagnose this problem? I do not want to spend $100+ on a new card and find out that this was not the real problem....
Thanks
Garry
  • 1 more comment
  • grbsr Jul 26, 2008
    Thanks colliewob,
    I gave you the "short" story in my initial question, so here is the rest... At the advice of a "friend" who knows a lot more than me about computers, I backed up all of my data files and proceeded to reformat my hard drive and re-installed Windows XP with the Dell disk provided with my computer. Initially, this worked well, but when I started reinstalling the needede drivers, the problem reared its ugly head again. I do not remember which driver installation caused the problem to pop up again, as I was so "sure" at that time that I had solved the problem... Ha! Ha! So, you see my registry is clean, the hard drive is clean, and the problem is still there...
    Based on this new and more detailed info, any additional solution or diagnosis path would be welcomed.
    Thanks again,
    Garry
  • jannnnnnnnnn Mar 15, 2009
    same problem as garry. Can anyone help please?
  • Anonymous Mar 25, 2009
    I have a Dell Dimension 8300 purchased in Feb '04. Recently I've been getting fuzzy screen/blue screen indicating that the nv4_disp.dll driver is responsible. I have this exact same graphics card (using the DVI port).
    Problem Solver:
  • 5 Answers
Try downloading the driver from the nvidia instead of dell. I had a dell for 3 years and found that the drivers they provided only worked 30% of the time.
Posted on Jul 27, 2008
  • 781 Answers
After 4 years I recommend trying all these things as your computer is cluttered up
go to c:\ drive right click on it
go to properties/tools/error check/ check now a box should popup and you tick the box fix errors reboot when windows is rebooting it will scan system files and fix any that are faulty window will then restart and load.
go to start/run type in msconfig enter go to startup stop all except for your anti virus reboot
You can then see if its running correctly
but after 4 years I suspect you will need to clean out the registry.
you will have to search net for registry cleaner there are a lot out there see if you can get a free one as some will only find errors and not fix them
Posted on Jul 26, 2008
  • David
    David Jul 26, 2008
    Go to
    Start/control panel/ system/hardware/device manager check if any driver have yellow mark by them these are not there or faulty drivers.
    Try to download the PC wizard program
    When installed and used it will give a list of drivers you need for your computer. note name and number search web for them
    EG: (cmedia 2346 drivers). ensure you get the ones for your operating system UNINSTALL any old drivers before installing new ones
    Install one at a time reboot install another one see how that goes
    As an afterthought the disk that come with computer usually have all drivers needed
Dell Dimension 3000 blue screen error with writing that say attemp to fix windows
First try to replace ram with known good one.. if you have two eject one and vice and versa.. run system to see if it's working.. if it doesn't then try to install windows on it.. If it's not Harddrive bad sector that has corrupted your windows. .It would be either RAM or a virus...
Mar 27, 2013 | Dell Dimension 3000 PC Desktop
First of all you have to identify the blue screen error code. Blue screen errors normally occurs due to infected windows files. You need to scan PC to remove malwares, junk and virus.
Also update the drivers that control your PC.
To fix this problem instantly use system optimization tool like Reginout.
Frequently get a blue screen with a Fatal Error message.
Blue screen while running indicates that the OS (one of the file) has been as been corrupted.... Re installation of the OS will solve the problem
Thanks...
Jul 19, 2010 | Dell Dimension 3000 PC Desktop
I get a blue screen error message ''c000021a unknown hard error'' after running CHKDSK as a result of receiving an initial blue screen error message ''The Type of file system is NTFS. The volume is...
Hi, Boot into Safe Mode by pressing F8 at bootup and choose
'Safe mode with command prompt'
At the command prompt type
C:\Windows\system32\restore\rstrui.exe
Hopefully System Restore will open so choose a Restore Point a few days ago.
Please rate my response!! Thanks, SF
Jan 28, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Where should I look in the computer (Dell dimension 8400) for the problem windows shuts down and a blue screen error message saying page fault in a non page area.
Hi friend,
You need to check your ram in your computer.. i think your RAM is not good running...so try to change then ram ...then it will work..
Jan 06, 2010 | Dell Dimension 8400 PC Desktop
Blue Screen with various STOP error messages appearing.
This is a tough one to troubleshoot since there are several issues which can result in this error. Let me start by listing known causes.
Corrupt pagefile.sys file
Corrupt or wrong drivers for system devices. printer, camera, ect.
Corrupt program drivers, adobe elements, capture card software.
Bad System Ram Modules.
You didn't specify if you installed anything new, hardware or software but to trouble shoot this issue begin by download Memtest86. This will test your system boards memory for errors.
If your ram passes the test you might try removing other devices such as printers and its software. Testing the issue after each uninstall.
Last you can try replacing system files or performing a system repair using your operating system cd. If you need to run the repair option and need help just post back here.
Hope this helps.
Apr 07, 2009 | Dell Computers & Internet
Dell Dimension C521 w/Vista will not boot OS.
There is no way around this you need to get your OS from Dell and reload.
Sorry.
Feb 19, 2009 | Dell Dimension C521 PC Desktop
Blue error screen and system shutdown on Dell Dimension C521
Rule of thumb test ram out first usally that is the cause what does the code say on the blue screen
Feb 13, 2009 | Dell Dimension C521 PC Desktop
Blue Screen Error Message
Looks like you've been getting two different Stop errors...
The 1st error, 0X00000024, aka Stop 0x24, is a Windows 2000 error. (XP is just an updated version of 2000) Microsoft gives an explanation here.
For the 2nd error, starting with 0x000000ED, Microsoft's solution is here, with additional help here.
Jan 02, 2009 | Dell Dimension 3000 PC Desktop
Nvidia GeForce FX 5200 Video Card Graphic Logo
717 people viewed this question
Top Nvidia Computers & Internet Experts
Terry
David
David
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
