Question about Kenmore 22062 Top Load Washer
Kenmore Elite Calypso 22066 washer beeps and displays 6 on screen, can't start
Our Calypso model 22066 washer started beeping the other day and the control panel gets locked up. It is displaying lights: Wool/Silk, Auto Temp Control, Cold/Cold, Minimum, and "6" in the minutes remaining space. Sometime I can clear the display, push the cycle I want and push start. It will work fine except beeps all throughout the cycle. Other times, I can't get it off of the frozen display. It works only about 25% of the time. Any ideas what is wrong with it?
4 Suggested Answers
SOURCE: Damaging clothes
Put garments in a laundry mesh bag or pillow will snag on even the smallest imperfections in the drum. Then do the extra gentle wash the other person suggested. Other wise always hand wash in very cool water and mild soap.NEVER use a bio, ever!
Posted on Oct 18, 2008
  • 1723 Answers
SOURCE: I have a kenmore elite
Start here, then let me know what you see:
The washer must be empty and the control must be in the OFF
state before pressing the touch-pad sequence to start the test.
Starting the Test Mode
■ Close the door.
■ Push CONTROL/ON (if present on this model).
■ Select the DRAIN/SPIN cycle.
■ Select NO SPIN by pressing the SPIN SPEED touch-pad.
■ Push PREWASH OPTION four times within five seconds. (If
PREWASH OPTION is not present on this model, press RINSE
HOLD four times within five seconds.) C:00 will light up on the
If the Starting procedure fails, push the PAUSE/CANCEL touch-pad,
then repeat the starting procedure.
Test Program Control
In order to advance to the next step of the test procedure, push
PREWASH OPTION touch-pad two times. If PREWASH OPTION is not
present on this model, press RINSE HOLD two times.
Posted on Aug 24, 2009
  • 447 Answers
SOURCE: Kenmore elite calypso 22066 runs through cycle but
check the water inlet solinoid to see if its working
Posted on Jul 24, 2011
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 13, 2010 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elite washer, Model 110.20096993, it starts beeping with about 10 mins left in the cycle and shuts off. Any thoughts?
I have the same model - it displays 10 minutes and keeps beeping in series of 3 (beep beep beep...... beep beep beep... etc..) ran through a cycle successfully but kept beeping like that the whole time. I unplugged it for 10 minutes but had the same symptoms after plugging it back in. I unplugged it for 24 hours, and that seems to have cleared the problem up.
Jun 12, 2010 | Kenmore Washing Machines
Kenmore elite calypso doesn't respond to buttons except cancel
I've had a similiar problem on my calypso. In my case the key pad would go dead after washing or pushing stop after a few minutes. If I unpluged the unit for a few minutes it would work again. This would appear to be in the controller board. I removed the board and inspected it finding no problems. After re-installing the board the washer appears to be working again. My conclusion is that there is a loose connector/connection. I'd suggest you remove and re-install all the connectors on the controller board. This is the board closest to the power chord.
Good Luck, George S.
Sep 10, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Catalyst Washer Keeps beeping and displays 10
I'm not sure if you've solved this already but our Kenmore Elite washer had a similar problem that got worse. It ended up being the whole touch panel had to be replaced. I was able to diagnose and replaced it myself with help from the Tech sheet that is underneath the touch panel. Our Kenmore Elite dryer also had to have this paenl replaced several years ago when it was fairly new. Hope this helps.
Sep 08, 2009 | Kenmore 3.2 cu. ft. Top Load Washer
Kenmore elite calypso washing machine that won't spin and drain, it has an error code of F-3, but I can;t find my manual. any help
After setting up washer I hit the start butten, washer filles up and befor it will start it will start to beep and the lights flash and I have to hit the start butten agin befor it will start to wash.
Dec 31, 2008 | Kenmore 24032\24036 Top Load Washer
Calypso 22066 top=load washer
You probably have hoses and sump pump plugged/jammed by not enough to the machine from operating, my machine leaked prior to cleaning out all the hoses and sump pump
Aug 29, 2008 | Kenmore 22062 Top Load Washer
Kenmore Elite Calypso Washer
take the pannel off the bottom and unscrew the pump cleanout
Feb 09, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 22062 Top Load Washer Logo
Sal De
 Brian Main
Brian Main
