I can not figure out where to load photo paper in the paper tray
  • 876 Answers
Do you still have your manual? It should show you exactly what to do. Good Luck! If you don't have your manual ,go to the website for your PC and click on support and you should be able to get help there or even download a new manual.
Posted on Jul 26, 2008
HP Photosmart 3210 service & repair manual sought
There is NO technical information available for any HP inkjet models, not for anybody, even service centers.. HP offers exchange only.
Apr 02, 2014 | HP Photosmart 3210 All-in-One Printer...
How do I print color photos on glossy paper with Canon Pixma MP 6
printer supports it. just you have to goto printing preferences or printer properties and set rear tray to accept glossy paper. it will accept size of paper ur using. so give the actual size.
Apr 23, 2009 | Office Equipment & Supplies
HP OfficeJet Pro 8600 tray can't be inserted all the way. Stops with 3 inches of tray sticking out.
  1. Grasp the handle on the front of the input tray, and then pull the tray towards you to open it.
    Figure 1: Pull out the input tray
  2. Slide the paper width guides out as far as possible.
  3. Remove all paper from the paper tray.
  4. Inspect and remove any foam or tape packaging materials in the paper tray.
  5. Insert a stack of unused, plain white paper (with the print-side down) in the center of the tray.
    Figure 2: Load paper into the tray
    CAUTION: Do not load any paper above the solid red lines on the sides of the tray. Do not use torn, wrinkled, perforated, wet, or folded paper. Make sure to remove all paper clips and staples before loading the paper. Figure 3: Stack label height
  6. Slide the paper guides in so that they rest against the edges of the paper, and then insert the tray into the product and push it forward until it clicks into place.
    Figure 4: Slide the paper guides in and reinsert the tray into the product
  7. Pull out the tray extender on the output tray.
    Figure 5: Pull out the tray extender on the output tray
Step two: Load paper in optional Tray 2
Tray 2 is an optional accessory. Follow these steps to load paper in Tray 2.
NOTE: Tray 2 supports only plain letter or A4 paper.
  1. Grasp the underside of the tray, and then pull out the tray from the bottom of the printer.
    Figure 6: Pull out the tray from the bottom of the printer
  3. Load a stack of unused, plain white paper (print-side down) in the center of the tray. Make sure that the stack of paper aligns with the engraved lines in the tray.
    NOTE: Load Tray 2 with only U.S. Letter or A4 plain white paper.
  4. Slide the paper guides in so that they rest against the edges of the paper.
  5. Carefully reinsert the tray into the printer, and then push the tray forward to close it.
    Figure 7: Reinsert the tray into the printer
  6. Pull out the tray extender on the output tray.
    Figure 8: Pull out the tray extender
Load specialty paper Follow these steps to load specialty paper such as card stock, envelopes, photo paper, or labels.
Before you proceed, verify that your printer supports the specialty paper on which you are attempting to print by viewing the product specifications . If the size, type, or weight of the paper is not available, the printer does not support printing it. Also note the tray loading capacity for the type of paper on which you are attempting to print.
Sep 27, 2013 | HP Officejet Pro 8600
How to load photo paper in paper tray canon mg5220
For front or front tray loading printers, shiny side down... for rear/back loading printers.., shiny side up. Pictures should be visible coming out of the exit slot. Using pre-cut photo paper requires some technique, if the paper holder does not have an adjustable paper width feature. Feed paper in one sheet at a time to prevent jambs.
Aug 27, 2012 | Canon Pixma MG5220 InkJet Printer
Hp c6180 won't print from 4x6 photo paper tray
If you put regular paper in the tray as it is asking does the printer use the regular paper to print the picture? If so, be sure the 4x6 photo paper tray (with photo paper) is pushed all the way in, and when you select print there should be an option (probably hidden in a submenu) to select the photo tray as the paper source. If you are printing from Adobe Acrobat, I have not found a reliable way to get the c6180 to use the photo paper tray. I hope this helps.
Jul 15, 2012 | HP Photosmart C6180 All-In-One InkJet...
IMy wife pulled the paper tray completely out of
Loading your paper
Paper loading tips:
● Load paper with the side to be printed facing down.
● You can print photos and documents on a wide variety of paper sizes, from
8 x 13 cm (3 x 5 inch) up to 22 x 61 cm (8.5 x 24 inch). The 10 x 15 cm
(4 x 6 inch) photo paper is available with and without tabs.
● Before loading paper, pull the Main paper tray out (use the Main tray release or
the tray grips) and slide out the paper-width and paper-length guides to make
room for the paper. After loading paper, adjust the guides to fit close to the edges
of the paper without bending the paper. When finished loading paper, push the
Main tray back in all the way.
● Load only one type and size of paper at a time in the same tray.
● After loading paper, extend the Output tray extension to catch your printed pages.
Use the directions in the following table to load the most commonly used paper sizes
into the printer.
Paper type How to load Tray to load
Any supported
photo or plain
paper media
1. Extend the Main tray by
pulling it out with the Main
tray release or the tray
grips.
Load the Main tray
Chapter 2
(continued)
12 HP Photosmart 8200 series
2. Slide the paper-width and
their outermost positions.
3. Load paper with the side
Check that the stack of
paper is no higher than
the top of the paperlength
guide.
4. Adjust the paper-width
inward until they stop at
5. Push in the Main tray all
the way in.
6. Make sure the light on the
Photo tray button is
turned off to enable
printing from the Main tray.
Load paper and adjust guides inward
1 Paper-width guide
2 Paper-length guide
1 Push the Main tray all the way in
Aug 03, 2010 | HP Photosmart 8250 InkJet Printer
No matter how much paper is in the tray the printer will not feed paper. I can't figure out how the printer grabs the paper. any help?
Open the rear of the printer and turn the rollers with your fingers to make sure they are free rolling.Look in the manual for proper loading of the paper tray and try reloading the paper
Sep 28, 2009 | HP Deskjet 6980 InkJet Photo Printer
Paper jams using nextech premium photo pape gloss finish
  1. Before you do anything else, turn the printer off and on by following these steps:
    1. Turn off the printer by pressing the Power button.
    2. If the optional HP Photosmart Internal Battery is not installed in the printer, unplug the printer power cord. Wait about 10 seconds, then plug the power cord back in.
    3. If the optional HP Photosmart Internal Battery is installed in the printer, unplug the printer power cord, if it is plugged in. Open the battery compartment cover and remove the battery. Wait about 10 seconds, then reinstall the battery. If desired, plug in the power cord.
    4. Turn on the printer. The printer checks for paper in the paper path and will automatically eject the jammed paper. Press OK to continue.
    If the error still occurs, go on to the next step.
  2. If the paper came part way through the front of the printer, gently pull the paper towards you to remove it.
  3. If the paper did not come part way through the front of the printer, try removing it from the back of the printer:
    1. Remove the paper from the In tray, then push in the catches to release the in tray. Figure 1: In tray catches c00256377.jpg
    2. Open the In tray to a horizontal position.
    3. Gently pull the jammed paper to remove it from the back of the printer.
    4. Before you lift the In tray to close it, make sure it is pushed all the way to the right on its hinges. Figure 2: Pushing the tray to the right before closing c00256378.jpg
    5. Lift the In tray up until it snaps back into paper-loading position.
  4. Open and close the pen door on the front of the printer to make sure it is securely latched. Figure 3: Opening and closing the pen door c00269435.gif
How to avoid paper jams
  • Make sure that the cartridge door on the front of the printer is securely closed.
  • If you experience paper jams while printing, try loading one sheet of photo paper at a time. Insert the paper as far as it will go into the In tray.
  • Do not add paper while the unit is printing.
  • Do not use paper that is too thin, too slick, or that stretches.
  • Do not use torn or creased paper. Paper that has been printed previously may cause jams.
Aug 04, 2009 | HP Photosmart 375 InkJet Printer
Loading 4x6 photo paper
it's in the actual print settings. under file go to page settings, you can change it ther for as long as you need to print. Or you can apply it to keep those settings permenant. But if you choose to print a full sheet you will have to change the settings back to letter
Jul 19, 2008 | HP Deskjet 5440 InkJet Photo Printer
Printer will not print 4X6" pictures.
Loading index cards, post cards, and 4 x 6-inch photo paper Remove the paper output tray and all paper from the paper supply tray. Slide a stack of cards into the paper supply tray until they stop. Make sure the print side is face down. Adjust the paper-width guide against the cards, and then slide the paper-length guide in until it stops. Make sure the cards fit within the tray (do not overload it), and then reinstall the paper output tray. Figure 3: Loading a stack of cards 80455c3.jpg
Nov 10, 2007 | HP PSC 1410 All-In-One InkJet Printer
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
