Question about Nintendo DS Lite Console
Upper screen not working correctly
My son's DS LIte is a year and a half old.  The bottom screen works fine, but the top screen lights up, but you can't see anything on it.  I would just like to know if this can be fixed, and if so, where do I take it?
  • dtwolee Jan 16, 2009
    Hello and yes I have the same problem.
    I was trying to fix mine but mine ended up destroyed.
    I think its better going to a nintendo store or something.
  • 103 Answers
Replace the top screen.
Posted on Jul 26, 2008
I replaced the top lcd screen on my son's Nitendo DS lite and now when I turn it on the bottom screen flashes and shuts off. What is wrong with it?
Hello!
The bottom screen flashes because something is still wrong with the upper lcd
Make sure you didnt put a rip in the upper lcd. The smallest rip will mess it up.
Also, make sure the cable is in completely.. If its off the slightest cm , it'll cause the lower lcd to blink which causes the DSlite to not work
Dec 29, 2009 | Nintendo DS Lite Console
Help! My sons ds lite is two years old and has just
might be good to take out battery then put it back in, if that doesn't work go to nintendo forums, maybe reimburse you.
Dec 27, 2009 | Nintendo DS Lite Console
Pastel colors in upper screen
Take it to get checked and lower the back light.
Aug 06, 2009 | Nintendo DS Lite Console
The Ds lite powers up for a brief moment then crashes
well try to find DS parts in EBAY...
and don´t try to power the DS with a broken display ´cause it can short-circuit another part of your DS...and make things go Bad...
good Luck!
Dec 05, 2008 | Nintendo DS Lite Console
Turns on and lights up but no images on top screen
The DS top screen has two components, which are the LCD display, and the backlight. If the LCD display has gone bad but the backlight still works and the connecter is seated properly, the DS will still power on and the lower screen will be normal, and the top screen will light, but it won’t display anything.
You didn’t mention if your DS is the original DS or the DS Lite. Replacement top screens for the DS Lite are cheap on eBay, but installing the screen is a bit complex. The screen for the original DS is a different part and they are more expensive and hard to find.
I’ve never worked on an original DS, so I can only tell you about installing the top screen on a DS Lite.
First, the DS Lite has to be just about completely disassembled. You have to completely remove the top and bottom cases, pull out the microphone and wi-fi cables, and release the connecter for the top screen, which is located on the main board in the lower case. You’ll need the tri-wing screwdriver. You can leave the bottom screen/touch screen assembly attached to the main board, but be careful not to pull or tear the flex cables. Check YouTube for videos on disassembling the DS Lite.
Here’s the deal breaker for most people: The speakers are soldered to the flex cable of the top screen. I’ve never seen a replacement sold with speakers. You’ll have to unsolder your speaker wires from the old screen cable and reconnect them to the new one. If you can’t solder, you could take the screens to a local tv/electronics repair shop and pay to have it done. I got this information for you from http://wiinewz.com/forums/nds-general-discussion/72805-ds-top-screen-white-blank.html this appears to be a common problem I hope this helps
Dec 01, 2008 | Nintendo DS Lite Console
DS Lite top screen has gone grey with vertical stripes down it.
It is a problem with the flatcable of the upper TFT screen or the TFT itself. Only solution is treplacement of the TFT screen (flatcable is not separate replaceble). Because you say it is not even one year old, you still have warranty. Send it to Nintendo for repair!
John
Nov 30, 2008 | Nintendo DS Lite Console
Top screen goes opaque white, but looks fine with pressed L button.
Puchigusu,
You have a defective flatcable of the upper screen, or the calble is not correct seated in the connector on the systemboard.
The upper screen connector is on the bottom side of the Left button-switch.
If the flatcable is defective (most likely because of the open-close actions every time the DS Lite is used) you have to replace the complete upper screen (the cable cannot be removed without replacing the whole screen).
First try to reseat the flatcable in the connector. If that is not working, replace the screen (manuals how to open the DS Lite etc etc can be found on the Internet)
John
Oct 31, 2008 | Nintendo DS Lite Console
Nintendo DS lite - dropped
Might be worth taking it into a phone repair shop to see if they can replace the LCD screen. (yes, a phone repair shop - a lot of them do portable console screens too!) If they can't do it, it's probably unfixable realistically.
Mar 27, 2008 | Nintendo DS Lite Console
Bottom Screen doesn't work but lights up
cable problem most likely usually cheaper to replace.
Oct 06, 2007 | Nintendo DS Lite Console
Lights on bottom screen don't light
i dont think it is a problem i think it just does it to save energy
Oct 03, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
178 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
