My USB flash drive will work in my laptop but not in my PC. It says the device is working properly when plugged into the PC but then says it's not formatted in G drive. How can I get the flash drive to work on my PC?
  • 163 Answers
What OS oare you using on both?
Posted on Jul 26, 2008
"USB device not recognized" error message MacBook Air
The drivers must be up to date and written for your device. If there are no drivers, it will not communicate and thus it may look like it is working and in place, but the linkage is not there.
Mar 17, 2014 | Kingston DTU30G2/32GB 32GB DataTraveler...
Sandisk cruzer 8gb suddenly not recognized when connected to my computer
1. Try the other USB slots to see it the board is ok. Most modern pcs have two slots in the front and two to four slots in the back, try them all.
2. Do you have another pc that you can plug it into? If it works on that one you may have driver problem or the board is bad on the other one.
3. Have you tried to plug other USB devices into the slot(s) to see if the port is ok?
I have the same one and have had to mess it sometimes. Have to right clicked the "Safely Remove Hardware" in the right corner of the task bar. Right click and then left click the Safely Remove Hardware. That will show you all USB devices loaded. If you see the Flash Drive, click it and when you see the next prompt to remove it wait a few seconds and then plug it back in. If that does not work, reboot and leave the Flash Drive plugged in and see if it loads when the pc fully is loaded.
4. Goto the Control Panel> System > Hardware > Device Manager. Look for your drive in the list of Disk Drives. Pick it and then pick the Action Menu and Scan for hardware changes. If the Flash Drive is working properly you should not see any errors. You should also be able to see the drive in explorer.
5. If you still do not see the Flash Drive in explorer but you do see it in Device Manager, right click it in Device Manger and unstall it and reboot and let windows search and reinstall the device drives.
Good luck and post back.
Jun 01, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Good Morning! Please help me how to restore the function of my laptop USB port, when i connect even flash drive, printer, scanner to my usb port it dosn't work properly, its hang then when i remove and...
Have you tried to shut down your computer and re-start it up again ? (to see if your USB port starts to works again ?)
One thing you should (must) do before you remove / detach a USB device (e.g. flash drive, camera, etc.) from the USB port is to make sure you properly "dismount" (eject/disconnect) the device first (e.g. use its Property menu option) before you physically remove the device (i.e. take it out - remove it from the USB port). If this is not done, you'll get the problems you're experiencing.
Jan 02, 2011 | Computers & Internet
When i plug in the u3 flash drive it says usb device not recognized
Hi ,dkjran,
If your computer affected by virus will not show in the pc .so you will install it to another pc,and format it .Flash drive can not recocknize,becayse there are some reason .
  • VIrus affected
  • Sometimes when a flash memory stick or USB external hard drive fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory USB hard drive device appears to malfunction it may be possible to restore it by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted then it will indicate that it is Healthy.
If this doesn't work then it is faulty.
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
hope it will help you
Dec 12, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sir ! when i atteched pendrive from usb port in hp530 laptop give error usb unreconizable
This can happen if the proper driver for this device is not installed or that the USB stick is damaged. If proper driver is not installed go to control panel-hardware-device manager & locate the device and update/reinstall the driver. If it still does not work plug your USB stick on any other computer & if it works then format it once & try again on your laptop.
Nov 10, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
When i plug in my kingston usb 8 gb the system message showen that the windows not recognize your device. i am using windows xp sp2 in my laptop plz solve my problem .... thanks
i recommend you try the usb flash drive in a different pc if it does not work you flash drive is corrupted if it works you might need to have your pc usbs checked out
Sep 26, 2010 | Computers & Internet
My usb port of my Compaq Armada E500 Laptop no
the usb port of my hp Compaq Laptop nc6000 no longer works properly. whenever i insert a flash it says usb device not recognized.
Jun 03, 2009 | Compaq Armada E500 Notebook
Usb device not recognize
You mentioned that you uninstalled the unknown device from the Device manager. If you uninstall it then connected your usb flash drive you will see an error again on your device manager. This means that the driver for your usb port is not properly installed.
To install it, visit dell website, look for the model of your machine and locate the driver, download it then install from your machine.
Jun 02, 2009 | Dell Inspiron 6400 Notebook
Usb trouble
update you device in the internet if didn't your again, try to used another OS. Use Windows XP
Jun 08, 2008 | Gateway 4028GZ Notebook
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
