Question about Nitro BMW-481 Car Audio Amplifier
Nitro 1200w amp
Well when i plug in my red and white connectors,the subs i have start to pulse and there touchy when I move the connectors.
  • theformermrs
    theformermrs Jul 13, 2012
    hi how are u mrs. i looking at diagram for audio amplifier nitro 1200 thanks.
  • 631 Answers
It sounds like the shield ground in the amplifier is broken. If that's the case, the connections would have to be repaired.
Let me know if you have any other questions.
Posted on Jul 26, 2008
Power light flashing
This means it is blown. Whenever the power light flashes on any amp it is blown or something else is wrong with it. Most likely its blown. You can blow am amp by hooking it up to a powerful sub and blaring it, or just overheating it. Hope this helps. This can usually be fixed as well
May 07, 2013 | Pioneer Gm-d8400m 1200w Max, Class D Mono...
Red light
You have not got your subs wired up poperly, End it fried the ouputs on the amp, Live end learn (Dude)
Nov 10, 2012 | Nitro BMW-482 Car Audio Amplifier
Is two comp 12's with a 1200 watts nitro amp a
The 1200w rated for the amp is usually an absolute maximum output, the rated output is more likely about a quarter of this figure (300w) I think for the subs you are looking at, you would be better off with a more powerful amp
Hope this helps
May 06, 2011 | Kicker Car Audio & Video
I urgently need a Clarion cd1500r installation manual or wirng color codes
Hello, here is Clarions wire codes.
FRONT Right SPKR: +Gray -Gray/Blk,
FRONT Left SPKR: +White -White/Blk,
REAR Right SPKR: +Purple -Purple/Blk,
REAR Left SPKR: +Green -Green/Blk
Brown Wire = Phone Mute Lead (If applicable)
Yellow Wire = 12V battery lead in (Connect directly to battery)
Red Wire = 12V Ignition wire (Connect to Acc switch)
Blue/White Wire = Amp turn on lead
Black Wire = Chassis Ground
Orange/White Wire = Illumination Lead (Connect to dimmer switch)
Blue Wire = Auto Antenna Lead (lowers power antenna Do not use for Amp Turn on! Use the Blue/White Wire for Amp,EQ, Ect.. turn on wire only
RCA Connectors if applicable:
Black RCA Harness:
White RCA = Rear Audio Left Sub Output 1
Red RCA = Rear Audio Right Sub Output 2
Gray RCA Harness:
White RCA = Front Left Audio Out to amp
Red RCA = Front Right Audio Out to amp
Oct 19, 2010 | Clarion Car Audio & Video
Kicker subs hook up problems
Connect one to each channel, for the best sound.
Jan 05, 2010 | Kicker Solo-Baric L5 Car Subwoofer
Honda 1992 XR600 miss firing
Hi and welcome to FixYa,
Initially if electrical, disconnect the black/white wire from the engine stop switch, try and observe if problem persists:
  • if yes, then a loose / dirty / faulty engine stop switch;
  • if not check:
  1. 2 connectors to CDI;
  2. connector from pulse generator (black/yellow - blue/white & green/white wires);
  3. black/red wire from exciter coil;
  4. blue/yellow & green (to ground) wires on the ignition coil;
  5. sparkplug wire & cap.
Good luck and thank you for asking FixYa.
Aug 03, 2009 | 1994 Honda XR 600 R
Does a 1200W amp run 2x800W subs
ya youll be fine 800watts is at peak power on the speakers
May 29, 2009 | Kicker KX Series 04KX1200.1 1200w RMS...
If there's only a single sub-out RCA cable, you have two options. The amp may have a manual switch that puts it in Mono mode, in which case you only use 1 of the 2 RCA jacks. The other option is to go get an RCA splitter. This will take your single sub-out cable and feed the exact same signal to both left/right of your amp. Either way, you get the same result. If the 1200W amp is for your sub(s) only, you should set the high-pass filter and subsonic filters to help your bass "hit harder" and cleaner.
May 17, 2009 | Dual XDVD8182 Car DVD Player
1200w Nitro amp
yes it could be your ground..check your negative from the amp is going to the car body and not the battery. also try a new set of rca leads from the stereo to the amp..also check that your stereo audio out voltage is the correct voltage for the amp inputs.
Jul 27, 2008 | Nitro BMW-481 Car Audio Amplifier
Car Audio (amp over heating)
The problem would be if you had it switched around. The 1200W subwoofer only means that it can handle 1200w of power the 1000w amp means that it can deliver 1000w of power. What you may have is an impedance mismatch. My question is what is the resistance rating on the sub woofer and what is the minimum resistance rating of the amplifier. These are actully the important issues at hand. the rating of the subwoofer resistance in Ohms should never be lower then the minimum resistance rating on the amplifier. in fact the resistance rating on the amp should match the resistance rating on the subwoofer.
Sep 09, 2007 | American Pro VS-2043 Car Audio Amplifier
Nitro BMW-481 Car Audio Amplifier Logo
103 people viewed this question
Top Nitro Car Audio & Video Experts
Level 1 Expert
Mark Skinner
Are you a Nitro Car Audio and Video Expert? Answer questions, earn points and help others
