http://support.microsoft.com/kb/929461/en-us 1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer. hope that helps
Hi friends, I need region unlock code for Samsung HT-TZ315. Below hack worked for 6 months then...
(More)
Hi friends, I need region unlock code for Samsung HT-TZ315. Below hack worked for 6 months then again its got locked to region 5. urn On player with remote Press Enter on the remote Press 8, 4, 2, 6 and 9 on the remote Press Enter on the remote The player will power Off Switch On power from remote Player is now Region Free Please help me with this.
My CD Rom is not playing ...diagnostics indicate there is a code 39 problem. i have followed...
(More)
My CD Rom is not playing ...diagnostics indicate there is a code 39 problem. i have followed instructions on this forum but drawn blank. It looks like I need to go into the registry.
