Question about Apple iBook G3 Mac Notebook
Failure to read USB connected storage drives
Hi, I have an ibook G3 900 Mhz, dual USB running OSX 10.4.11. Tried to connect my Western Digital Passport portable hard drive by USB to back up my files, and the ibook would not open the drive for use. No icon on the desktop or in Finder. Also will not mount a 2 GB portable USB storage device. However, I can look under system profiler and see the device name connected. any ideas? I tried installing and running the Mount Me! program and it cannot find any volumes to access.
thanks
Dorothy
  • dorothy181 Jul 26, 2008
    thanks. I will try to find a hub to test that option.
    I should have mentioned though, that the ibook has previously read these drives with no problems....don't know if that would make a difference. I appreciate all suggestions.
    Genius:
  • 1,673 Answers
What I have seen with some computer models, is that the USB port cannot deliver enough current to run some devices.
If possible, use an external drive with its own power supply and see if it will work. Most likely it will.
Also, try a powered USB hub. I found that most of the time, a powered USB hub solved many problems with having enough power for some external USB devices.
Jerry G.
Posted on Jul 26, 2008
  • Jerry Greenberg
    Jerry Greenberg Jul 26, 2008
    If the computer was able to read the drive before, try the drive on another computer to see if the drive failed. Try another drive, and other devices on the port to see if there is any problem with the port (which most likley there is not).
    From what you now commented, I am thinking that the drive media has failed, because you can see the name of the device in the system profiler. This means that the system sees the drive's onboard controler.
    Jerry G.
Just got a new WD HD (1Tb) and am trying to put a bunch of movies onto it, but the drive is 'read only.' i can't create new folders on it, or transfer anything onto it either. i'm on OSX at...
How was the drive formated? If it was formated as NTFS, OSX can only read - it won't write.
If you're going to be using it on your Mac, then you should repartition/reformat it in your disk utility. That way you will get better performance out of it.
May 28, 2011 | Western Digital My Book Essential 1TB...
My western digital modal number WD1200UO17-005. When I plug it in into my computer it reads the usb drive but i am not able open thorugh My computer section. i have tried it in many pcs .... i use...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 04, 2010 | Western Digital 120 GB USB 2.0 Hard Drive
We bought some time ago an WD External Harddisk and now the Adapter doesn`t work anymore! What can I do?
Try connecting it to a different computer.
Any external storage device has three major parts:
* USB cable
* disk-drive
* USB-to-disk-drive adapter
Disconnect the disk-drive from that adapter, and connect the disk-drive as a "slave" disk-drive in a desktop computer, and see if you can read the files, which implies that the adapter is the part that has failed.
If you cannot read from the disk-drive, check its WARRANTY status. W.D. will replace it, if the warranty is still valid.
Otherwise, W.D. has a "Customer Loyalty" program: find the serial-number of your unit, access their web-site, and purchase another W.D. external storage unit, at a significant discount, by citing the serial-number.
Or, if the adapter is OK, then replace the disk-drive by a new one, and close-up the casing, to create a "revived" external storage device for your use.
Oct 23, 2010 | Western Digital Elements powered by WD 320...
External HDD not working , but can here it running
Have you tried powering it up without connecting it to the computer?
It should at least power up and do something. After that try connecting it to your PC (with the disk powered up already).
You can further check this external drive troubleshooting article, which has some tips on trying to get external disks to work.
Jules
Apr 19, 2009 | Western Digital My Book World Edition 1TB...
Hi, I just bought a clamshell ibook for my 9 yr. old. It has upgraded ram and Mhz. I'm afraid something is wrong with it. It takes FOREVER to load, makes a loud noise, and (although it has and airport...
Hi Sahemric,
What OS is running on your system also, OS9 or OSX. I've got to wrack my brain to remember how to check in OS9 (it's been about 6yrs since I last used it) but in OSX it's very simple. Goto the apple symbol in the menu bar choose 'About this mac' then 'more info...' and in the left hand 'Contents' panel in the 'Network' section is 'AirPort Card'. Select that and if it says 'No information found' then you ain't got it! Otherwise it will give you the Make, model and settings.
If you have got one then the setup is different for each version of the OS so again I'd need that but that should get you part way there
All the best
Sean
Dec 15, 2008 | Apple iBook G3 Clamshell (M2453B) Mac...
WD mybook world won't work on mac?
Window and OSX - fun and joy.
Since you formatted a 1TB drive and it works fine in Windows, I have to concluded the the drive was formatted NTFS.
Here is the issue in a nutshell, OSX supports reading NTFS but have very limited write cababilities.
If you want both Windows and OSX to have full access to an external drive you should format it FAT32. The only issue then is that under normal conditions a FAT32 drive has a maximum size of 32GB.
I would partition the drive to have 1 or more FAT32 partitions and then have the rest of the drive NTFS.
Is the OSX version correct or should it be 10.3. If it is actually 1.3 it would mean you have the OSX Server edition that originally came out in 1999 and it may not have very good USB support - version 1.2 would only support 1 USB device.
Oct 16, 2008 | Western Digital 500GB My Book World...
120 gig Western Digital black no longer mounts on LEOPARD osx 10.5 grrrr
i have the same problem.
macbook doesn't see anymore my hdd western digital 2,5'' white 250 GB.
tried disk warrior, disk utility but nothing.
it's just seem disappeared, even if i hear it works inside (and the led light is on)
what can i do?
May 10, 2008 | Western Digital Passport WDXML800UE...
Usb connection failure
ok" take a small needle , streighten the pin very carefully.
Jan 21, 2008 | Western Digital 320GB MyBook External USB...
Western Digital External Hard Drive SN WCAMR4295471
If you are using a pre-Windows xp system you may need to install specific drivers for your HD. If you run xp or Vista Try disconnecting completely the power cable from your computer for five minutes and then plug it back to the power and restart it. I know it sounds weird, but sometimes usb mass storage devices suffer troubles caused by electrostatic charges.
Jan 03, 2008 | Computers & Internet
Apple iBook G3 Mac Notebook Logo
208 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
