Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Water fills dispensers
After every load, the dispensers fill with water. I can just lift the laundry dispenser out and empty it, but I have to siphon it out of the bleach and fabric softener dispensers. It takes alot of time. Why is this happening?
  • Anonymous Aug 23, 2008
    I pull the dispenser drawer out regularyly and clean it due to black mold build up. All of the holes are unblocked but I often have a full laundry detergent dispenser filled with water and usually the bleach dispenser is half full.
  • Anonymous Jan 17, 2009
    I have a bleach dispenser cup full of water after my washer completes its cycle. I either have to take the entire drawer out to empty it or shake it several times to get some of the water out. I have all the blue pieces and don't see any build-up in the holes.
    New Friend:
  • 60 Answers
A small amount of water left in them is normal but if they are totally filled something is wrong. Do you still have the blue pieces in the bleach and softner cups? If they're missing they will not empty right. You may also have build up in the holes that the liquid should go down that you may have to clean out.
Posted on Aug 15, 2008
Why is water sitting in soap dispenser pullout drawer?
Water remaining in soap dispenser. In front loading washers made by LG (some Kenmore too), water may remain filled in the soap dispenser after the wash cycle. This may be caused by the siphon tube being contaminated by detergent residue. To clear it, remove the siphon cover from the tube, and clean them thoroughly, making sure that all residue is removed. Replace the cover and make sure it seats properly all the way down. This will ensure that the siphon starts and continues until the dispenser tray is emptied. A small amount of water, a half inch or less, remaining is normal. There is a video on YouTube that suggests buying a new detergent tray. Try cleaning it first. There are no parts that will break or wear out under normal use.
Jul 27, 2014 | LG WM2688HWM TROMM SteamWasher
Fabric softener dispenser will not empty
Hello Mike Oswald - Fabric Softener is a very thick liquid that can clog up the siphoning mechanism. Try the following steps below.
  1. Remove the Dispenser
  2. Remove the Inset in the dispenser
  3. Clean out the dispenser and dispenser cover
The Fabric dispenser needs to have the hot and cold water at equal pressure for the fabric softener dispenser to operate properly.
1. Turn on the hot water fill then cold water fill at the washer. If the Wash Sense or temperature sensing is on it needs to be off.
  • If they seem to fill at the same pressure then you will need to contact a professioanl to move forward accurately.
  • If they seem not to fill at the same then you need to correct the pressure.
Mar 03, 2013 | Electrolux EWFLW65H 4.7 Cu. Ft. Washer
Fabric softner dispnser filled with water
Try siphoning it out or pumping it out .
Feb 06, 2013 | Washing Machines
My LG Washer 0642h doesn't always dispense the bleach. I notice that the dispenser fills up with water and doesn't empty. I have to empty it in the next wash. The dispenser doesn't appear to be clogged.
If the dispenser comes with a siphon tube, it is always this tube that is clogged. When the dispenser receives water from the machine, it fills up, the water/softener mix starts to go through the tube, at first by just draining because it has sufficient head, and then as the dispenser gets lower, siphon action in the tube takes place. . This tube must be clear for this dispenser to work.
Nov 25, 2009 | LG Washing Machines
Detergent dispenser is filled with water after wash is completed.
The water is left there because the syphon action is not working in the dispenser, what you need to do is to remove the dispenser drawer completely and thoroughly clean the conditioner compartment, poking any holes or tube, particularly the syphon tube with a piece of flexible wire or similar to ensure it is completely unblocked.
. to test, fill the conditioner compartment with water, and it should slowly empty itself, if it does not, then it is still blocked.
Plz rate this solution.Thanks.
Dec 27, 2008 | Bosch Washing Machines
Bleach not always being emptied, bleach marks on clothes, bleach sometimes runs right out when you fill it.
The dispenser works on a siphon principal. If you over fill the cup it will start the siphon and empty before it should. If that's happening you're using way too much. You only need about a tablespoon of soap, softner and bleach for a full load.
Aug 11, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG washing machine problem
I had the same problem with my LG front load. The second repairman fixed the problem. The water lines going into the machine were clogged with sediment (probably because I have well water). This caused the cups to remain full of water because the water pressure was so low the siphons were not working as they should to empty the cups. This also caused the wash cycles to be extremely long (sometimes 2 hours) because it took so long for the water to enter the machine for the wash & rinse cycles. Since the lines have been cleaned it works fine.
Jan 08, 2008 | Washing Machines
Bleach drains from compartment as soon as it is filled
Could you be putting too much bleach in? These things are usually designed to be self siphoning once the dispenser is full enough. The idea is that you half-fill it with bleach. At the right point in the cycle, the machine starts adding water, filling the dispenser up to the point where it siphons out until empty. If you overfill at the outset, the thing will empty straight away. If you're sure that isn't the cause, then take the dispenser out and check that the dam that keeps the bleach in place to start with isn't damaged (you may need to take a cover off the back of the dispenser first to see this). A.
Feb 18, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
257 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
