Question about Excelstor Technology J880 Hard Drive
Cant install ubuntu 7.04 on Excelstor J880 SATA Drive
I am new with ubuntu, but when I install ubuntu 7.04 on an ide harddrive I finish the installation without any problem, but when I try to install the same version in my new P.C. Ubuntu can't detect my SATA drive. I am using the Ubuntu 7.04 Live CD. My P.C. specs are the following:
Processor : Intel Core 2 Duo 2.4,
Motherboard: Asus P5VD2-VM SE
Harddrive: ExcelStor J880s 80 GB
Optical Drive: LG CD ROM
thank very much
Ubunt74
Earlier versions of Ubuntu won't run well with a sata drive. I am using the same mainboard, try any version 7.10 or later.
Posted on Dec 01, 2008
    Champion:
    Scholar:
  • 206 Answers
I had the same problem. I reformatted the hard drive with ext3 file system and it worked. I used Gparted utility to do the formatting. I used the live CD, that means you boot on the CD with Gparted on it, but you don't have to install Gparted. If you need more info on burning the Gparted .iso file, let me know.
Posted on Oct 25, 2008
  • 99 Answers
From what I know, both your motherboard and your hard drive work with Ubuntu. I would try the newest release, 8.04 (Hardy Heron).
Try setting the motherboard into AHCI mode rather than IDE mode (you should be able to change this under hard drive settings in your BIOS)
Also, the problem may be with your optical drive. Try swapping that out.  If you can't solve it from there, if you haven't already, try posting on the ubuntu forums.
Posted on Jul 26, 2008
Can we use Excelstor Gstor as a Slave Drive? If yes, how? What is the jumper setting required?
To configure the hard drive as a slave drive, you need to set a jumper on the hard drive to SL (slave)
The other jumper settings are MA (master) and CS (cable select).
Mar 20, 2011 | Excelstor Technology J880 Hard Drive
I have changed hard drive to ExcelStor Callisto 80GB, and i can't update windows xp sp1 to sp2
What error-message(s) do you get?
Access http://www.microsoft.com/downloads
and download Windows XP Service Pack 3,
and install it.
You do *NOT* need to install SP2 before installing SP3.
Dec 26, 2009 | Excelstor Technology J880 Hard Drive
Pin connection for 'master ..slave
I assume these are IDE drives since SATA doesn't require jumper settings. . .You will need to set the primary drive jumper to master[ma] & the secondary drive jumper to slave[sl]. Some systems require dual hdd systems to have both set to the cable select[cs] jumper. Check your motherboard or system manufacturer manual to see which setup your system requires. If you lost the manual most manufacturers have it availablr on their website under the support link. Hope this helps.
May 23, 2009 | Excelstor Technology J880 Hard Drive
Sata hard drive not recognized by windows
If it is a new drive, then you need to partition and format it for windows to see it. To do this, click START, RUN and type in compmgmt.msc. CLick on Disk Managment. Look for the new drive, right click on it and select partition. When that is finish, right click the drive again and select format. Format the drive as NTSF..
Mar 31, 2009 | ASUS P5LD2-VM Motherboard
Ecs 6100sm-m mobo connections
you have a few options
1) buy a sata harddrive (faster then ide), use the ide for the second harddrive (backup) and cd/dvd rom
2) buy a sata cd/dvd rom use the ide on both harddrives (1 set to slave)
3) depends on your budget, buy a sata drive + sata cd/dvd rom so your main drive is on sata (faster than ide) then you only have your second drive as your backup drive on ide.
i had the same problem when i rebuilt mine, i went for the seperate harddrive and cd/dvd rom and my 320 gb ide as my backup drive
sorry to jump on this post aswell, see what others think
Mar 16, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
Internal 80gb harddrive excelstor j880
Was this 80GB cloned (copied) from an old 30GB disk?
Open Computer Management window doing this:
Start button - settings - control panel - administrative tools - computer management.
In the window that open, on the left hand side pane, expand Storage and click Disk Management. On the left hand side window, lower pane you should see a list of disks. See Disk 0,Basic <disk size>, Online. Do you see the 80GB as disk size? To the right you would see a series of boxes. Probably you see (C:) 30GB NTFS Healthy (system). Do you see to the right of it a box with 50GB (unknown partition)?
If so, you do have a 80GB disk, but only 30GB is a recognized partition by Windows. You can still use the the unknown partition. Post back here if you need instructions.
Dec 31, 2007 | Excelstor Technology J880 Hard Drive
Excelstor Technology J880 Hard Drive Logo
251 people viewed this question
Top Excelstor Technology Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David Payne
David Payne
Are you an Excelstor Technology Computer and Internet Expert? Answer questions, earn points and help others
