Question about Lexmark X6100 Flatbed Scanner
PRINTER/SCANNER INSTALLION Can I install the printer and scanner without using a telephone jack? And how do you do this? I have one cord.
  • Anonymous Jan 27, 2009
    jack asss that does not resolve the original question
How about a class action suit against Lexmark and Microsoft for not coming up with a solution to the X6150/Vista problem, on behalf of all of us who are stuck with an all-in-one that is only two in one? I bought mine for the inclusion of a scanner.
A loser in Delaware
Posted on Aug 17, 2008
  • 163 Answers
The telephone jack/cord is only needed for utilizing the "FAX" funcions. For printer/scanner setup see http://www.lexmark.com/publications/eng/x6100/index.html
MM85
Posted on Jul 26, 2008
My Uniden Dect 6.0 are suddenly displaying "Check TEL Line" and there is no line tone. This happened after trying to install a new wireless printer. What should i do? Thank you!
first thing - don't do what I did - I pulled out somehow my printer /scanner network ethernet cable when putting in a network switch !
So
Check the power cord for the DECT 6.0 base unit has not come out when you were installing the wireless printer . and also
Check the tel line cord is plugged into wall and base unit.
Check frequency used by cordless is not 2.4 GHz or 5 GHz as it might interfere with Wireless printer radio frequency.
Feb 21, 2018 | Uniden Lands Phones
I cant send a fax or reseave one
Sir/Madam
Solution one: Check the fax connections Use the following steps to check the physical connections, and then use the HP Fax Test Service.
Step one: Check the physical connections
  1. Disconnect the telephone cord from the HP fax product, and then examine the connector on the end of the cord. Make sure that the cord has only two wires. Figure 1: Two-wire telephone cord
  1. Four-wire telephone cordGraphic: Four-wire telephone cordIf the cord has four wires, replace it with a two-wire phone cord.
    If you must use a cord with four wires, use the converter that shipped with product. The converter allows a cord with four wires to work with a device that requires a cord with two wires.
  2. Connect one end of the telephone cord to the telephone jack, and then connect the other end of the cord to the port labeled 1-Line on the back of the HP fax product.
    Figure 3: Fax only
  1. 1 - Telephone jack2 - Two-wire telephone cord to 1-Line
  2. Connect a single-line telephone to the 2-Ext port on the back of the HP fax product.
    Figure 4: Fax and telephon
  3. 1 - Telephone jack2 - Two-wire telephone cord to 1-Line
  4. Connect a single-line telephone to the 2-Ext port on the back of the HP fax product.
    Figure 4: Fax and telephone
1 - Telephone jack 2 - Two-wire telephone cord to 1-Line
3 - Telephone
If other devices need to use the same telephone jack, make sure that they are connected to the 2-Ext port on the back of the HP fax product.
Figure 5: Fax with answering machine and telephone
  1. 1 - Telephone jack2 - Telephone cord from 2-Ext
    3 - Optional telephone cord to telephone
    4 - Optional telephone
    5 - Answering machine
    6 - Two-wire telephone cord to 1-Line
  2. Pick up the telephone receiver and listen for a dial tone. Make sure that you can dial out using the telephone keypad.
    If there is a dial tone and you can dial out using the telephone, the HP fax product is connected correctly to a working telephone cord and telephone jack. If there is no dial tone, check the configuration again and make sure that it is set up correctly.If You Still Having Hp Printer Problem Then Visit Official HP Printer Website On Below Link URL http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c02263145
Or
If You Still need HP Printer Online Help Then Follow Us On:
HP Printer Support
Feb 12, 2014 | HP LaserJet 3030 All-In-One Printer
Cnecting to a computer
What OS is installed on your computer? The Samsung SCX-6220 is listed as compatible with several versions of Windows, including Win7 x64. The drivers for the SCX-6220 are the same as those here: http://www.samsung.com/us/support/supportOwnersProduct.do?prd_mdl_name=SCX-6322DN . You'll need the appropriate printer and scanner drivers for the OS and the SmarThru software (two different tabs under the Manuals and Downloads tab).
Then use the USB or parallel printer port depending on your computer (for Windows only Win98+ supported USB) and the cables you have available. The USB port is below the telephone jacks and the parallel port along the side of the telephone jacks. All of the ports are on the left side. A network card can be installed on the back of the printer.
I hope this helps.
May 25, 2012 | Samsung SCX-6220 Multifunction Printer...
I WANT TO USE THE SCANNER BUT, I DON'T NOW HOW, It go to the printer all the time, could you please help me ? I have the EPSOM STYLUS BX300F PROFESSIONAL, PRINTER,SCANNER,FAX,PHOTOCOPIER.
Basically, you can use the scanner in two ways. Please open the scanner cover and place the document or image you want to scan face down.
1. Press the SCAN button (color button = color scanning, black button = monochrome scanning). then your scanner will scan the document or image in the scanner tray.
2. Go to the scanner program installed in your computer when you installed the printer. Open it and then click the command button SCAN.
Note: Make sure that you installed the Scanner software when you installed the printer. Without the software, your scanner will not work. Please reinstall the printer including the scanner software.
Feb 06, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Properly connecting the scanner
well in order to use the scanner on your AIO printer... you need to install the application software for the scannerfrom the disk that you would have resolved along with the printer...
Jan 19, 2009 | HP OfficeJet J4580 All-In-One Laser...
FAX LINE NOT RINGING TO TELEPHONE
This is what is called a ring trip.
unplug your fax machine and plug in a normal phone. call the fax line. let it ring a few times. if the phone rings, but not the fax machine, check the cord of the fax machine and replace it. if the fax machine still does it, there is a short circuit somewhere in the machine. it is most likely in or around the jack that connects it to the phone cord, check for corrosion or bent contact pins.
if it rings only once or not at all, then check the phone jack for corrosion. trace it all the way back to where your phone line connects to your house. if it is still not ringing, call your telco to get them to check thier equipment.
Jan 15, 2009 | HP LaserJet 3055 All-In-One Printer
Dell926
Clear Carrier JamThese are possible solutions. Try one or more of the following:
Remove any obstructions
  1. Raise the scanner unit.
  2. Remove any objects blocking the path of the print cartridge carrier.
  3. Make sure the cartridge carrier lids are closed.
  4. Close the scanner unit.
  5. Press button_select_0.jpg.
Remove print cartridges
  1. Make sure the printer is on.
  2. Raise the scanner unit.
  3. Remove both print cartridges.
  4. Make sure the cartridge carrier lids are closed.
  5. Close the scanner unit.
  6. Press button_power_0.jpg to turn the printer off.
  7. Disconnect the power cord from the wall outlet.
  8. Plug the power cord back into the wall outlet.
  9. Press button_power_0.jpg to turn the printer on.
  10. Reinstall the print cartridges. For more information, see Installing print cartridges
  11. Close the scanner unit.
  12. Plug the power cord into the wall outlet.
  13. Press button_power_0.jpg to turn the printer on.
  14. Reinstall the print cartridges. For more information, see Installing print cartridges.
Regards
Chittaranjan
Dec 14, 2008 | Dell 926 All-In-One InkJet Printer
Won't install
since u cant find the file i suggest u use deskjet plus to do the installion. all will work well but u might not be able to print in color.
u use this if u need an urgent print out in black i only suggested
cos each time i fix some ones printer i use deskjet plus for deskjet n laserjet plus for laser jet n it works all fine without installaion disk.
thank u
May 27, 2008 | HP DeskJet 5150 InkJet Printer
Scanner problem of hp laserjet 3030 all in one
Try unplugging the cord to the printer and wait a few seconds and re-plug the cord again , print what ya have to print again/hope this helps .
Dec 01, 2007 | HP ScanJet 3200C Flatbed Scanner
Lexmark X6100 Flatbed Scanner Logo
129 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
