Jamo D6 Subwoofer osillating sound through speaker.Phase cutoff and vol control do not change it.With speaker leads o/c no oscillation. With dynamic feedback sensor out of circuit no oscillation. Has anyone had this fault previously please. Best regards........ mbeech@paradise.net.nz
  • 3 more comments
  • Mike Beech
    Mike Beech Jul 26, 2008
    Jamo D6 subwoofer. This unit is self oscillating giving a low level approx 1.5kc's sound through the speaker in addition to the correct signal.Also with no signal input.Appears to be caused through the servo feedback input which if disconnected the problem goes away.
  • Mike Beech
    I have this unit apart the oscillation is visible on a scope as a multi frequency centered around 1.5 Kc's triangle waveform.Disabling the servo feedback circuit stops the fault. Amplitude at speaker leads is about ten volts peak to peak.
  • Mike Beech
    s4u311 no i cannot explain it i was hoping someone on fixya would have the answer. Too much loop gain?
  • Mike Beech
    Robotek
    Thanks for your advice re input earthing.Will let you know if it helps later. Can i contact you via email or telephone i would like to remain in touch.
  • Mike Beech
    Mike Beech Jul 27, 2008
    Hi to all you folks who answered. First time i have used this service, very pleased with responses. How do i enter "award" points where appicable? Fault turned out to be the feedback transducer mounted on the back of the cone, a piezo disc plus op-amp inside a small plastic box hotglued in place. Now where to find a replacement!?
    Thanks again all.......
  • 689 Answers
Shielding is one of the main factor, Make sure cables are shielded well at the source. A tiny cut or crack on the unamplified cable lines will give chance to feedback and oscillation.
Posted on Jul 26, 2008
  • 2,071 Answers
No oscillation cause by Loose ,crack or cold solder joints parts..
Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....If i have helped,please click to rate.It is the only way i get paid for my work...
Good luck:
Regards,
VOTIT
  • 1,512 Answers
I would be looking for leaky capacitors in the sub woofers output stages. Some times the easiest way is tpo replace all the caps in the device that are in the signal section, and see if that stabilises the problem. Also check for low value resistors that may be used as a fusible connection to your input earth connections. It may have gone open circuit producing an earth loop from the rest of the system. You need to check that the sub is operating on the same phase as the equipment driving it or you will get earthloop problems from this also.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button If you consider the advice I have given you as sound, please accept my solution and we can work through your problem.
Thanks for using FixYa
regards
robotek
  • 2 more comments
  • Graeme Ross
    Graeme Ross Jul 26, 2008
    oh, by the same phase I am referring to the AC mains power supply phase. if they are on GPO,s on either side of a wall, they may be fed from different phases. Just pull the circuit breaker for plugs in the room, if the power is gone from all the GPO's then they will be on the same phase.
  • Graeme Ross
    no worries, just accept my solution and we can go from there. :)
  • Graeme Ross
    Graeme Ross Jul 27, 2008
    Good to here you found the problem. I have a pair of old Philips active HiFi speakers that have a peizo transducer like that. You can get parts from hereservice@qualifi.com.au Its in Australia, but still be quick for you. Cheers mate
  • Graeme Ross
    Graeme Ross Aug 07, 2008
    How did you get on mate? Any uck sourcing the par to fix the problem?
  • 813 Answers
Can u explain it
  • sandip panchal
    sandip panchal Jul 26, 2008
    connecting a 0.1uF/100V capacitor across the speaker terminal
    humming will be off
    Brigadier General:
  • 6,966 Answers
On a similar concern, troubles are normally internal to the amplifier of the subwoofer. If it is a 60cycle hum, then it may very well be insufficient/defective filter of the power supply; if on the other hand, it the sound is rumbling, then it is amp noise and if it feedback sort, then it is a shielding problem.
Correct procedure would require opening the unit for a look and see, familiarity with electronic circuitry and components, use of a DVM and a soldering iron.
Alternately, possible temporary workaround may include:
  • shortening/replacing/relocating the speaker cable and the input cable;
  • connecting a 0.1uF/100V capacitor across the speaker terminal;
  • decreasing the input impedance of the amp (preloading); and/or
  • using a filtered power strip for the AC mains connection.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role Jul 26, 2008
    Hi again,
    Appreciate the additional information. What is the output/amp IC? Any op-amp or pre-amp IC too?
  • 790 Answers
Hi
what do you mean oscillating sound?
Thanks!
Why won't my a102 speakers from jamo witch came
The Jamo speakers need an AV Receiver to drive them properly. The TV doesn't have the correct outputs nor does it have the power required.
The Jamo kit consists of a powered subwoofer ans 5 small surround speakers. Each surround speaker needs to be powered by the speaker output from an an AV Receiver. The subwoofer should also be connected to the receiver, but the connection is a phono/RCA lead from the receiver's "Sub Out" socket.
Your TV connects to the AV receiver via the Optical out.
Sep 01, 2014 | Audio Players & Recorders
My a102jamo surround sound speakers and working
Aug 31, 2014 | Audio Players & Recorders
I brourt a jamo sub 200 and five a102speakers but
I have jamo sub200. I connect to pioneer vsx-rs320k audo video receiver. when I turn the volume of subwoofer to a higher value with the receiver, the bass sound becomes distorted and not satifieng to...
hi,
Do one thing set the control behind the sub. set the level and cutoff control at it half position. Set phase control at "0" position. Then test the sound. if you ate using tower speaker as front speaker then you have to set the position of phase control 180 ,
ok
Apr 11, 2011 | Jamo SUB 200 Subwoofer
What do the phase and cut off controls do,manual does not explain much.
Phase reverses the polarity of the driver so it can be matched to the other speakers and bass-reinforcement characteristics of its position in the room. You don't want the sub 'sucking in' while other speakers are 'pushing out' or a bass cancellation will occur.
Set it, listen to bass from your normal seating position, reverse it and observe if the bass gets subjectively better. Leave it in the 'better' position.
Cutoff is a variable for the highest frequency where the speaker 'cuts off'. You can experiment with adjusting it for what sounds to you like the smoothest transition betwen the sub and the othere speakers. You don't want a lot of audible overlap where the sub and other speakers are acting on the same frequencies. It may sound to bassy in that area.
Dec 26, 2010 | Jamo SUB 200 Subwoofer
Sound faliure
If the subwoofer has its own power cord seperate from the rest of the audio system, the internal amplifier could be fried or u have a loose connection inside the box
Mar 29, 2009 | Jamo SUB300BA SUB 300 Powered Subwoofer...
Jamo Sub300. No power. No lights
Well it would void the warrantee, but you can take the back panel off and the power supply will only have two leads (3 if grounded) in from the plug, and out to the crossover. It sounds as if you are correct that the power supply is bad.
Charles
Jan 05, 2009 | Jamo SUB300BA SUB 300 Powered Subwoofer...
Tuning speaker system denon avr 2400
You need to check on the operation of your receiver regarding the use of the subwoofer output line. If it does not satisfy you, better get a better receiver or A/V control pre-amp system with lots of features in the subwoofer circuitry. Google (internet) might help you with your specific model.
Sep 24, 2008 | Denon AVR-2400 Receiver
315 people viewed this question
 Grubhead
Grubhead
