Every time I take things from my flash drive. The pictures will transfur ok. The doc. in work looks like an empty folder. I was able to open it once. But I would loose it.
  • 876 Answers
Which document proggy do you have and what type of file are you saving to your flash? doc? rtf? If you are able to save a document to your hard, it must be a file type problem.
Posted on Jul 26, 2008
4gb usb cannot be detected on my computer. how to fix the problem?
Try it on the other pc just to see if its working atleast,if yes then try it back to your PC but using different usb port.or also go to my computer management then check your Universal serial bus controllers if not showing any errors rght click on them and scan for Plug and Play complaint components.
Sep 04, 2011 | HP Computers & Internet
I have just purchsed a 4gb usb2 flash drive . I am wanting to copy some pictures from my desktop and put them on my new laptop . Can anyone tell me how to do this in simple language as i do not understand...
Hi. All you have to do is:
- Insert your new USB flashdrive in an empty USB slot in your desktop computer.
- A new window will appear and will ask you what you want to do with that device... Choose "Open folder to view files".
- Then just leave it there and go to the file(s) you want to copy, right click on i and click "copy"
- Go back to your USB folder, right click on an empty space on that folder and click "paste". That will copy the files into your USB flashdrive.
- Remove the USB flashdrive from your desktop.
- Insert it into your laptop's empty USB slot.
- Highlight all the files you want to copy from USB flashdrive folder, right click and click "cut".
- Go to your laptops folder where you want to copy the files, right click on an empty space and click "paste".
Thanks for using Fixya!
Jun 12, 2011 | Computers & Internet
Hard drive c full hard drive d empty can i put them together or shift some from one to another
Well, the safest thing is to only move any photos and text docs to the D: So the 'My Documents' folder should be ok moved to the D: drive. I suggest you Google moving this folder to a different drive as you didn't specify your operating system and I only use XP.
Don't try and move any installed applications....these wont work again!
If you must move applications, (programs/software) then the only way is to firstly remove them in control-panel and reinstall them on the D: drive using your original install disks. Remember, by default programs get installed on the C: drive, so you have to 'tell' the install wizard you want it installed on the D: drive..
Hope this helps!
Nicam49
Apr 29, 2011 | Acer Aspire 1670
HOW TO UPLOAD PICTURES FROM MY PHONE ONTO PC
1. You should have a USB data cable where you can connect your phone to your PC.
2. Once you already connected your phone to your PC, there will be a notification "New Hardware Found".
3. Open "My Computer".
4. Then look for devices with removable storage. If you only have C and D partition then the removable storage would be E or F or G.
5. Open that drive, then look for the folder named "images". That folder contains all the pictures saved on your phones memory.
Mar 20, 2011 | Computers & Internet
I want to take the photos that I have in kodak file and copy them to flash dirve.
sheri359,
If you are using Kodaks easyshare program then you can simply "drag & drop" the pictures onto your flash drive. You can also trying looking on your "C: drive" (hard drive) for your pictures. Normally Kodak Easyshare stores pictures at C:\Documents and Settings\All Users\Shared Documents\Shared Pictures\Kodak Pictures. Once you find your pictures all you need to do is select all the pictures you want to copy and paste them into your flash drive.
If the pictures are on your camera then connect your camera to the computer and then click on "My Computer" on your desktop or under the start menu (if you are using Windows). Then if a few seconds you should see a drive pop up that will say "Kodak*****", proceed to double click on that and keep clicking into the folders until you see your pictures. Once you see your pictures copy all of them. Once copied open up "My Computer" again and select your flash drive. Once inside your flash drive then right click in the window and select "paste". Your pictures should start copying over to your flash drive. Once the copying it complete you are the safe to remove your flash drive.
Note: I am assuming that you are using a Microsoft Windows operating system. If you are using MAC OS X then it is slightly different but similar.
I hope this helps! Good luck!
Feb 28, 2011 | Kodak EasyShare One Digital Camera
Hi. I have a problem with the hard-disk. I have two partition. One is Windows (C:) and another is the one that I have all my documents (doc,mdb, photo, music, movies etc). When I open the partition with my...
Hi, Infact you do have a virus if you want to enter the other drive I'm assuming it would be D: on your computer go to windows explorer and right click on the drive select explore. This should open the drive. The next thing to do is select tools from the menu in the explorer window. Select Folder Options and then select view from the tabs. Scroll down till you see an option to see all files. Once that is done press ok. You should be still in your D: drive. Looking at the files now there should be an autorun file on the drive. This file was put there by a virus you can try deleting this file and all the other files that have funny names in the folder. This won't stop windows thou from giving you the Open With... if you double click the drive in you My Computer folder. The only work around I know is to right click the drive and select explore to get access to your files. I would then recommend backup everything on the drive that you need and formating that partition to make it work properly again.
Nov 25, 2010 | Microsoft Windows XP Professional SP2
Can not delete pictures on my flash drive on my mac computer
Are you sure they're not deleted? Try this procedure:
1) Connect the flash drive to the Mac's USB port.
2) Open the flash drive folder.
3) Delete any files you want.
4) Empty the wastebasket.
5) If the wastebasket is already empty (i.e. the files you deleted from the flash drive aren't in it), try to find the deleted files in the Finder and delete them manually.
6) Eject the flash drive - don't just pull it out of the USB port.
7) Put it back in, to check the deleted files really are deleted.
8) Sometimes a flash drive will create a hidden folder of deleted files, so it looks as if the files are missing, but they're still taking up space on the drive. If you find this is the case, use the Finder to track down the deleted files and delete them manually.
Hope that helps. Good luck!
Oct 10, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have problem in my USB flash drive
go to antispyware.com this is free try it. It has worked for me and the main thing its free!!!!
Jun 30, 2010 | Kingston 4GB Secure Digital High Capacity...
I cannot move a Microsoft Word file to a SanDisk 2 GB Cruzer,getting the message that "Directory or File cannot be created"...Why? What's the solution?
There is a problem with these where putting files directly on the root folder of the drive only allows X amount of files. Open the Cruzer from My Computer and create a new folder. Try dropping the Word file into that new folder and all should be well.
Hope this helps. Look forward to hearing back from you soon!
Feb 26, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Computers & Internet Logo
David Payne
David Payne
