Question about Movado 800 Performance watch
Hello I have a movado 800 series sub 200 and
Hello I have a movado 800 series sub 200 and latley the arms have stopped movin but the seconds arm does not stop
  • 148 Answers
It is probably either in set time mode, or some sort of chronograph mode. play with the buttons.
Posted on Feb 19, 2011
SOURCE:
How do I replace the rubber on the back case of movado 800 series
I was told my a jeweler that Movado condiders that. Design defect and they don't produce or offer that rubber insert for sale.
Jun 26, 2013 | Movado Series 800 Watch
I just recieved my Movado 800 series watch today and the large chronograph timer hand won't reset to zero (top of dial @ 12 o'clock) when I press the zero button. It resets to 56 minute position....
you do not need to return, as this is re-settable. Pull out crown to the first position (date setting) and then toggle with upper push button. If upper button do not do the job, try the bottom one. When you reach 12, then push the crown back in. Start the chrono, stop it and check if it returns to 12.
May 18, 2011 | Movado® Series 800 Blue Chronograph Watch...
How can i get second hand to start working?
I couldn't find the operating instructions for your watch but a similar watch made by anothe manufacturer makes me think that the "second hand" is actually part of the chronograph i.e. it acts as a stop watch.
Try pressing the button at the two o'clock position. If the had moves, press the button again to stop it. To set the hand to zero, press the button at the 4 O'clock position.
I hope this helps.
If this does not produce the desired result, go to http://www.movado.com/contact-us and speak to them about it.
Feb 15, 2011 | Movado 800 Performance watch
The chronograph hour hand on my movado series 800 is out of sync and i cant get it back to the 0 position. I have pulled out the crown and pushed the start/stop button...
Try pulling the crown out and using the reset button to move hands beside the sweep arm. If this doesn't work then you may need to take it to a repair shop that can reset or AC the watch. With a movement as fine as Movado I wouldn't attempt this yourself. If you make a mistake the repair could cost more than the watch. Be sure that you have the watch resealed so it maintains its water resistance.
Feb 10, 2011 | Movado Series 800 Watch
My watch stops in the night.But works fine when i wear it.any ideas?
Yes, the Movado is a self winder, and it was designed for the sports active wearer, of which the motion of the wearer's arm provides the power to keep the watch wound. Apparently you are not active enough for the watch to be fully wound, so when you take it off, it will use up all of the stored energy in the spring and stop. many self winders will only store enough energy for 8-12 hours of use and will require constant wearing. You could try wearing it to sleep and see if this is enough to keep it wound.
If you feel that this is not the case for your watch, then you may want to have it looked at by a watch maker
Jan 23, 2011 | Movado 800 Performance watch
In reading the movado 800 quartz chronographic instruction manuel there are 3 settings for the crown. the first is the one in which you generally wear it. the second position states it will stop the watch...
The time should only stop when the crown is pulled all the way out in the third positiion... In the second position the 2nd hang should continue to tick and you should only be able to move the hour hand on the watch
Aug 22, 2010 | Movado 800 Performance watch
Just bought this watch today (movado 800 series) and the second hand (hand C) doesnt move at all. It is part of the chronograph function. It is stuck at the 9 oclock position. When chronograph is...
I wouldnt try to return it. I would go back and inform the store of the problem you have and they have no choice but to either fix it, show you how to solve the problem, exchange it, or at the least, return it but please give them a chance to fix the issue.
Best wishes,
Aug 16, 2010 | Movado® Series 800 Blue Chronograph Watch...
My watch battery low. watch name MOVADO series 800
mcdevito75 here, Movado a FINE watch, BEST BET, look for a small watch repair shop in your area to change the battery, Movado watches have a very good over all value and any damage can lessen that value, not to mention the jewelers screwdriver you"ll need to change that battery.
Jul 09, 2010 | Movado Series 800 Watch
Movado 800 Performance watch Logo
298 people viewed this question
Top Movado Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a Movado Watch Expert? Answer questions, earn points and help others
