No need to replace thermostat nor stop valve but the problem most likely is the hot water stop valve(s) lose lubrication or valve surface got oxidized which has caused valve(s) fail to close tight. All you need to do is to take out both valves and flush clean. Pull out plunger type valves. Clean and well grease them before put them back in. This is actually a regular maintenance and it should resolve your minor leakage probelm. Worst case scenario, you have to buy Grohe Part # 08355 which comes in a pair. I bought one pair from Amazon.com for $96 shipping inclusive but now found no need to replace the stop valve(s). Thermostat valve doesn't have anything to do with your leaky valve but you may need to flush clean it as well. Good luck! -- Michael
Fsefse
