Question about SanDisk Audio Players & Recorders
MP3 will not turn on
SanDisk 2GB, Black, serial # BEO804AOVK-2GB worked fine till bedtime. In the morning, it would not turn on. I recharged it as usual, even though the battery at night had been 1/2 to 3/4 charged. Player would not light up and will not come on by switch or when connected to computer. Please help!
Gene
    Genius:
  • 3,422 Answers
HI,
Try reseting it by holding the power button for 30 sec.
Let me know the result.
Posted on Jul 26, 2008
  • Priya darshan Jul 26, 2008
    The next thing you can do is just remove the battery from your player and then connect the usb cable to the player and the pc.If the player turns on then problem is with the battery.Just try putting the battery back and see if it turns on.IF it doesn't then you will have to replace it with a new battery.
The screen is dim it is on the last song played it won't do anything won't turn off but won't play either, It worked fine this morning help please It is a sansa clip 2gb I've had it since Sept. 09
Sansa Clip won't turn off right? push up power button and hold it for 10 to 20 second, your device will turn off now.
After that, you should update your new firmware from sandisk forum, you should check Sansa Clip or Sansa Clip+ from the following web,
http://forums.sandisk.com/sansa/
Good luck
Jan 25, 2010 | SanDisk Sansa Clip MP3 Player
Spare clip for sandisk blak 2gb how do i get one.
Sandisk does not list them for sale on their website, but you can call them and order one. Just have your model # and serial number ready. 1-866-SANDISK
Mar 02, 2009 | SanDisk Sansa Clip MP3 Player
My SanDisk Sansa Clip MP3 Player does turn on but does'nt work.
this should fix it, a tiny software that fixed mine just fine
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
Nov 20, 2008 | SanDisk Sansa Clip MP3 Player
HI,
remove cover and reset by removing the battery.If you see screws behind then use a screw driver to take it out.
Jul 26, 2008 | Audio Players & Recorders
My M240 sandisk is frozen
Attention: Resetting the device will delete all the songs
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
May 30, 2008 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa c200 2Gb won't turn on
Some recent Windows updates have caused problems as severe as this on many mp3 players regardles of manufacturer (the iPod has been immune because it is not Windows-based). If you have either Windows Vista or Windows Media Player 11, which are the latest versions, then perform a firmware update on your Sansa player by going to the Sansa website and getting the firmware updater:
http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
Mar 12, 2008 | SanDisk Sansa c200 MP3 Player
It sounds your device batteries is bad...what I will recommend you to do is to contact sandisk to see if they can RMA the device for you...Sandisk number is 1-866-726-3475..
I hope this helps...
Thank You
Computerrep
Feb 05, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
MY Sandisk c150 keeps blinking when turned on.
You have probably corrupted it. Plug it back into the computer- reformat if you must and do it properly as you know you should. You may wind up buying another
Aug 14, 2007 | SanDisk Sansa c150 MP3 Player
Sandisk Sansa e260
u have to wait till the screen will be black. I had the same problem with my sansa. it can lasts 1 or 2 days. after screen is black and then do following: 2. change lock switch to orange position 3. Press and hold rec button (at left side) 4. while pressing the rec button, turn the player on 5. it will appear the boot menu. connect the USB cable and try to continue the firmware 6. if it doesn't work, do a firmware downgrade. download this file: http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe 7. execute the application while in boot mode good luck darek
Apr 03, 2007 | SanDisk Sansa e260 MP3 Player
23 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
