My air conditioner is blowing hot air instead of cool air.. what is wrong with it? a/c is blowing warm air. i checked the circuit breakers, all okay. check both fans, all okay. i pulled the filter, just a little dirty. i pulled the main panel off the unit and checked for a dirty coil, all okay. The unit is 2.5 years old and is suspended in the air in my garage. is there a clogged drain. should i get the bleach out? please help.
  • emaltby Jul 27, 2008
    i poured bleach in the drain pan which it ran down through the drain pipe and it works now? is that normal.
  • 725 Answers
Check to see if you have power to the compressor. it my be a thermostate problem...
Posted on Jul 26, 2008
Why does it just blow cool air?
Check outside condensing unit. Should feel warm to hot air blowing out of the top. If cool to outside air temperature blowing off you likely have a refrigerant problem
Apr 02, 2016 | Heating & Cooling
What is wrong with my Goodman AC unit?
Sounds like it has no power getting to it at all. Dont forget that some circuit breakers have UP as ON and some have DOWN as ON. Do not just assume a common way is always the same. You may even have to have one UP and the other DOWN as on. Check what the switch or circuit breaker has written on it to be sure.
AIR CONDITIONERS run like a refrigerator, they manufacture their own Heat or Cool and blow air past the unit to give hot or cold air to cool or heat the Room. These do not require flowing water.
Sometimes people (wrongly) call EVAPORATIVE COOLERS air conditioners. (An evaporative cooler just blows AIR past flowing water to humidify the flowing air and therefore "cool" the area)
An evaporative cooler therefore would require running water and without flowing water, the unit may not start due to the installation of a "fail safe" switch. An evaporative cooler would generally have a large box mounted on your roof with open sides with filters which are kept moist by the running water and through which the fresh air is sucked and pumped into your home.
There are varying thoughts on both, I personally consider the REFRIGERATED style as the most effective type, but they are more expensive to install and run.
May 29, 2014 | Goodman Manufacturing GSZ130181A - 1.5 Ton...
Plug heats up, blows circuit breaker
Plug is having loose contact. may be wire are loose inside socket. Tighten them. The contact should be firm not sparky loose.
May 26, 2010 | Haier HWR10XC3 Air Conditioner
Bryant Legacy Air Conditioner doesn't blow out cold air
Unplug the unit with all controls off, then plug back in and wait 5 minutes before turning on switct at unit. Good luck
May 27, 2009 | Bryant 462AJC021BA Air Conditioner
Ac BLOWING HOT AIR INSTEAD OF COLD. All of a sudden my AC started blowing hot air instead of cold. It is set on cool.
Check to see if your outside unit is running. If not, check the breaker. If it is running you may have an issue with the reversing valve. It looks like three lines coming out of the top and one on the bottom. Trace the wires back to see that they are tight and secure. Of course, TURN OFF THE POWER first. good luck.
Apr 18, 2009 | Hunter 30124 Air Conditioner
Intertherm not cooling correctly
Sound like air flow problem to me, the inside and the outside. check the inside filter to see if it's clean and clean the outside condenser coils by washing it.
Aug 23, 2008 | Intertherm P3RA-048K Air Conditioner
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
My air conditioner is blowing hot air instead of cool air.. what is wrong with it? I have a Freyven mini split and the compressor turns on and off in a matter of seconds. It doesn't cool the room at all....
first if it turns on and off does this trip the breakers?? I'd recommend you to change the combination capacitor and check against wiring diagrams probably a misplaced wire that can do what your describing. check that you have your remote set on cooling to 21c or 72 f if you need any other help e-mail me at hvac.tech7872pr@gmail.com
May 04, 2008 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
291 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
