SOURCE: Intelliflo SVRS Pump not able to ramp up without help
These pumps are very sensitive. If you are pushing the on button and the pump trys to prime and then the alarm kicks on I would check the following:
Water level in pool
Make sure skimmer weir door are not stuck in up position
Most Likely Cause
Diffuser oring needs to be replaced on pump. Easy check - shut power off to pump: remove 6 bolts that hold seal plate together (2 on top and 2 on bottom of each side of seal plate with no nuts, and 2 in middle on each side of seal plate with nuts) do not remove bolts that mount motor to pump. Once 6 bolts are removed, grab motor and pull motor unit away from pump. You will see a cone at the end of the assembly with an oring on it. Make sure the oring is snug, if not replace. This is most likely what is causing your problem.
SOURCE: We lost our password for
On the normal vs-3050, you need to reset the whole unit. You do this by holding all 4 speed buttons for 30 seconds. After thi, shut off the power at the breaker. let sit for 2 minutes. Restore power and all setting are reset. I cant find any information about the SVRS model, but it should work the same way.
SOURCE: I have intelliflo VS+SVRS pool
There is either something blocking the suction side of this pump (blocked valve, strainer, strainer basket, leaves on main drain.) or the pump is not getting primed in the aloted amount of time. You can increase the priming time on the pump, or manually prime it, or just turn off the svrs feature temporarily until you get a good prime again. If you need the manual to figure out how to do these things, here is the link.
http://www.pentairpool.com/pdfs/IntelliProVS+SVRSOM.pdf
Paragon 7008-00 timer parts:
http://www.paragontimecontrols.com/parts_accessories.htm
http://www10.shopping.com/-paragon+timer+trippers
Paragon mechanical 7008-00 has 120V clock motor
-8 poles control 1-4 separate 120V loads, with 2 NO Normally Open and 2 NC Normally Closed circuits with max 690 Watts per pole.
Test 120V clock motor:
-Clock motor connects to two far right terminals. Black hot to pole M, White neutral to pole T.
-You should be able to hear clock motor running by putting ear against outside case.
-Clock motor will rotate wheel, if wheel is not rotating, then motor is not running.
