Question about Olympus IS-50 QD 35mm Point and Shoot Camera
How do i load the film - Olympus IS-50 QD 35mm Point and Shoot Camera
    Problem Solver:
  • 6 Answers
Please see page 8 of the user's manual, found here.
Posted on Feb 19, 2011
SOURCE:
I have an old Nikon Lite Touch Zoom 100 AF camera and I am having trouble loading the film. Can you use Kodak Advantix APS film in this camera or should I be using manual loading film instead?
This camera uses 35mm film, not APS film. 35mm is a larger format, giving MUCH better results, at the expense of having to manually pull the leader across to the take-up spool each time you load a roll.
Dec 29, 2010 | Nikon Lite Touch Zoom 120 ED/QD 35mm Point...
When i load the film in the back of the camera it blinks "E" and "o _ _" and doesn't move automatically to the first frame
Blinking 'E' means no film loaded. 'o_ _' shows that the film is loading. Apparently the film has not gone to the receiving spool. Pull the film all the way over to the other side when loading the film and make sure it catches the spool.
Feb 22, 2010 | Photography
Diana F+ 35mm back wont load film.....
possibly you have a friction padded roller instead of spikes place enough film on roller to overlap and then close camera
Dec 09, 2017 | Lomo Photography
Problem with loading film in my Nikon F60.
Draw the film all the way to the receiving spool. There's an 'eye' inside the film compartment to check that the film is loaded. When the film is not correctly loaded the camera thinks it's empty and rewinds the film.
Aug 08, 2009 | Nikon F60 35mm SLR Camera
I have no idea how to put my film in the "Pentax mz-m" camera? Someone help me. I'm new to this as I am just doing photography at school!
Pull up on the rewind knob ( left side ) to open the film door. put film cassette in chamber then lower rewind knob and pull enough film leader to the take up spool. attach film to spool. close the film door then advance the film to #1 on the counter.
Jun 06, 2009 | Pentax MZ-M 35mm SLR Camera
I loaded the film but display window shows a flashing zero
Go ahead and try anyway. A ruined film is far cheaper than a useless camera or a professional repair. In any case, if the film hasn't loaded properly it will only be the first short length of film which is ruined. As this is a newly loaded film you haven't any risk of losing any undeveloped photos.
Auto spooling film systems are great when they work, but sometimes are a real pain and some cameras seem really picky about having a film leader of precisely the right length. See if you can engage the the film onto the spool manually.
May 14, 2009 | Canon Prima Super 105X - Point & Shoot /...
Film will not load
Took out the battery, then put it back in. The film then loaded properly.
Jul 21, 2008 | Kodak Vivitar KV270 Film Camera
Film not loading properly
The lines could be scratches in the negatives.
Have you looked CLOSELY at your negatives with a magnifier to see if the scratches are on your film?
And when you say "Serviced", do you mean "cleaned" also?
If you have scratched film, then return it to the place you got it serviced/cleaned and let the owner/manager know that you just had it serviced there and it's scratching your negatives.
If you have an automatic camera, this bit below will be of no help.
Assuming that your camera is a manual loader, it may be that you aren't putting enough film into the take up spool for it to catch.
Try putting a little more film into the take up spool when you are loading the camera, and MAKE SURE that the holes in the film LINE UP with the film sprockets.
Then after you close the film door and start advancing your film, look at the film rewind knob, if it isn't turning while you are winding in film, then your film hasn't caught in the take up spool.
Another way to tell if your film is advancing is to shoot a test shot, and then advance the film, and then lightly turn the rewind knob a bit.
You should be able to feel the tension of the film if it is loaded correctly.
Feb 13, 2008 | Nikon FM10 35mm SLR Camera
Loaded film wrong??
I'm assuming you're not able to shoot pics. Its my best guess that the film just isn't getting loaded properly. Next time you attempt to load film there maybe a small red mark near the take spool (bottom edge where film goes) to indicate how far you need to pull the leader forward toward take up spool. I think the film isn't out quite far enough for the camera to do its auto load thing & when you close the back it goes thru its auto loading motions but the film just isn't getting loaded. Then close back & see what happens.
Apr 27, 2007 | Konica Minolta Maxxum QTsi with 35-80 lens...
Olympus IS-50 QD 35mm Point and Shoot Camera Logo
100 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
