Question about Whirlpool Refrigerators
Whirlpool refridgerator 362L model No.WRN38RWG6 need to get spare parts for inside top loder plastic cover and bottom plastic part for bottle loader at door.
Yeah I alos need some spares fro min
Posted on Nov 10, 2008
I have a obsolete but modern-ish Whirlpool water cooler. The white plastic ring the 5 gallon water bottle sits on is cracked, and chunks are coming off. Whirlpool doesn't stock parts for old model
The collar is only there to keep the bottle at the correct height in relation to the water in the cooler. The principle is that when the vacuum inside the bottle is not being release by the water clearing the opening no more water will run out. To understand what I mean fill up a bottle ( any old bottle) right to the top. Fill up the sink and with you finger over the top of the bottle place the bottle upside down in the water. Take you finger from the hole and it will glug once maybe twice then no more water will run out until you lift the bottle out of the sink water. To stop more running out simply put the neck of the bottle bac in the sink. It is the same with you water cooler bottle. So all you need to do now is to to cover the foam with a piece of vinyle and it will be fixed.
Mar 08, 2013 | Cars & Trucks
How do I replace the CAM-AGIT on a Whirlpool Washer Model #395165
you have to remove the cover inside the upper agitator first, then you will see a plastic cover inside the top. it has 2 raised handle type tabs to pull on, then remove the cover and under it you will find a 7/16 bolt to remove and that will allow you to pull the tophalf of the agitator and change the agitate" dogs "
Dec 31, 2009 | Washing Machines
The ice dispenser rubber door or seal does not close allowing warm air back into the freezer and causing frost buildup. How difficult is that rubber seal to replace.
Remove the top freezer hinge cover and disconnect the plug there . This will remove power to the door . At the bottom of the dispenser cover , but inside the dispensing area , between the grill and the cover , insert a small screwdriver about 1 " in on both sides , and push down and inward , forcing the bottom of the cover outward . Do this carefully , due to plastic tabs on the dispenser cover . After bottom is loose , lift upward , to release the top plastic slots of the cover . Disconnect the plug on the cover . Remove the 2 screws holding the dispenser housing , and slide forward . You should now be able to see the door flap , return spring and pin . You will have to see which part(s) are needed or what the situation is . Maybe pin slid out , maybe the clear plastic ice guide , connected to the dispenser activator arm , broke loose , obstructing the closure of the door flap . Come back with your findings and a model number , and myself or another expert , will be glad to give you part numbers .
Sep 14, 2009 | Whirlpool Refrigerators
Ice maker door stays open. How do I take off front panel to revel parts?
Remove the top freezer door hinge cover and disconnect the plug there . This removes power to the door only . Between the dispensor grate and the dispensor cover , inside at the bottom inside dispensor , insert a butter knife and push down and inward , to pop the bottom of dispensor cover outward , on each inner side . This will pop the 2 plastic clips on the cover off . Lift the cover , to pass the plastic retainer tabs . Disconnect the plug to the dispensor . There are 2 screws holding the white housing which has the switches mounted onto it . Remove these screws , and slide the housing foreward and lift . You should be able to see the complete flap door and the spring and pin , to decide what is causing the door to stay open . If you come back with the found problem , and the model number , I would be able to give you the part number(s) needed .
Sep 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool refridgerator-model#ETICHMXKOO4-We have
There is ice buildup in the drain and maybe under the seperator. Remove the back panel in the freezer and the botom floor of the freezer and remove the ice. Be careful of the styrofoam ducts. Eric
Aug 10, 2009 | Whirlpool Refrigerators
Removing front cover to fix non-closing dispenser door
If your talking about the disp/foutain cover for the ice door chute not closeing problem heres how its done.
1 That cover is plastic and plastic flexs.
2 There should be two notches in the bottom area of cover. Insert flattip screwdriver in either one and pry out towards you. Bottom should pop off and top then slides up of tabs in door.
you can also try pushing down on top of disp cover when prying at bottom or pressing down really hard on fountain cover till part sortof flexs/slides down a milimetter and pulling towards you. The pressing down and pulling is down at bottom of cover inside disping area.
Jul 08, 2009 | Whirlpool GS6NBEXR Side by Side...
WHIRLPOOL TOP FREEZER ET1WTKXKQ01. NOT COLD ENOUGH
You need to look inside the freezer at the rear wall cover and see if it is frosted over. If your refrigerator is not defrosting that can cause the refrigerator side and the freezer side also not to cool to the desired temp.
Mar 30, 2009 | Whirlpool ET1WTKX Top Freezer Refrigerator
Whirlpool washing machine agitator removal
my whirlpool washing machine's agitator bottom is working but the top is not. How can I fix this myself?
Thank you,
Ann
Nov 24, 2008 | Estate TAWX700JQ Top Load Washer
Refridgerator door handle
The entire handle slides upward and out to detach from the door. There are two screws attached to the handle which can be tightened once the handle is off. Those screw heads are what reattach the handle to the door by sliding them through the door bracket opening, where they follow a short channel down leaving the handle secured again.
Dec 30, 2007 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
465 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
