Question about Samsung 226BW Monitor
No power at all
Right out of the box it doesn´t even come up. The power on button never lights up. tried different power cords & volages, but still is dead. Any chance of getting a troubleshooting guide and/or tech manuals ? thx
    President:
  • Samsung Master
  • 1,314 Answers
If it's brand new, exchange it. Why try and fix something when you can get a working one?
Thanks and please remember to rate as FixYa.
Posted on Jul 26, 2008
Converter box will not stay on - starts green light then switches to red
I have one of those right here attached to my computer so I can watch TV on the PC. The red-green light is the power indicator. Your converter is turning off for some reason. Possibly it is getting a signal from another remote, and turning off. You can block the converter's remote sensor with something (black tape works) and then change the channels with front panel buttons if it has them.
Mine has power buttons for both the TV and the converter, so watch out for that.
Apr 06, 2017 | Televison & Video
My Remington Keratin Therapy Flat Iron Doesn't Turn On.
see thi steps and fix it.God bless you
If the iron doesn't heat, make sure 1) power is on to the outlet, 2) check the electrical cord and 3) check the thermostat and replace if necessary. Use the VOM.
Oct 15, 2012 | Remington Style Therapy: Keratin Therapy...
Hp PSC1210 All-In-One not turning on
HP makes a couple of different power cords for the PSC 1210 and their other printers. First make sure you are using the correct power cord (Amperage and voltage). Unplug the power cord (from the wall and the printer and from a power module if you have one). Leave all of the sections unplugged for at least 15 seconds to reset the power module/printer.
Next connect the power cord to the wall outlet and to the power module if present and check if the LED (if present lights up). If it doesn't try another outlet. In either case, check what the outlet voltage/amperage is at the end of the power cord with a multimeter (before you plug it into the printer). If you have a power module, then check the Amperage (it will be a DC current out).
If you are not getting the correct voltage and amperage out or the LED doesn't light (with a known good outlet), try a different power cord/module.
You can order these from HP.
If you have the correct power at the cord, plug the power cord into the printer and attempt to turn it on. (Press and release the power button.) If the printer still doesn't come on, the unit needs service. Contact HP if the printer is under warranty. Decide if it is worth fixing if it is out of warranty.
I hope this helps.
(I've had to use the HP Repair/Replacement service after a unit was in a home that was hit by lightning. Due to printer availability, an HP gift card was provided to buy a new printer.)
Dec 11, 2011 | HP PSC 1210 All-In-One InkJet Printer
When you plug it in, (lexmark pro 205), there is a white light in the display box but no words or pictures and the on button does not light up. the only way to shut it off is by unpluging. It does...
Try to rebrick your printer. Pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds. This will give enough time for the printer to reset itself.
You may also try to plug the printer to a different known working power outlet in the wall to identify if it's a faulty power outlet issue.
If that doesn't help, please contact Lexmark Technical Support Center for additional assistance.
Sep 01, 2011 | Lexmark Prospect Pro205 Wireless...
My lexmark x5470 does not turn on, and only a red light bright inside near the print injectors. Thank You.
Try to rebrick you printer by pulling out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds. This will reset your printer.
If that doesn't help, try to plug your printer into a different known working power outlet.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 25, 2011 | Lexmark X5470 All-In-One InkJet Printer
My printer is not switching on What can be the problem even though the fuse is alright in place?
UNPLUG PRINTER POWER CORD,AND TRY DIFFERENT OUTLET. IF THAT DOESN'T WORK, LOOK FOR RESET BUTTON, LOOK IN YOUR MANUAL UNDER TROUBLESHOOTING. OR CALL BEST BUY GEEK. HOPE THAT HELPED.
Jun 29, 2011 | HP PSC 1315 All-In-One InkJet Printer
Bought new power supply, no difference power button will not even go on or light up ; however small green light on mother board lights up. als accidentaly disconnected the switches wiring to the mother...
The green light just show that the motherboard is getting power.
The power button of the front of the case is connected to the mother board, not to the power supply, usually in the extreme lower left corner along with the with the HDD and Reset Button cords; Power button wire are labeled and usually red/black.
If all wired correctly, possible bad or stuck power button or reset button.
Hope this helps.
Please rate this answer by check rating "Hands"
Feb 08, 2011 | E-Machines T3958 (827103050974) PC Desktop
Hello we have a 19inch HP monitor that doesn't power up, even with a new cord and different outlets in the power strip.
after connecting it to the circuit correctly> try pressing the power button that might be either on the right top or side> if the power button doesnt turn blue> the monitor has gone bad
Oct 08, 2009 | HP Computers & Internet
Just bought HPJ4550 and will not turn on during initial setup. Appears to be power to the cord as the green light is on on the coverter.
Ok. The most obvious things first. Unplug the power from the printer itself and plug it back in. Next, press the power button just 1 time and wait 10-15 seconds. If you do not see any lights or display, try a different outlet. If you still cannot get a response from the printer even after trying a different outlet, the printer or power cord is defective.
Aug 22, 2009 | Office Equipment & Supplies
Mi computer doesn't work anymore. It's an HP tx1220. My warranty has expired and a technician has told me that probably it was the mother board. What can I do?
Ok what do you mean by doesn’t work?
No power? no lights? dead?
Have you tried a different power cord?
I ask this because of these things
  • Laptop power cords can just give out without warning
  • And just because the green light on the power cord is lit does not mean it is putting out enough power or any at all
  • And even if you test the power cord and it reads the correct voltage does not mean it is still putting out enough amperage to handle a load (like powering up the computer) Of course that is extremely rare but I have seen that happen before
  • Before giving up hope I would try borrowing another cord from someone with an HP laptop or one of those I-GO laptop cords with the changeable tips or something or even better yet try your power cord on a different laptop and if the other laptop turns on .then well I am sorry
NOTE: if your power cord has a little green light on it and that light goes dim or starts flashing as soon as you plug it into the laptop then that is a very good indication (9 times out of 10) that your motherboard has gone bad and shorted out somewhere.
But there are too many possibilities of what could be wrong with out more info
When you plug it in do any lights on the computer come on at all?
I wouldn’t give up all hope yet .. that is a pretty nice little computer and worth trying to figure it out.
Nov 25, 2008 | HP Computers & Internet
Open Questions:
See all Samsung 226BW Monitor Questions
Samsung 226BW Monitor Logo
59 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
