Question about GE Dishwashers
I have no power on my dishwasher. I ran an extension cord to another outlet that I know has power and still nothing. I don have any led lights or anything. Can you help. GE model # GHDA960K03BB. Thank you Clint
    Scholar:
  • 93 Answers
Few components may cause power failure to your Dishwasher.
1. Disconnect your power plug from the socket outlet.
2. Trace the cord to where it connected to your dishwasher.
3. Tight those connectors firmly .
4. Plug back your dishwasher power cord .Start your dishwasher.
If nothing happen, check if control board came with fuse or bimetal. check the continuity of the fuse., You may also check your latch assembly.If no power still change the console or the control board.
Posted on Jul 26, 2008
How do I fix -no power issue on my samsung dmr78ahs dishwasher?
To eliminate a dishwasher problem, run a heavy 3 pronged extension cord from a known working outlet to the dishwasher and plug the dishwasher into the cord. If you still have no power (dishwasher is not showing any signs of life) then it is a dishwasher problem (circuit board, bad connection from dishwasher cord to dishwasher, etc).
If the dishwasher actually shows signs of life, then you may have a tripped breaker. Check the breaker to make sure it is on and that the tab is not either in the center or the off position. Also, try moving the dishwasher cord's plug from the outlet it is currently in to another outlet in the under sink area. There is a chance that the plug got switched from the normal outlet to the outlet that controls the garbage disposal, that outlet should only be hot when the disposal wall switch is flipped to the on position.
Dec 18, 2014 | Samsung DMR78AHS Builtin Dishwasher
LG LDS5811BB power cord is good, however the dishwasher is not getting any power. No lights no nothing.
There is a fuse on power unit, that should be tested first, check also a different outlet.
Aug 09, 2008 | LG Dishwashers
Kenmore 66517514202 dishwasher has no power dead no lights nothing
Does the wiring come up through the door at the bottom to the control panel? Check for a broken wire
May 21, 2012 | Kenmore Dishwashers
Need to know how to place extension cords for outdoor ice lights on roof edge of house
Hello, you can use a terminal strip power surge outlets. It will have many outlets on it that then go into one cord that will plug into the outdoor outlet.
Dec 06, 2011 | Heating & Cooling
Our hayward power-flo matrix series pump will not go on. When we push the on switch, nothing happens. We have checked the brakers, ran an extension cord to check the outlet, checked to see the motor will...
Thank you for posting your question here on Fixya.com.
Please explain what you mean by "checked the brakers, ran an extension cord to check the outlet, checked to see the motor will run manually and it will". I assume you mean the breaker in not tripped. What I am unsure of is how you would use an extension cord to check an outlet and what you mean by the motor runs manually.
If you have a power-flo matrix and it is plugged into a 115 volt outlet and by manually you mean you can spin the pump by hand and it turns freely and you have tried to plug something like a radio into the outlet to ensure it works then the problem is the motor or its on/off switch.
If a radio or some other item plugged into the same outlet also doesn't work you'll need to look at the electrical system.
Please add a comment to address what your situation is if this doesn't help.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
Feb 27, 2011 | Hayward 1 Hp Max - Flo Swimming Pool Pump
Whirlpool refrigerator trips gfci outlet
Yes ,, if the fridge outlet is behind the fridge and therefore not accessible for use by counter top appliances .. then yes change it to a regular outlet.
The cause is probably the compressor, getting a bit noisy..electrical noise I mean.
Feb 23, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore dishwasher... filled up with water and its lights went off.. no buttons work acts like no power. check the house fuse box - ok ... check the 2 door switch - ok .. checked the thermal fuse - ok ...
Did you check power to the unit? Double check the common and grounds. When servicing I will disconect(unplug from wall) power to the unit. Is it pluged in? Use another outlet(the outlet under the sink may be wired thru a switch for a disposer)even if you need an extension cord. Hope this helps.
Nov 12, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Xbox 360 won't turn on
I had this problem. Make sure the pins in the USB ports (2 on the front and 1 on the back of the console) aren't bent and there's nothing obstructing them. I unbent some of the metal inside these ports, and voila! I have a working xbox.
Oct 09, 2009 | Microsoft Xbox 360 Console
Plug at end of power cord for kenmore freestading dishwasher
heres a part number for a power cord 8566201, it costs about $50.. the same cord you can purchase at the big hardware store chains, home depot or Lowes, a heavy duty extension cord, with one end cut off, will be a fine sustitute and probly only $10 tops.. just buy a real thick extension cord
Dec 19, 2008 | Kenmore 17459 Free-standing Dishwasher
Dishwsher is getting no water?
can you make a test cord out of a short extension cord . cut the cord on the female end and crimp on two alligator clips . now with the dishwasher disconnected from the power grid put the alligator clips on the water valve .check that the alligator clips are not touching nothing but the valve terminals. Now plug up the male end into a wall outlet ,you should have water if not you will know what to test.
Dec 12, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Dishwashers Logo
336 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
