Cannot connect with broadband. broadband modem having trouble maintaining DSL and power as indicated by flashing red lights. Occasionally becomes steady green light only to roll back to flashing red. all connections appear to be in order. i am using dial-up at this time as a back-up. thanks for your help!
  • 876 Answers
Tell me about your PC and your modem and your server please.
Posted on Jul 26, 2008
A problem has occurred when trying to access the internet. Please check your DSL/Cable connection and verify your internet connection settings. Wtf is this ? Firmware update doesnt helped. .
Cables connection might loosen up. Check cables that runs from the wall jack going into your modem, make sure all cables are tightly plugged in. Also, check indicator light on your device. If DSL light is RED, OFF, flashing red, flashing green. there might be trouble with your Internet provider. DSL light indicator MUST be always on STEADY GREEN. If you see that the DSL light is not on STEADY GREEN status call your Internet service provider.
Oct 27, 2012 | D-Link Dlink Dir-600 Wireless Router...
Tip
Troubleshooting DSL Modems
Ever look at your DSL Modem and wonder what all those lights mean? Why do some flash, while others remain solid? What if your lights are different colors? How do you tell if your DSL Modem is working correctly?<br /> <br /> Each light on your DSL Modem represents a function. The light is an indication of whether that function is working properly. Sometimes the placement and title of each function can vary by modem manufacturer, but they are pretty standard in interpetation. If you look closely your modem, you might find that each function is labeled in small print to help identify them.<br /> <br /> A standard DSL Modem has a light for power, internet, ethernet, link and wireless connection. A healthy DSL Modem will have a steady green light that does not blink or flutter for all features other than internet, ethernet and wireless. A flashing or fluttering light indicates movement and useage. When you are connected to your DSL Modem wireless, the light for this feature will blink indicating a connection and/or active useage. If the internet connection is working properly the color of the light will be green. If the connection is working but experincing a problem the light can turn to yellow or orange. If the connection fails, the light on the DSL Modem can be red or absent depending on the problem causing the trouble. If your service is turned off by the provider, more than likely the light will be "off".<br /> <br /> If your lights turn a different color, are absent or your internet connection fails try power cycling your modem before reporting the trouble to your provider. Power cycling helps the DSL Modem to reset its connection and repair your internet services.<br /> <br /> If you are using a DSL Modem alone to connect to the internet (no additional router) you can power cycle it by first turning off your computer and then unplug the modem itself from the power source at the wall. Wait for 1 to 2 minutes and then plug it back into the power source and wait for the warm up to finish before rebooting the pc.<br /> <br /> The DSL Modem should go through the normal warm up procedures of blinking lights, making them all stable and solid green ect. You will know when its finished warming up when the features are set at solid green (other than eithernet, internet and wireless connection as explained above). When the modem finished the warm up, reboot your computer and check your internet connection.<br /> <br /> Power cycling your DSL Modem can help keep your connection healthy and running at optimal speeds.<br />
on Mar 30, 2011 | Computers & Internet
My dsl light will flash red when im surfing in the web and then it will restart normal for about an hour then the same thing will happen so what should i do ive reboted the system and power cycle it and...
Good day. For your problem as suggest for you to contact at&t and ask for a modem replacement. It should not take an hour for your dsl light to turn solid green. A red light also indicates a problem on the modem itself. Better to get it now than to lose your connection permanently in the future. Hope this information help you a lot. Have a great day to you.
Jun 12, 2011 | AT&T High Speed DSL Modem
My modems LAN light is blinking and I can't get Internet, I've tried unplugging it, but the problem still exists, please help
There will be 4 lights...
Power
Dsl
Internet
Ethernet
Power light indicates power supply is good...
Ethernet light indicates connection between modem and computer is good...
DSL light indicates connection between modem and telphone line is good... Also DSL light should be steady and it should not flash...
If it flashes then it says there is a lot of noise in telephone line...
Internet light says whether the internet status is connected or not...Internet light can flash depending upon the internet activity...
Feb 03, 2011 | Paradyne 6381 ADSL2+/ReachDSL Router...
My Motorola Modem Mstatea
When the DSL light turns red it indicates that the modem has no internet signal.
So please check if the cables are connected properly
Also ensure that there is a proper signal to your premises without any interference
This is called intermittent connection
If the DSL light turns red it indicates that there is a problem with the cables connected or the DSL line
Please check your DSL connection with ISP
There is on another reason that the modem might have gone bad.
If all the above steps are executed and if this issue still persists replace the modem
Jan 28, 2010 | AT&T High Speed DSL Modem
Hello
Does the DSL light come on at all when the modem is powered up?? If not, then it looks like the modem is bad.
When the modem is first powered on, all of the lights should come on and then go off after a few seconds. The power light should then begin to blink while the modem does a self test. Once that is done, the DSL light should come on and begin to flash red. If it senses a DSL connection, it will change to flash green until it has established a DSL connection. If it does not detect a DSL connection, it will continue to flash red. If the light does not flash at all or if the power light continues to flash after a minute or so, then the modem is most likely bad.
Let me know if you need more help. :)
Jan 12, 2010 | Siemens SpeedStream Modem (4100) (SS4100)
Assistance with blinking light on my DSL modem
First thing to do is unplug your DSL modem and leave it unplugged for about a minute then plug it back in and see if problem is corrected. If not you should contact your ISP tech support. You could have a bad line from the phone company or bad connection in your house. Also if you have filters installed on your other phones you can have a bad filter that is causing interference and keeping yoiur DSL from working properly. You should go to "Start" > "Run" and type cmd and hit "Enter"
In the command window type ping google.com -t (Enter) This will start a continual ping. If you are getting ping times exceeding 70 - 120 ms that could be a sign your DSL is not functioning properly or if you get packet loss. That is when the ping time doesn't return a time periodically.
Sep 23, 2009 | Westell Wirespeed LiteLine 6100...
No activity on my new speedstream 4200
Ethernet and DSL lights are indicating you have ADSL available on your line, and that you have computers connected to the router.
What has probably happened is that Optus did not set up the new router with your username and password. Go to thw following website for details on how to setup the modem.
http://help.optuszoo.com.au/help/dsl/connected/windows/optus_modems/speedstream_4200
Manual Modem Settings The Optus DSL Broadband self-installation CD configures all the necessary settings for your DSL Broadband service. You do not need to manually configure your modem if you have run the self-installation CD. While the following information is provided for your reference, using the self-installation CD is the recommended method for configuring your modem.
The Siemens SpeedStream 4200 ADSL modem can use either USB or Ethernet to connect to your computer.
  • If you are connecting via USB you will need to run the self-installation CD to install the USB driver before you connect your modem. The Siemens SpeedStream 4200 ADSL modem supplied by Optus has been customised for the Optus DSL Broadband service. Only the USB driver supplied on the self-installation CD will work with the Optus service. If you do not have the self-installation CD, you can download the latest drivers from the Siemens website.
  • If you are connecting via Ethernet it is possible to manually configure your modem without the self-installation CD. Only a web browser is required.
After connecting your modem there are two key steps to manually configure your modem for the Optus DSL Broadband service:
  • PC settings - Configure your computer's Ethernet network interface.
  • Configure Your Modem - Set the password in your modem's configuration pages.
top
PC Settings Step by step instructions are provided for each of the supported Windows operating systems:
  • Windows 98/Me
  • Windows 2000
  • Windows XP
  • Windows Vista
top
Configure Your Modem To configure your modem settings you must now access the configuration manager using your web browser. This is done by entering the IP address in the address bar of the browser window as follows:
Note: If you are updating the password in your modem, please complete steps 1 to 3 only.
Step 1 of 5
  • Enter http://10.1.1.1 (Default IP address of the Optus Supplied Siemens SpeedStream 4200) to access the modem Configuration software. You may wish to add this page to your Favorites for easy access later.
  • The following modem System Summary screen will appear.
ss4200_home_disconnected.gif Step 2 of 5
  • Click on the word Setup in the green menu of options on the left side of the web page. An expanded set of options will be displayed.
  • Click PPP in the list of options that appeared below the word Setup.
  • The ISP Password page will appear:
  • Replace the default username (john_citizen@optusnet.com.au) with the username provided for you by Optus DSL Broadband.
  • Replace the default password with the password provided by Optus DSL Broadband in the Password field.
  • Note: You will find your Optus DSL Broadband username and password on the letter you received with your self-installation kit.
  • Save these details by clicking the Save Settings button.
Step 3 of 5
  • The next screen will ask you to disconnect and reconnect to the Optus DSL Broadband service.
  • Click the link to return to the System Summary page.
  • Click the Disconnect button to disconnect the modem from the Optus DSL Broadband service. The text on the button will change to Connect.
  • Click Connect to reconnect the modem to the Optus DSL Broadband service.
Step 4 of 5
  • Click the word Mode in the green menu of options on the left side of the web page.
  • Confirm that Optus Bridge is the selected operation mode.
  • If Optus Bridge is not selected click the radio button next to Optus Bridge to select it.
  • Click the Apply button.
  • Click the Reboot button to restart the modem using your saved settings.
  • After about a minute the modem will return to an operational state and connect to the Optus DSL Broadband service.
ss4200_reboot_3.gif Once the modem has rebooted and the ADSL connection has been successfully established the DSL LED indicator will light steady green.
Your modem is now connected to the Optus DSL Broadband service.
Jul 25, 2009 | Siemens SpeedStream 4200 (13A4200001)...
Motorola router
Modem light goes RED if No external Ethernet device has been attached and detected OR The Ethernet link is down.
in your case it is going to be the DSL MODEM ....
Second cause could be The WAN interface has been disabled by the firmware.
TO enable it log on to your router's address http://192.168.10.1.
and look for WAN options.
http://broadband.custhelp.com/cgi-bin/broadband.cfg/php/enduser/std_adp.php?p_faqid=17058&p_sid=rTOCxT5j&p_lva=17178&p_accessibility=&p_redirect=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9ODAsODAmcF9wcm9kcz02MzAsNjQ0JnBfY2F0cz0mcF9wdj0yLjY0NCZwX2N2PSZwX3BhZ2U9MQ%2A%2A&p_li=
Thanks ,, please let me now it worked or not
Jun 09, 2008 | Arris WR850G Router (DHWR850G)
DSL indication problem
ramjee,
pls can you replace the power adapter you are using to connect to power source
or
uninstall and reinstall the modem driver it should help.
Apr 05, 2008 | Computers & Internet
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
