Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer on GE model 25 GSS25SGMDBS not working
Freezer not working but fridge is. Cleaned dust from front as well as from the back(condenser). Still not working.
    Scholar:
  • 93 Answers
Change sensor temp- part number WR55X10025. You can get from searpartdirect. approximate$7.00
Posted on Jul 26, 2008
GE profile bottom freezer model # PGSS5NFXA SS. Got up this morning and freezer thawing. Pulled back panel cleaned the condenser fins with compressed air andchecked the connections. runs fine but can'
I had this happen with my fridge when the door was open for awhile when I was cleaning the inside. I did what you did, clean everything behind it. Pay particular attention to the circuit boards, there may be reset buttons in that area. Then unplug the freezer for 10 minutes (make sure it's for a FULL 10 minutes) then plug it back in and try it.
Feb 03, 2015 | GE Refrigerators
Fridge/freezer not cooling
What is the model number of your unit?
Nov 01, 2012 | Refrigerators
Hotpoint mistral plus
Sounds like a faulty thermostat, although fast freeze usually bypasses the stat so should then get to temperature. If the compressor and condenser are getting very hot and all is clean, check there isn't a condenser fan stuck underneath that is seized. If not, may have had a bit of a refrigerant leak and sucked a bit of air into the system. Call an engineer
May 19, 2012 | Washing Machines
My Ge Monogram Refrigerator required maintenance cleaning on the condenser, typical with this type of built-in system. blew out the dust and cleaned it. the freezer is working fine but the refrigerator...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 18, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
GE fridge and freezer cools when it wants to - freezer on top
hard to say, there is many questions left that need answered...does the compressor run, does the fans run? what more could you tell me.... whirlpoolpartssurplus.com free tech support
Jun 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
I have a zanussi fridge freezer combination, it is a frost free model, Im developing lots of frost in the freezer which never used to happen and the fridge is not getting cold, some condensation does...
Hello Mr Barnard
Welcome to fixya
You said, You have a zanussi fridge freezer combination, it is a frost free model, And you're developing lots of frost in the freezer which never used to happen and the fridge is not getting cold, some condensation does appear inside the fridge, it is 2years old.
Frost could mean a few things.
Is the freezer cold but the fridge not?
If so the freezer may be so full that the articles are covering the air vents in the back that share the cold air with the fridge.
I've have seen the freezers packed to the hilt!
More things to check.
Is the condenser in the back or under the front of the fridge. If it is under the front of the fridge you must remove the plastic grill`(The condenser is the thin black metal tubing that runs back and forth to make up your condenser). This needs to be free of dust and have air passing over and through it!
they sell refrigerator brushes for this at the hardware store.
I have had customers that never ran the brush under there ever and had 1 to 2 inches of dust and lint
under there between the tubes.After a few hours it was cool the next day it was cold!
The freon level pressure should be checked in case you have a leak.
The thermostat may be bad.
Let me know what works for you.
Huuum
Please remember to leave a rating!
Oct 05, 2008 | Refrigerators
Fridge and freezer on GE GSS25SGMDBS not working
see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Jul 26, 2008 | GE GSS25SGMBS Side by Side Refrigerator
Fridge and Freezer running, but not getting cold.
make sure your fans are working. one is in freezer section,the other at back by your compressor.
Jan 06, 2008 | GE 16.7 cu. ft. / 473 liter Upright...
Ge side by side not cooling enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting,
Sep 07, 2007 | GE Profile PSS26NGS Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
592 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
