Question about Protron PLTV-26 26 in. HD-Ready LCD Television
It will not turn on manually or with the remote.
This happened during a thunder storm and all the electricty went off for about two minutes. I had been watching the T.V. when the power was out, but when the power came back, the T.V. had no power. I checked all circuit breakers. If it was struck by lightening, can it be repaired?
My protron fuckin blows ***
Posted on Oct 15, 2008
  • Protron Master
  • 5,568 Answers
Posting this for the third time now:
 I checked and found the Protron name belong(s) or (ed) to Spectroniq and neither of the two websites are up anymore.
Also, I could probably make a zapped supply work again but you do not know what might have been damaged downstream from it and that is a good possibility; the damage may be much deeper than it appears since many of the integrated circuits used in modern equipment don't tolerate hundred (or thousand) volt spikes and without a working supply, there is little chance of diagnosing it unless a service department has a few lab-type power supplies and can simulate the failed original supply.
If you do find anyone who has stock on assemblies for this TV, you may find more than one part number on the board. If it is a number that seems to be under clear lacquer, it is likely only the bare board number. If it seems to be stamped on or has a label with a number on it, this is going to be the whole part number for the 'stuffed' board.
I can't help you with this one but I would suggest, especially if you live in a lightning-prone area to consider installing a 'whole house' surge protector. They do cost a couple of hundred US dollars plus installation charges, but the established companies even include an insurance policy that covers $10,000-25,000 in damages. If you own your home, it's your decision and I cannot imagine any landlord would object to having you install one at your own expense.
Posted on Sep 28, 2008
How do I know what parts to get to fix it
Have you replaced the lamp recently? they can fail if they are on when the storm happens? Please post your model # for more info.
Apr 21, 2015 | Panasonic Televison & Video
LN55C750R2FXZA Samsung LCD
What your describing is symptoms of a power surge, Many LCD Tv's are sensative to Slight fluctuation in power during rain, thunder and lightning storms, i myself was happily watching Tv through such a storm at one time, and when i went to bed the TV would not respond remotely or manually, i also disconnected the power from the wall waited for the ready light to disolve and try to turn on, unfortunatley the damage was done, a Tv Repair was nessecary and since then i now use a belkin power surge protector board for my TV and appliances......one question to you is i would guarantee you do not use a surge protection my friend......and your set will need a Tv Repair, it is not major as what is neccesary is a firmware dump on the internal memory and replace the BIOS Battery as well.
Aug 17, 2014 | Samsung UN55B8000 55 in. LCD HDTV
Tv does not turn on, after a thunder storm.. tv was off during storm.. but heard a click as if I was turning off tv.. Blueray player , ok Direct tv box ok , all come on that was connected to tv... whi
during thunder storm, is your TV connected to wall outlet, if it so your set have a problem on power supply, you are lucky if is only a blown fuse.
Aug 06, 2014 | Televison & Video
My frigidare gas oven wont turn on...
try changing the igniter it may have burned out or is weak
Aug 26, 2012 | Frigidare FGB24S5DC Gas Single Oven
HELP! I think my TV got zapped and is ruined from storm!
Check whether the power outlet has power. If it has, I suggest please do not attempt to switch on the TV, unless checked by a qualified service technician.
Aug 16, 2012 | Toshib 46L5200U 46" 1080p LED-LCD TV -...
Kdl40ex401
Hi there!
One of reasons your tv not working, the thunder storm /lighting possibility has burnt your Tv micro processor. get a technician to check the power supply section too because during the thunder storm your TV circuitry received excessive voltage .
If is the main processor is burnt you have to change it for the TV to work .
Jan 10, 2018 | Sony KDL-40EX401 42" HDTV-Ready LCD TV
Can't get channel manager to come up. Can't change channels. Electric went out from a thunder storm. Transformer hit by lighting. Now can't get channel manager to come up and can't cha
If you have not tried it: UNPLUG THE SET FOR A WHILE then plug b a c k and see if helped-----what can happen if power outage is microprocessor in set gets confused.
Let me know if questions or if this helped.
Mar 23, 2012 | Hitachi P50V702 50 in. Plasma HDTV
Air conditioner went out during thunder storm and now only blows out hot air. How can I fix this problem?
check to make sure outside unit is running. power failures can damage alot. if it was running during storm.
Jun 17, 2010 | Bryant 463AAC005BA Air Conditioner
Tv turns on and then off
Good Day, ruschracing;
Storm? The first thing you should do is unplug the TV from the wall for 3 to 6 minutes (reset), then plug back into wall.
If that does not help, then you should call an authorized service center to give you an estimate for the repairs. OR call your home owners insurance company.
Good Luck, big IRISH.
Jul 25, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Protron PLTV-26 26 in. HD-Ready LCD Television Logo
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
