Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
My MacBook I just replaced my DDR2 memory sticks and now i am getting an error that my memory is full and lost program access.  How can i fix this?
    New Friend:
  • 28 Answers
Did you use PC2-5300 200 Pin DDR2 SODIMM. One problem could be that the RAM is PC rather than PC2, a very easy mistake.
Otherwise, try taking out the RAM and reinstalling it. If that doesn't work, trying installing the original RAM.
Posted on Aug 25, 2008
My aspireone does not have a cd drivei lost my password how do i fix this
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and copy it to an USB memory stick.. Then insert this USB memory stick into your laptop/computer and boot up the laptop/computer with the Hiren's program and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Jan 12, 2013 | ASUS Eee Computers & Internet
Ram won't work
and old A rig from the dust bins at goodwill.
NO OS stated, nor BIOS version stated at BIOS info page.
and matters.
I'll assume there is no OS and just BIOS fails.
Leave bios in auto on DDR2. for sure.
getting good ram for old PC is not easy
you do know the old MMC (mem manager controllors)
stuck then right,> on density and type not just simple speed and fits slot. very complex that.
the sticks have ID chips that the BIOS uses to set them up
if the BIOS dont like your mem sticks it will never work.
The BIOS will run at the slowest speed of the slowed stick installed.
first ill attempt to read you PC full spec.
HP dont have it now , its gone to dead legacy mode. deleted the books.
looks like its 11 years old.
2006 made, oops not good
Athlon 64 X2 (W) 3800+ 2.0 GHz
The Atholon sets these rule(unlike pentium 4s)
on memory.
if you read the data sheet on it its very restrictive.
it does support 4x1gb,
Kingston memory pages i bet fails to help you , i bet.
they dont make them now. so..... leaving only fleabay used mem.
not good that.
PC2-4200 MB/sec
240 pin, DDR2 SDRAM
430 rules next , the HP pages are gone and the qualifed DDR pages with it... making , help on any Legacy box very hard.
but I do have facts on MMC
The BIOS rules ARE HPs and are now lost in the sands of time.
in most cases if you try each stick 1 by 1, on bank 0
if any stick fails in BIOS that stick is bad or not for the
Athlon 64 X2
The Athlon like all old processors even i3 and i5
have rules on max size per stick
max for all banks.
and chip density rules per stick
and even some can not run sticks with chips on both sides.
this is due to data bus capacitance rules too (limits)
why mess with this old air box.
why not get a modern 2 core mobo, say and I7 or
FX amd 2 core.
off hardware secrets page. (oxymoron)
Used by Athlon 64, Athlon 64 FX, Athlon 64 X2 and Sempron (some models) processors. On these models the embedded memory controller supports DDR2-533, DDR2-667 and DDR2-800 memories at dual channel configuration, meaning that the CPU accesses the memory at 128-bit rate if an even number of memory modules is used. Keep in mind that the memory controller found on socket 754, 939 and 940 CPUs supports only DDR memories.
you are running at
2.0 GHz 10x 5div = 800 MHz memory rate.
if we had the missing HP manual on memory
you would see a complex set of rules for population.
1 or 2 channel mode.
the Athlon chip maker and the mobo designer sets these rules.
try these,. they have a warranty
https://www.amazon.com/Upgrade-Pavilion-a1624nb-DDR2-533-PC2-4200/dp/B00337NKVS
http://www.memorystock.com/memory/HewlettPackardPavilionA1700N.html
with 32bit os, the memory will show as 3GB (or tad more
never 4gig.
Sep 05, 2017 | HP Pavilion a1700n PC Desktop
Why does memory upgrade for biostar k8m800-mam2 motherboard cause memory error beeps?
I would verify that the memory you're using is actually working properly.
Try to boot to the new stick and see if it works.
If not, it doesn't work.
If it does, you may need to replace the original stick with the same stick that you are trying to use now.
Use this site as a guide.
http://www.crucial.com/store/listparts.aspx?model=K8M800%20Micro%20AM2&Cat=RAM
Dec 22, 2011 | Biostar K8M800 Micro AM2 Motherboard
How do i unlock my apple laptop
my macbook pro has a password and i can't remember the password so i can't download any program. help please
Oct 21, 2010 | Apple aluminum 13-inch MacBook laptop-...
Memory upgrade problem
you have two sticks of different speeds they will not work together you must be sure that both sticks have the same FSB speed
Aug 17, 2009 | Apple Macbook Pro, MB133LL/A-2.4GHz Intel...
Problem with upgrading my acer extensa 5620z memory to 4GB
Hi there.
I recommend you get another stick of SODIMM to replace what seems to be the faulty stick.
If you are using XP or Vista X86 (32bit) then the system will only recognize 2.8 - 3GB of memory, only 64bit operating systems recognize the full 4GB.
Good luck ad thanks for using FixYa!!
May 24, 2009 | Acer Extensa 5620 Notebook PC
Can i place a 4g and 2g stick in my macbook pro
Hello! The MacBook Pro you have mentioned can only support 4GB's total. 2GB's in the first slot, and 2GB's on the second slot.
What you may have seen by accident was that you can purchase either a 4GB kit, or a 2GB kit. Meaning a 4GB kit with 2 2GB sticks, or a 2GB kit with 2 1GB sticks.
Your best bet is to go with a 2GB stick in each slot to max out your MacBook Pro. 2GB's is the largest each slot can read.
For more information, check out the website below which has very detailed information on memory for various systems.
MacBook Pro Memory Information
Mar 16, 2009 | Apple MacBook Pro Notebook
Format Error in Sony Cybershot
i think this problem arises when you fail to regularly format the card ie. take lots of pictures and delete some and repeat the process over and over instead of downloading every session and formatting the card causing coruption. Also if you've bought pro duo memory stick off ebay poss. its a very good forgery (again i've been caught out by this).
Nov 05, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
53 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
