Question about Razer Copperhead RZ01-050100-R1M1 Mouse
I have the copperhead anarchy red laser and NOT wireless... Its all fine but when i try to move it fast to a position its just jumpy... I found some infos that the mousepad is the reason of this cause(it needs other type of pads) I use razer goliathus Control Edition,and when i test it without mousepad(on the table) it works perfect! Any ideas what the problem is?
Krenn
  • 59 Answers
SOURCE: Razer Copperhead mouse problem
Check the BIOS settings on your computer: is it set to boot from USB drive?  that may be the problem.
Posted on Mar 29, 2008
  • 3 Answers
SOURCE: razer copperhead problem
I have something like you've all described with mine occasionally, normally, turning the mouse over and rubbing the laser surround with my finger vigorously is enough to clean off the crud that seems to be causing the problem..
I've never had any software problems or anything with mine..
Posted on Sep 23, 2008
SOURCE: razer
Hmm...I managed to solve the problem of mouse "breaking" while playing counter strike..Its a lil technical...
1. Right Click My Computer -> Properties
2. Choose 'Hardware' tab and then 'Device Manager'
3. You should see a Yellow exclamation mark on 'Razer Copperhead USB mouse' under 'Human Interface devices'
4. Right click -> properties
I do not exactly remember the wordings of the prompts that appear after this..
5. Click on something which says "install / update driver"
6. Choose the 1st option which has something missing in one of the columns..
7. Unzip downloaded driver files on your desktop
8. Choose logical options from here...
9. At some point it will ask for "Razerlow.sys" file...
10. Click browse and go to C:\Windows\system32\drivers....you will find it there...
11. Choose logical options from here and your "breaking" problem will be solved...
This does not solve the "No mouse detected" message in configurator...but atleast you can play your favorite game :-)
Posted on Oct 21, 2008
hmerchant110
  • 7191 Answers
SOURCE: My copperhead Razer mouse has started double clicking for one
This double-clicking can be due to a worn out micro-switch in your mouse. If you are well -verse with repairing such gadgets, you can go ahead and replace this switch yourself or refer it to a qualified technician
Posted on Apr 23, 2009
SOURCE: my scroll isnt working on my razer copperhead, any
Just had the same problem with my copperhead... firstly go to url below to show you how to open up the copperhead (only do this if it's out of warranty!! which is two years if you have your purchase recipt) http://razerblueprints.net/index.php/Copperhead/copperhead-disassembly-guide.html . Once you have got the top off look at the front where the wheel attaches you can pull the wheel out of the circular thing on the left then find some thin paper I used some laser receipt paper (probably gonna wear out but will find something better in meantime) cover the hole with a very small square of whatever thin material you have chosen then push the axle of the wheel back in... this tightens the hole back up allowing the clicking feel to come back and the scroll wheel to work again.
Ultimately the problem is wear and tear with the hole for the axle or the shape of the axle end wearing down.
Posted on May 30, 2010
Copperhead cursor won't move when i move the mouse
this is because the laser light in the mouse had gone bad...all that you can do is to replace that with a new one... or buy a new mouse...
Apr 04, 2010 | Razer Copperhead RZ01-050100-R1M1 Mouse
My Razor Copperhead mouse restarts
I found that when this was happening to me the problem area was where the wire meets the mouse. By wiggling that (moving the mouse) it would cause it to disconnect and reconnect.
Some claim it could be the firmware for various hardware pieces on your pc IE: motherboard, usb. Depending on how old the mouse is this could be true. Mine, however, is 4 years old and needs to either be repaired or replaced.
Mar 30, 2010 | Razer Copperhead RZ01-050100-R1M1 Mouse
It is jumpy! It's very hard to point it to anything with any accuracy, as it jumps about, and isn't smooth.
All you need to do to fix this problem is get a mouse mat, or short term just a bit of paper. If the desk or table that you are using the mouse on is in any way shiny then the laser will reflect and will be jumpy
Mar 15, 2010 | Microsoft Wireless Laser Mouse 6000...
My scroll isnt working on my razer copperhead, any ideas?
Jan 01, 2010 | Razer Copperhead RZ01-050100-R1M1 Mouse
My wireless mouse doesnt go left and right very well. (slow and jumpy) but up and down is smooth. it worked fine for the first week.
I would suggest either moving the reciever closer to the mouse, and/or replacing the battery in the mouse, just to make sure.
Jul 15, 2009 | Belkin Computers & Internet
HP wireless mouse
Try replacing the batteries. Wireless mice do funky things when the batteries are low.
May 18, 2009 | HP Wireless Optical Mouse
Razer copperhead problem
Feb 18, 2008 | Razer RZ01050300 Mouse
Jumpy mouse pointer, imprecise. How do I clean it?
Laser mice don't need cleaning.
Try un-installing the driver.
Go to your "Device Manager" (Right click on ‘My Computer', select 'Properties', click the 'Hardware' tab, click the 'Device Manager' button. Click the "Human Interface devices" (If you have one). If there is some kind of a "Warning" icon superimposed on the 'mouse' icon there is your problem!
If NOT go ahead and Uninstall the drivers anyhow, It CAN"T hurt!
Uninstall the DRIVERS for THAT DEVICE only.
Click on the faulty device and hit the remove button, follow the instructions given by the program.
Do the same with the "Mice and other pointing devices"
Shutdown, restart, the device will automatically reinstall by the "Found New Hardware" program.
Dec 08, 2007 | Logitech Cordless Mouse
Razer Copperhead RZ01-050100-R1M1 Mouse Logo
44 people viewed this question
Top Razer Computers & Internet Experts
Alun Cox
Sunday Ojelabi
Sunday Ojelabi
Larry Chandler
Are you a Razer Computer and Internet Expert? Answer questions, earn points and help others
